117305
117305
    LUTZE
117305 数据手册
Technical data sheet · LÜTZE SUPERFLEX® TRONIC AS PUR PUR actuator cables or cables ctrack compatible Subject to technical modification 117305 Identification Use/Area of application Application Properties Type Part-No. • • • • • • • • • • • • • • Technical data Rated voltage Test voltage Insulation resistance Temperature range 4×0.34 UL 117305 Machine and device construction, transport and conveyor technology Actor, sensor technology Combination cable SUPERFLEX® ASB for actuator box, schleppfähig Through full PUR jacket, optimally suited for c-tracks, extremely harsh operating conditions and aggressive coolants and lubricants Flame-retardant, self-extinguishing Very good alternating bending strength Good pressure and roll-over resistance Low adhesion, abrasion-proof, nick-resistant, tear-propagation-resistant Hydrolisis-resistant, microbe-resistant, and rot-resistant Weathering, ozone and UV resistant (normal lighting conditions Good industrial- and salt water resistance Excellent coolant and lubricant resistance Widely resistant to oils, greases, alcohol-free benzines and kerosene (see tech. information) Free from paint wetting disruptive substances (LABS-free), RoHS-compliant 300 V 3000 V min. 20 MΩ × km moving -5 °C to +80 °C 24.11.2007 – Subject to technical modification Part-No. 117305 USA: LUTZE INC. 13330 South Ridge Drive • Charlotte, NC 28273 Tel.: +1 (704) 504-0222 • Fax: +1 (704) 504-0223 www.lutze.com • info@lutze.com United Kingdom: LÜTZE Ltd. Unit 3 Sandy Hill Park Sandy Way, Amington • GB-Tamworth, Staffs, B77 4DU Tel.: +44 (0)1827 31333-0 • Fax: +44 (0)1827 31333-2 www.lutze.com • sales.gb@lutze.co.uk page 1 of 2 Technical data sheet · LÜTZE SUPERFLEX® TRONIC AS PUR Minimum bending radius Radiation-resistance Burning behaviour Halogen-free Number of strands/cross-section Outer-∅ Weight Cu-Index Design Strand colours Conductor structure Conductor insulation Conductor labelling Outer jacket Jacket colour General Note fixed -40 °C to +80 °C moving Cable diameter × 7.5 fixed Cable diameter × 4 7 5×10 cJ/kg Flame-retardant according to VDE 0482 T. 265-2-1; IEC 60332-1 according to DIN EN 50264-1, EN 50267-2-1 and EN 60684-2 4×0,34 UL 4.6 approx. mm 4.8 kg/100 m 1.3 kg/100 m brown, blue, black, white Bare copper wire, finest multi-strand according to DIN VDE 0295 class 6, IEC 60228 class 6 Special-TPE conductor insulation Conductors colour-coded Full polyurethane jacket, matt, adhesion-free surface grey CE These products are in conformity to the EC Low Voltage Directive73/23/EWG or 93/ 68/EWG respectively Logo 24.11.2007 – Subject to technical modification Part-No. 117305 USA: LUTZE INC. 13330 South Ridge Drive • Charlotte, NC 28273 Tel.: +1 (704) 504-0222 • Fax: +1 (704) 504-0223 www.lutze.com • info@lutze.com United Kingdom: LÜTZE Ltd. Unit 3 Sandy Hill Park Sandy Way, Amington • GB-Tamworth, Staffs, B77 4DU Tel.: +44 (0)1827 31333-0 • Fax: +44 (0)1827 31333-2 www.lutze.com • sales.gb@lutze.co.uk page 2 of 2
117305 价格&库存
很抱歉,暂时无法提供与“117305”相匹配的价格&库存,您可以联系我们找货
