AA3046V
AA3046V
    ECLIPSE
AA3046V 数据手册
Hacksaw Blades Bi-Metal Plus 30 Cuts 30% more effectively than a conventional blade. Benefits include a sharper first cut, faster cut and longer blade life Size (mm) 250 x 13 x 0.65 250 x 13 x 0.65 250 x 13 x 0.65 300 x 13 x 0.65 300 x 13 x 0.65 300 x 13 x 0.65 (in) 10 x 1⁄2 x 0.025 10 x 1⁄2 x 0.025 10 x 1⁄2 x 0.025 12 x 1⁄2 x 0.025 12 x 1⁄2 x 0.025 12 x 1⁄2 x 0.025 Teeth Per(in) 18 24 32 18 24 32 Price Each Order Code 137-3895 137-3896 137-3897 137-3898 137-3899 137-3901 Hi-Cut HSS cutting edge, electron beam welded to a tough spring back. More shatter-resistant than other types of blade. Size (mm) 300 x 25 x 1.25 300 x 25 x 1.25 300 x 25 x 1.25 300 x 25 x 1.25 350 x 32 x 1.6 350 x 32 x 1.6 400 x 32 x 1.6 400 x 32 x 1.6 400 x 40 x 2.0 450 x 32 x 1.6 450 x 32 x 1.6 450 x 40 x 2.0 525 x 40 x 2.0 525 x 45 x 2.5 (in) 12 x 1 x 0.050 12 x 1 x 0.050 14 x 1 x 0.050 14 x 1 x 0.050 14 x 11⁄4 x 0.062 14 x 11⁄4 x 0.062 16 x 11⁄4 x 0.062 16 x 11⁄4 x 0.062 16 x 11⁄2 x 0.075 18 x 11⁄4 x 0.062 18 x 11⁄4 x 0.062 18 x 1⁄2 x 0.075 21 x 11⁄2 x 0.075 21 x 13⁄4 x 0.088 Teeth Per(in) 10 14 10 14 6 10 6 10 6 6 10 6 6 6 Price Each Order Code 137-3914 137-3915 137-3916 137-3917 137-3918 137-3919 137-3920 137-3921 137-3922 137-3923 137-3925 137-3926 137-3927 137-3928 Flexible Silicon Steel Designed primarily for the occasional user. Will cut most types of softer materials. Size (mm) 250 x 13 x 0.65 250 x 13 x 0.65 300 x 13 x 0.65 300 x 13 x 0.65 300 x 13 x 0.65 300 x 13 x 0.65 (in) 10 x 1⁄2 x 0.025 10 x 1⁄2 x 0.025 12 x 1⁄2 x 0.025 12 x 1⁄2 x 0.025 12 x 1⁄2 x 0.025 12 x 1⁄2 x 0.025 Teeth Per(in) 18 24 14 18 24 32 Price Each Order Code 137-3902 137-3903 137-3904 137-3905 137-3906 137-3907 All Hard Plus 30 Cuts 30% more effectively than a conventional blade. Benefits include a sharper first cut, faster cut and longer blade life. Size (mm) 250 x 13 x 0.65 250 x 13 x 0.65 300 x 13 x 0.65 300 x 13 x 0.65 300 x 13 x 0.65 300 x 13 x 0.65 (in) 10 x 1⁄2 x 0.025 10 x 1⁄2 x 0.025 12 x 1⁄2 x 0.025 12 x 1⁄2 x 0.025 12 x 1⁄2 x 0.025 12 x 1⁄2 x 0.025 Teeth Per(in) 18 24 14 18 24 32 Price Each Order Code 137-3887 137-3888 137-3889 137-3890 137-3892 137-3893 High speed steel. with strong rigid back to assist in accurate cutting. 493775 Size (mm) 300 x 16 x 0.8 300 x 16 x 0.8 300 x 16 x 0.8 300 x 25 x 1.25 300 x 25 x 1.25 350 x 25 x 1.25 350 x 25 x 1.25 350 x 32 x 1.6 350 x 32 x 1.6 350 x 40 x 2.0 400 x 32 x 1.6 400 x 40 x 2.0 400 x 40 x 2.0 425 x 25 x 1.25 425 x 25 x 1.25 425 x 32 x 1.6 425 x 32 x 1.6 450 x 32 x 1.6 450 x 32 x 1.6 450 x 40 x 2.0 525 x 40 x 2.0 525 x 45 x 2.25 600 x 50 x 2.5 600 x 50 x 2.5 600 x 50 x 2.5 600 x 50 x 2.5 (in) 12 x 5⁄8 x 0.032 12 x 5⁄8 x 0.032 12 x 5⁄8 x 0.032 12 x 1 x 0.050 12 x 1 x 0.050 14 x 1 x 0.050 14 x 1 x 0.050 14 x 11⁄4 x 0.062 14 x 11⁄4 x 0.062 14 x 11⁄20.075 16 x 11⁄4 x 0.062 16 x 11⁄4 x 0.062 16 x 11⁄2 x 0.075 16 x 11⁄2 x 0.075 17 x 1 x 0.050 17 x 1 x 0.050 17 x 11⁄4 x 0.062 17 x 11⁄4 x 0.062 18 x 11⁄4 x 0.062 18 x 11⁄4 x 0.062 18 x 11⁄2 x 0.075 21 x 11⁄2 x 0.075 21 x 13⁄4 x 0.088 24 x 13⁄4 x 0.088 24 x 2 x 0.100 24 x 2 x 0.100 Teeth Per(in) 14 18 24 10 14 10 14 6 10 6 6 10 4 6 10 14 6 10 6 10 6 6 6 6 4 6 Price Each Order Code 137-3856 137-3858 137-3859 137-3860 137-3861 137-3862 137-3864 137-3865 137-3866 137-3867 137-3868 137-3871 137-3872 137-3873 137-3874 137-3875 137-3876 137-3877 137-3878 137-3879 137-3880 137-3881 137-3883 137-3884 137-3885 137-3886
AA3046V 价格&库存
很抱歉,暂时无法提供与“AA3046V”相匹配的价格&库存,您可以联系我们找货
