ES3D
ES3D
    DOWO(东沃电子)
    SMB(DO-214AA)
    200V 3A
ES3D 数据手册
ES3A THRU ES3J SURFACE MOUNT SUPER FAST RECTIFIER Forward Current - 3.0 Amperes Reverse Voltage - 50 to 600 Volts DO-214AA/SMB FEATURES The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 For surface mounted applications Low reverse leakage Built-in strain relief,ideal for automated placement High forward surge current capability High temperature soldering guaranteed: 250 C/10 seconds at terminals Glass passivated chip junction 0.155(3.94) 0.130(3.30) 0.087 (2.20) 0.071 (1.80) 0.180(4.57) 0.160(4.06) 0.012(0.305) 0.006(0.152) 0.096(2.44) 0.084(2.13) MECHANICAL DATA 0.060(1.52) 0.030(0.76) Case: JEDEC DO-214AA molded plastic body Terminals: leads solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight:0.003 ounce, 0.093 grams 0.008(0.203)MAX. 0.220(5.59) 0.205(5.21) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Catalog Number SYMBOLS Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL=75 C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 3.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Maximum reverse recovery time (NOTE 1) VRRM VRMS VDC Typical thermal resistance (NOTE 3) Operating junction and storage temperature range ES3A ES3B ES3C 50 35 50 100 70 100 150 105 150 ES3D ES3E 200 140 200 ES3G ES3J UNITS 400 280 400 600 420 600 VOLTS VOLTS VOLTS 300 210 300 I(AV) 3.0 Amps IFSM 100.0 Amps VF 0.95 1.25 1.7 Volts IR 5.0 100.0 µA trr 35 ns RθJA 47.0 C/W TJ,TSTG -50 to +150 C Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A 2.P.C.B. mounted with 0.2x0.2 ”(5.0x5.0mm) copper pad areas AVERAGE FORWARD RECTIFIED CURRENT, AMPERES RATINGS AND CHARACTERISTIC CURVES ES3A THRU ES3J PEAK FORWARD SURGE CURRENT, AMPERES FIG. 1- FORWARD CURRENT DERATING CURVE 3.0 2.4 1.8 Single Phase Half Wave 60Hz Resistive or inductive Load 1.2 0.6 0 0 25 50 75 100 125 150 175 FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 100 80 60 40 20 0 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 1 10 AMBIENT TEMPERATURE, C FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 20 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 10 1 0.1 ES3A-ES3D ES3E-ES3G ES3J 0.01 0 0.4 0.8 1.2 1.6 1.8 1,000 100 10 TJ=100 C 1 TJ=25 C 0.1 0.01 TRANSIENT THERMAL IMPEDANCE, C/W INSTANTANEOUS FORWARD VOLTAGE, VOLTS FIG. 5-TYPICAL TRANSIENT THERMAL IMPEDANCE 10 1 0.1 0.1 1 10 t,PULSE DURATION,sec. 0 20 40 60 80 100 PERCENTAGE OF PEAK REVERSE VOLTAGE,% 100 0.01 100 NUMBER OF CYCLES AT 60 Hz 100
很抱歉,暂时无法提供与“ES3D”相匹配的价格&库存,您可以联系我们找货
