1.5KE Series
东沃电子
1.5KE Series
DOWOSEMI
Breakdown Voltage: 6.8 to 600 V
Peak Pulse Power: 1500 W
Axial Lead
Transient Voltage Suppressors
Features
ϥ
ϥ
ϥ
ϥ
ϥ
ϥ
ϥ
DO-201
Glass passivated chip
1500 W peak pulse power capability with a
10/1000 ȝs waveform, repetitive rate (duty
cycle):0.01 %
Low leakage
Uni and Bidirectional unit
Excellent clamping capability
Very fast response time
RoHS compliant
1.000 [25.40]
MIN
ϥ
ϥ
DIA.
0.209 5.30
0.189 4.79
1.000 [25.40]
MIN
Dimensions :
inch [ mm ]
DO
ϥ
Case: Molded plastic
Epoxy: UL 94V-0 rate flame retardant
Lead: Solderable per MIL-STD-202, method
208 guranteed
Polarity: Color band denotes cathode end
except Bipolar
Mounting position: Any
WO
ϥ
0.375 9.53
0.285 7.24
Mechanical Data
ϥ
DIA.
0.042 1.07
0.038 0.97
Maximum Ratings(TA=25к unless otherwise noted)
Parameter
Peak power dissipation with a 10/1000ȝs waveform(1)
Peak pulse current wih a 10/1000ȝs waveform(1)
Power dissipation on infinite heatsink at TL = 75 °C
Peak forward surge current, 8.3 ms single half sinewave unidirectional only(2)
Maximum instantaneous forward voltage at 100 A for
unidirectional only(3)
Operating junction and storage temperature range
Value
Symbol
PPP
1500
IPP
See Next Table
PD
6.5
UNIT
W
A
W
IFSM
200
A
VF
3.5/5.0
V
TJ, TSTG
–55 to +150
°C
Note:
(1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1
(2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum
(3)VF
很抱歉,暂时无法提供与“1.5KE400A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.64806
- 50+2.15817
- 150+1.94822
- 500+1.71548
- 2500+1.59884
- 5000+1.52874
