1N4728A-Z1330A
Axial Lead
Zener Diodes
VZ: 3.3 to 330 V
PD: 1 W
Features
DO-41
Glass passivated chip
● Low leakage
● Built-in strain relief
● Low inductance
● High peak reverse power dissipation
● Lead (Pb)-free component
● For use in stabilizing and clipping circuits
with high power rating
DIA.
0.033 0.84
0.028 0.71
1.000 [25.40]
MIN
0.205 5.21
0.165 4.19
Mechanical Data
Case: Molded plastic
● Epoxy: UL 94V-0 rate flame retardant
● Lead: Axial leads,Solderable per MILSTD-202, method 208 guranteed
● Polarity: Color band denotes cathode end
● Mounting position: Any
DIA.
0.117 2.97
0.090 2.29
1.000 [25.40]
MIN
Dimensions :
inch [ mm ]
Maximum Ratings(TA=25℃ unless otherwise noted)
Parameter
DC power dissipation at TL = 75 °C(1)
Maximum forward voltage at IF = 200 mA
Maximum thermal resistance junction to ambient air
Junction temperature range
(2)
Storage temperature range
Symbol
PD
Value
1
Unit
W
VF
1.2
V
RӨJA
170
°C/W
TJ
- 55 to + 175
°C
TSTG
- 55 to + 175
°C
Note:
(1) TL = Lead temperature at 3/8 " (9.5mm) from body
(2) Valid provided that leads are kept at ambient temperature at a distance of 10 mm from case
0571-87006810
www.dowosemi.cn
第 1 页,共 3 页
1N4728A-Z1330A
Ratings and Characteristics Curves (TA=25℃ unless otherwise noted)
100
0.8
Temperature Coefficient,ӨVz, (mV/°C)
Maximum Power Dissipation, PD (W)
1.0
0.6
0.4
0.2
0.0
50
75
100
125
150
175
Range
10
1
200
10
100
Zener Voltage, Vz, (V)
Lead Temperature ,TL (℃)
Fig. 1 - Power Temperature Derating Curve
Fig. 2 - Temperature Coefficients v.s. Zener
Voltage
Junction to Lead Thermal Resistance, ӨJL,
(°C/W)
175
150
125
100
75
50
25
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
Lead Length to Heatsink , L, (inches)
Fig. 3 - Typical Thermal Resistance v.s. Lead Length
Peak Surge Power, Ppk, (W)
100
5% Duty Cycle
10
11V-91V Non-Repetitive
Rectangular Waveform
TJ=25°C Prior to Initial Pulse
10% Duty Cycle
20% Duty Cycle
1
0.01
0.1
1
10
100
1000
Pulse Width, PW, (s)
Fg. 4 - Maximum Surge Power
0571-87006810
www.dowosemi.cn
第 2 页,共 3 页
1N4728A-Z1330A
Electrical Characteristics(TA=25℃ unless otherwise noted)
Part Number
1N4728A
1N4729A
1N4730A
1N4731A
1N4732A
1N4733A
1N4734A
1N4736A
1N4737A
1N4738A
1N4739A
1N4740A
1N4741A
1N4742A
1N4743A
1N4744A
1N4745A
1N4746A
1N4747A
1N4748A
1N4749A
1N4750A
1N4751A
1N4752A
1N4753A
1N4754A
1N4755A
1N4756A
1N4757A
1N4758A
1N4759A
1N4760A
1N4761A
1N4762A
1N4763A
1N4764A
Z1110A
Z1120A
Z1130A
Z1150A
Z1160A
Z1180A
Z1200A
Z1220A
Z1240A
Z1250A
Z1270A
Z1300A
Z1330A
Nominal Zener Voltage
VZ @ IZT
(V)
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.8
7.5
8.2
9.1
10.0
11.0
12.0
13.0
15.0
16.0
18.0
20.0
22.0
24.0
27.0
30.0
33.0
36.0
39.0
43.0
47.0
51.0
56.0
62.0
68.0
75.0
82.0
91.0
100.0
110.0
120.0
130.0
150.0
160.0
180.0
200.0
220.0
240.0
250.0
270.0
300.0
330.0
IZT
(mA)
76.0
69.0
64.0
58.0
53.0
49.0
45.0
37.0
34.0
31.0
28.0
25.0
23.0
21.0
19.0
17.0
15.5
14.0
12.5
11.5
10.5
9.5
8.5
7.5
7.0
6.5
6.0
5.5
5.0
4.5
4.0
3.7
3.3
3.0
2.8
2.5
2.3
2.0
1.9
1.7
1.6
1.4
1.2
1.0
0.9
0.9
0.8
0.8
0.7
Maximum Zener Impedance
ZZT @ IZT
(Ω)
10
10
9.0
9.0
8.0
7.0
5.0
3.5
4.0
4.5
5.0
7.0
8.0
9.0
10
14
16
23
25
35
40
45
50
60
70
80
95
110
125
150
175
200
250
350
450
550
700
1000
1100
1200
1900
1600
1800
2000
2100
2300
2500
ZZK @ IZK
(Ω)
400
400
400
400
500
550
600
700
700
700
700
700
700
700
700
700
700
750
750
750
750
750
1000
1000
1000
1000
1500
1500
1500
2000
2000
2000
2000
3000
3000
3000
4000
4500
5000
6000
6500
7000
9990
8000
8500
9000
9000
9500
9500
IZK
(mA)
1.00
1.00
1.00
1.00
1.00
1.00
1.00
1.00
0.50
0.50
0.50
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
Maximum Reverse
Leakage Current
IR @ VR
(V)
(μA)
100
1.0
100
1.0
50
1.0
10
1.0
10
1.0
10
1.0
10
2.0
5.0
4.0
5.0
5.0
5.0
6.0
0.5
7.0
0.5
7.6
0.1
8.4
0.1
9.1
0.1
9.9
0.1
11.4
0.1
12.2
0.1
13.7
0.1
15.2
0.1
16.7
0.1
18.2
0.1
20.6
0.1
22.8
0.1
25.1
0.1
27.4
0.1
29.7
0.1
32.7
0.1
35.8
0.1
38.8
0.1
42.6
0.1
47.1
0.1
51.7
0.1
56.0
0.1
62.2
0.1
69.2
0.1
76.0
0.1
83.6
0.1
91.2
0.1
98.8
0.1
114.0
0.1
121.6
0.1
136.8
0.1
152.0
0.1
167.2
0.1
182.4
0.1
190.0
0.1
205.0
0.1
228.0
0.1
250.2
Maximum Maximum
DC Zener
Surge
Current
Current
Notes :
(1) The type number listed have a standard tolerance on the nominal zener voltage of ± 5 %
(2) The revese surge current is a non-repetitive, 8.3ms pulse width square wave or equivalent sine-wave superimposed
on IZT per JEDEC method
0571-87006810
www.dowosemi.cn
IZM
(mA)
274
251
232
210
192
177
161
133
121
110
100
91
83
76
69
61
57
50
45
41
38
34
30
27
25
23
22
19
18
16
14
13
12
11
10
9.0
8.6
7.8
7.0
6.4
5.8
5.2
4.7
4.0
3.8
3.6
3.3
3.0
2.7
IRM
(mApk)
1370
1255
1160
1050
960
885
805
660
605
550
500
454
414
380
344
305
285
250
225
205
190
170
150
135
125
115
110
95
90
80
70
65
60
55
50
45
40
37
34
30
28
25
22
18
16
15
13
第 3 页,共 3 页
很抱歉,暂时无法提供与“1N4746A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.38500
- 500+0.25740
- 2500+0.22330
- 5000+0.20350
