Transient Voltage Suppression Diodes
Surface Mount – 1500W > 1.5SMC series
1.5SMC Series
RoHS
Pb e3
Descriptios
Uni-directional
Bi-directional
The 1.5SMC series is designed specifically to protect
sensitive electronic equipment from voltage transients
induced by lightning and other transient voltage events.
Features
Agency Approvals
AGENCY
AGENCY FILE NUMBER
E230531
Maximum Ratings and Thermal Characteristics
(TA=25OC unless otherwise noted)
Parameter
Symbol
Value
Unit
Peak Pulse Power Dissipation at
TA=25ºC by 10/1000µs Waveform
(Fig.2)(Note 1), (Note 2), (Note 5)
PPPM
1500
W
Power Dissipation on Infinite Heat
Sink at TL=50OC
PD
6.5
W
Peak Forward Surge Current, 8.3ms
Single Half Sine Wave (Note 3)
IFSM
200
A
VF
3.5/5.0
V
Maximum Instantaneous Forward
Voltage at 100A for Unidirectional
Only (Note 4)
Operating Temperature Range
TJ
-65 to 150
°C
Storage Temperature Range
TSTG
-65 to 175
°C
Typical Thermal Resistance Junction
to Lead
RθJL
15
°C/W
to Ambient
RθJA
75
°C/W
Notes:
1. Non-repetitive current pulse , per Fig. 4 and derated above TJ (initial) =25OC per Fig. 3.
2. Mounted on copper pad area of 0.31x0.31” (8.0 x 8.0mm) to each terminal.
3. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional
device only, duty cycle=4 per minute maximum.
4. VF < 3.5V for single die parts and VF< 5.0V for stacked-die parts.
5. The PPPM of stacked-die parts is 2000W and please contact littelfuse for the detail
stacked-die parts.
Functional Diagram
• 1500W peak pulse power
capability at 10/1000μs
waveform, repetition rate
(duty cycles):0.01%
• Excellent clamping
capability
• Low incremental surge
resistance
• Typical IR less than 1μA
when VBR min>12V
• For surface mounted
applications to optimize
board space
• Low profile package
• Built-in strain relief
• Typical failure mode is
short from over-specified
voltage or current
• Whisker test is conducted
based on JEDEC
JESD201A per its table 4a
and 4c
• IEC-61000-4-2 ESD
30kV(Air), 30kV (Contact)
• ESD protection of data
lines in accordance with
IEC 61000-4-2
• EFT protection of data
IEC 61000-4-4
• Fast response time:
typically less than 1.0ps
from 0V to BV min
• Glass passivated chip
junction
• High temperature
to reflow soldering
guaranteed: 260°C/40sec
• VBR @ TJ= VBR@25°C
x (1+αT x (TJ - 25))
(αT:Temperature
Coefficient, typical value
is 0.1%)
• Plastic package is
flammability rated V-0 per
Underwriters Laboratories
• Meet MSL level1, per
J-STD-020, LF maximun
peak of 260°C
• Matte tin lead–free plated
• Halogen free and RoHS
compliant
• Pb-free E3 means 2nd
level interconnect is
Pb-free and the terminal
finish material is tin(Sn)
(IPC/JEDEC J-STD609A.01)
Applications
TVS devices are ideal for the protection of I/O Interfaces,
VCC bus and other vulnerable circuits used in Telecom,
Computer, Industrial and Consumer electronic
applications.
Additional Infomarion
Bi-directional
Cathode
Anode
Uni-directional
© 2015 Littelfuse, Inc.
Specifications are subject to change without notice.
Revised: 11/20/15
Datasheet
Resources
Samples
Electrical Characteristics (T =25°C unless otherwise noted)
A
Part
Number
(Uni)
Part
Number
(Bi)
1.5SMC6.8A
1.5SMC7.5A
1.5SMC8.2A
1.5SMC9.1A
1.5SMC10A
1.5SMC11A
1.5SMC12A
1.5SMC13A
1.5SMC15A
1.5SMC16A
1.5SMC18A
1.5SMC20A
1.5SMC22A
1.5SMC24A
1.5SMC27A
1.5SMC30A
1.5SMC33A
1.5SMC36A
1.5SMC39A
1.5SMC43A
1.5SMC47A
1.5SMC51A
1.5SMC56A
1.5SMC62A
1.5SMC68A
1.5SMC75A
1.5SMC82A
1.5SMC91A
1.5SMC100A
1.5SMC110A
1.5SMC120A
1.5SMC130A
1.5SMC150A
1.5SMC160A
1.5SMC170A
1.5SMC180A
1.5SMC200A
1.5SMC220A
1.5SMC250A
1.5SMC300A
1.5SMC350A
1.5SMC400A
1.5SMC440A
1.5SMC480A
1.5SMC510A
1.5SMC530A
1.5SMC540A
1.5SMC550A
1.5SMC6.8CA
1.5SMC7.5CA
1.5SMC8.2CA
1.5SMC9.1CA
1.5SMC10CA
1.5SMC11CA
1.5SMC12CA
1.5SMC13CA
1.5SMC15CA
1.5SMC16CA
1.5SMC18CA
1.5SMC20CA
1.5SMC22CA
1.5SMC24CA
1.5SMC27CA
1.5SMC30CA
1.5SMC33CA
1.5SMC36CA
1.5SMC39CA
1.5SMC43CA
1.5SMC47CA
1.5SMC51CA
1.5SMC56CA
1.5SMC62CA
1.5SMC68CA
1.5SMC75CA
1.5SMC82CA
1.5SMC91CA
1.5SMC100CA
1.5SMC110CA
1.5SMC120CA
1.5SMC130CA
1.5SMC150CA
1.5SMC160CA
1.5SMC170CA
1.5SMC180CA
1.5SMC200CA
1.5SMC220CA
1.5SMC250CA
1.5SMC300CA
1.5SMC350CA
1.5SMC400CA
1.5SMC440CA
1.5SMC480CA
1.5SMC510CA
1.5SMC530CA
1.5SMC540CA
1.5SMC550CA
UNI
BI
Reverse
Stand off
Voltage
VR
(Volts)
6V8A
7V5A
8V2A
9V1A
10A
11A
12A
13A
15A
16A
18A
20A
22A
24A
27A
30A
33A
36A
39A
43A
47A
51A
56A
62A
68A
75A
82A
91A
100A
110A
120A
130A
150A
160A
170A
180A
200A
220A
250A
300A
350A
400A
440A
480A
510A
530A
540A
550A
6V8C
7V5C
8V2C
9V1C
10C
11C
12C
13C
15C
16C
18C
20C
22C
24C
27C
30C
33C
36C
39C
43C
47C
51C
56C
62C
68C
75C
82C
91C
100C
110C
120C
130C
150C
160C
170C
180C
200C
220C
250C
300C
350C
400C
440C
480C
510C
530C
540C
550C
5.80
6.40
7.02
7.78
8.55
9.40
10.20
11.10
12.80
13.60
15.30
17.10
18.80
20.50
23.10
25.60
28.20
30.80
33.30
36.80
40.20
43.60
47.80
53.00
58.10
64.10
70.10
77.80
85.50
94.00
102.00
111.00
128.00
136.00
145.00
154.00
171.00
185.00
214.00
256.00
300.00
342.00
376.00
408.00
434.00
451.00
460.00
468.00
Marking
Breakdown
Voltage VBR
(Volts) @ IT
MIN
MAX
Test
Current
IT
(mA)
6.45
7.13
7.79
8.65
9.50
10.50
11.40
12.40
14.30
15.20
17.10
19.00
20.90
22.80
25.70
28.50
31.40
34.20
37.10
40.90
44.70
48.50
53.20
58.90
64.60
71.30
77.90
86.50
95.00
105.00
114.00
124.00
143.00
152.00
162.00
171.00
190.00
209.00
237.00
285.00
332.00
380.00
418.00
456.00
485.00
503.50
513.00
522.50
7.14
7.88
8.61
9.50
10.50
11.60
12.60
13.70
15.80
16.80
18.90
21.00
23.10
25.20
28.40
31.50
34.70
37.80
41.00
45.20
49.40
53.60
58.80
65.10
71.40
78.80
86.10
95.50
105.00
116.00
126.00
137.00
158.00
168.00
179.00
189.00
210.00
231.00
263.00
315.00
368.00
420.00
462.00
504.00
535.00
556.50
567.00
577.50
10
10
10
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
Maximum Maximum Maximum
Agency
Clamping
Peak
Reverse
Approval
Voltage VC
Pulse
Leakage IR
@ Ipp
Current Ipp
@ VR
(V)
(A)
(µA)
10.5
11.3
12.1
13.4
14.5
15.6
16.7
18.2
21.2
22.5
25.2
27.7
30.6
33.2
37.5
41.4
45.7
49.9
53.9
59.3
64.8
70.1
77.0
85.0
92.0
103.0
113.0
125.0
137.0
152.0
165.0
179.0
207.0
219.0
234.0
246.0
274.0
328.0
344.0
414.0
482.0
548.0
602.0
658.0
698.0
725.0
740.0
760.0
144.8
134.5
125.6
113.4
104.8
97.4
91.0
83.5
71.7
67.6
60.3
54.9
49.7
45.8
40.5
36.7
33.3
30.5
28.2
25.6
23.5
21.7
19.7
17.9
16.5
14.8
13.5
12.2
11.1
10.0
9.2
8.5
7.3
6.9
6.5
6.2
5.5
4.6
4.4
3.7
3.2
2.8
2.5
2.3
2.1
2.1
2.0
2.0
1000
500
200
50
10
5
5
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
For bidirectional type having VR of 10 volts and less, the IR limit is double.
For parts without A , the VBR is ± 10% and Vc is 5% higher than with A parts.
Revised: 11/20/15
I-V Curve Characteristics
Bi-directional
Uni-directional
Ipp
Vc VBR VR
V
IR VF
IT
IT
IR
Vc VBR VR
IR
IT
V
Ipp
Ipp
PPPM
VR
VBR
VC
IR
VF
VR VBR Vc
Peak Pulse Power Dissipation -- Max power dissipation
Stand-off Voltage -- Maximum voltage that can be applied to the TVS without operation
Breakdown Voltage -- Maximum voltage that flows though the TVS at a specified test current (IT)
Clamping Voltage -- Peak voltage measured across the TVS at a specified Ippm (peak impulse current)
Reverse Leakage Current -- Current measured at VR
Forward Voltage Drop for Uni-directional
Ratings and Characteristic Curves (T =25°C unless otherwise noted)
A
Figure 1 - TVS Transients Clamping Waveform
Figure 2 - Peak Pulse Power Rating
100
PPPM-Peak Pulse Power (kW)
Voltage Transients
Voltage or Current
Voltage Across TVS
Current Through TVS
TJ initial = Tamb
1
0.1
0.001
Time
stacked-die, 2kW
at 10x1000µs, 25°C
10
Single die, 1.5kW
at 10x1000µs, 25°C
0.01
0.1
1
10
td-Pulse Width (ms)
continues on next page.
Revised: 11/20/15
Ratings and Characteristic Curves (T =25°C unless otherwise noted) (Continued)
A
Figure 4 - Pulse Waveform
Figure 3 - Peak Pulse Power Derating Curve
150
IPPM- Peak Pulse Current, % IRSM
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
100
80
60
40
50
75
100 125 150
TJ - Initial Junction Temperature (ºC)
Uni-directional V=VR
100
Bi-directional V=VR
1
10
100
2
Transient Thermal Impedance (°C/W)
Cj(pF)
Bi-directional V=0V
1
50
10/1000µsec. Waveform
as defined by R.E.A
td
1.0
4.0
100
10
1
0.1
0.01
0.001
1000
0.01
0.1
VBR - Reverse Breakdown Voltage(V)
1
10
100
1000
TP - Pulse Duration (s)
Figure 7 - Maximum Non-Repetitive Peak Forward
Surge Current Uni-Directional Only
Figure 8 - Peak Forward Voltage Drop vs Peak Forward
Current (Typical Values)
100.0
200
Single die
180
IF- Peak Forward Current(A)
IFSM - Peak Forward Surge Current (A)
2.0
Figure 6 - Typical Transient Thermal Impedance
Uni-directional V=0V
10
Half Value
IPPM IPPM
t-Time (ms)
100000
1000
TJ=25°C
Pulse Width(td) is defined
as the point where the peak
current decays to 50% of IPPM
Peak Value
IPPM
100
175
Figure 5 - Typical Junction Capacitance
10000
tr=10µsec
160
140
120
100
80
60
40
Stacked-die
10.0
1.0
10
Number of Cycles at 60 Hz
100
0.1
0.0
1.0
2.0
3.0
4.0
5.0
6.0
7.0
8.0
9.0
VF-Peak Forward Voltage(V)
Revised: 11/20/15
Soldering Parameters
Lead–free
assembly
Pre Heat
- Temperature Min (Ts(min))
150°C
- Temperature Max (Ts(max))
200°C
- Time (min to max) (ts)
60 – 180 secs
Ramp-up
TL
Average ramp up rate (Liquidus Temp (TA)
to peak
3°C/second max
TS(max) to TA - Ramp-up Rate
3°C/second max
Reflow
- Temperature (TA) (Liquidus)
217°C
60 – 150 seconds
Peak Temperature (TP)
260
Time within 5°C of actual peak
Temperature (tp)
20 – 40 seconds
Ramp-down Rate
6°C/second max
Time 25°C to peak Temperature (TP)
8 minutes Max.
Do not exceed
260°C
+0/-5
tp
TP
Temperature (T)
Reflow Condition
tL
Ts(max)
Ramp-down
Ts(min)
ts
Preheat
25˚C
t 25˚C to Peak
Time (t)
°C
Physical Specifications
Critical Zone
TL to TP
Environmental Specifications
High Temp. Storage
JESD22-A103
HTRB
JESD22-A108
Weight
0.007 ounce, 0.21 grams
Temperature Cycling
JESD22-A104
Case
JEDEC DO214AB. Molded plastic body
over glass passivated junction
MSL
JEDEC-J-STD-020, Level 1
Polarity
Color band denotes positive end
(cathode) except Bidirectional.
H3TRB
JESD22-A101
Terminal
Matte Tin-plated leads, Solderable per
JESD22-B102
RSH
JESD22-A111
Dimensions
DO-214AB (SMC J-Bend)
Cathode Band
(for Uni-directional products only)
Dimensions
A
C
A
B
H
D
F
E
G
J
K
L
I
Solder Pads
(all dimensions in mm)
Revised: 11/20/15
Inches
Millimeters
Min
Max
Min
Max
0.114
0.126
2.900
3.200
B
0.260
0.280
6.600
7.110
C
0.220
0.245
5.590
6.220
D
0.079
0.103
2.060
2.620
E
0.030
0.060
0.760
1.520
F
0.008
0.203
G
0.305
0.320
7.750
8.130
H
0.006
0.012
0.152
0.305
I
0.129
3.300
J
0.094
2.400
K
0.165
4.200
L
0.094
2.400
Part Numbering System
Part Marking System
1.5SMC XXX C A
Cathode Band
F
5% VBR VOLTAGE TOLERANCE
XXX
BI-DIRECTIONAL
YMXXX
VBR VOLTAGE
SERIES
Littelfuse Logo
Marking Code
Trace Code Marking
Y:Year Code
M: Month Code
XXX: Lot Code
Packaging
Part number
Component
Package
1.5SMCxxxXX
DO-214AB
Packaging
Option
Quantity
3000
Tape & Reel - 16mm tape/13” reel
Packaging
Specification
EIA STD RS-481
Tape and Reel Specification
0.157
(4.0)
0.63
(16.0)
Cathode
0.315
(8.0)
0.059 DIA
(1.5)
Cover tape
13.0 (330)
0.80 (20.2)
Arbor Hole Dia.
0.65
(16.4)
Dimensions are in inches
(and millimeters).
Direction of Feed
Revised: 11/20/15
很抱歉,暂时无法提供与“1.5SMC400A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.99574
- 50+1.58750
- 150+1.41254
- 500+1.09923
- 3000+1.00203
- 6000+0.94371
