160AR5K271M0809G13T
160AR5K271M0809G13T
    APAQ(钰邦)
    插件,D8xL9mm
    270UF ±20% 16V
160AR5K271M0809G13T 数据手册
CUSTOMER: Doc No: MES007328 Rev: A0 RoHS Comp. 承認書 Halogen Free APPROVAL SHEET Specifications description : APAQ P/N : Customer P/N Date AR5K G13T Series Package Type: Taping Type : Approved by Checked by 陳明宗 梁名琮 APAQ R&D 2020.07.10 APPROVAL Approved by Customer (Signing or stamping here) : Approved Date : 鈺邦科技股份有限公司 APAQ TECHNOLOGY CO., LTD 竹南科學園區 苗栗縣竹南鎮科東三路 2&6 號 4 樓 4F., No.2 & 6, Kedong 3rd Rd., Chunan Science Park, Miaoli County 350, Taiwan ,( R.O.C.) PAGE 1 OF 20 AP-CON AR5K SERIES SPECIFICATION 1. Application This specification shall be specified to conductive polymer aluminum solid electrolytic capacitors of AR5K series. 2. Composition of part number 160 AR5K 271 M 0809 Rated voltage Series code Capacitance Cap tolerance Size code G13T Special code 2.1 Rated voltage code Table 1 Rated voltage and surge voltage Rated voltage code Rated voltage (V) Surge voltage (V) 2R5 2.5 2.9 4R0 4 4.6 6R3 6.3 7.2 100 10 11.5 160 16 18.4 2.2 Capacitance code Table 2 Rated capacitance Capacitance code Capacitance (uF) 3R3 3.3 100 10 821 820 122 1200 2.3 Capacitance tolerance code Table 3 Capacitance tolerance Cap tolerance code Cap tolerance M 20% THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:呂姿儀 CHECKED BY:梁名琮 鈺邦科技股份有限公司 TITLE:AP-CON AR5K SERIES SPECIFICATION DOCUMENT NO. APAQ TECHNOLOGY CO., LTD APPROVED BY:陳明宗 REV MES007328 A0 PAGE 2 OF 20 2.4 Size code Table 4 Dimension of radial type capacitors Size code Diameter (mm) Case length (mm) 0509 5.0 9.0 0606 6.3 6.0 0609 6.3 9.0 0809 8.0 9.0 0812 8.0 12.0 1012 10.0 12.0 2.5 Special code Special code Remark G13 Black case, white ink T Taping Type 3. Rating 3.1 Category temperature range -55 to +105 oC 3.2 Surge voltage Rated voltage * 1.15 3.3 Rated ripple current Rated ripple current shall be in accordance with standard ratings list. These current are rms values of sine wave of 100kHz at 105 oC. THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:呂姿儀 CHECKED BY:梁名琮 鈺邦科技股份有限公司 TITLE:AP-CON AR5K SERIES SPECIFICATION DOCUMENT NO. APAQ TECHNOLOGY CO., LTD APPROVED BY:陳明宗 REV MES007328 A0 PAGE 3 OF 20 3.4 Standard ratings Table 5 Standard ratings Leakage WV /Vdc Cap Size (SV) (μF) Code 2.5 current tan (μA) ESR Rated ripple current (mΩmax/20℃, (mA rms/105℃ 100k to 300kHz) 100kHz) Part No. 820 0609 500 0.10 7 5,000 2R5AR5K821M0609G13T 560 0609 705 0.10 8 4,700 6R3AR5K561M0609G13T 16 100 0609 320 0.10 25 2,820 160AR5K101M0609G13T (18.4) 270 0809 864 0.10 10 5,000 160AR5K271M0809G13T (2.9) 6.3 (7.2) THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:呂姿儀 CHECKED BY:梁名琮 鈺邦科技股份有限公司 TITLE:AP-CON AR5K SERIES SPECIFICATION DOCUMENT NO. APAQ TECHNOLOGY CO., LTD APPROVED BY:陳明宗 REV MES007328 A0 PAGE 4 OF 20 4. Construction and dimensions. 4.1 Construction Radial type capacitors shall be enclosed wound element, where anode and cathode foils with lead wire termination shall be winded together with separator, with conductive polymer electrolyte in a plastic coated aluminum case and sealed up tightly with rubber. Figure 1 Cross-section view Table 6 Compositions Anode foil Construction Materials Aluminum 1 Element Cathode foil Aluminum Separator Synthetic fiber 2 Seal Rubber 3 Aluminum tab Aluminum 4 Lead wire Tinned Lead 5 Case Plastic coated aluminum 4.2 Outer dimensions Outer dimensions shall be in accordance with Figure 2, and the dimensions in each size shall be specified on Table 7. Figure 2 Dimension THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:呂姿儀 CHECKED BY:梁名琮 鈺邦科技股份有限公司 TITLE:AP-CON AR5K SERIES SPECIFICATION DOCUMENT NO. APAQ TECHNOLOGY CO., LTD APPROVED BY:陳明宗 REV MES007328 A0 PAGE 5 OF 20 Table 7 Dimension Size code D0.5 (mm) Lmax (mm) d0.05 (mm) F0.5 (mm) 0509 5.0 9.0 0.5 2 0606 6.3 6.0 0.45 2.5 0609 6.3 9.0 0.6 2.5 0809 8.0 9.0 0.6 3.5 0812 8.0 12.0 0.6 3.5 5. Marking The following items shall be marked on each capacitor, as showed in Figure 3. (1) Polarity (2) Series (3) Year code: Y-2018,Z-2019,A-2020 (4) Production period code (5) Manufacturer's identification mark (6) Rated capacitance (7) Rated voltage (8) The color of marking ink is White - + Figure 3 Marking 6.Specification for automatic insertion 6.1 Tape Adhesion The adhesion of the hold-down tape to the carrier tape shall be a minimum 1N. 6.2 Component Adhesion The component, when tested as shown Figure 4 applying the force of 5N, shall not be removal the tape. THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:呂姿儀 CHECKED BY:梁名琮 鈺邦科技股份有限公司 TITLE:AP-CON AR5K SERIES SPECIFICATION DOCUMENT NO. APAQ TECHNOLOGY CO., LTD APPROVED BY:陳明宗 REV MES007328 A0 PAGE 6 OF 20 Figure 4 7. The electrical and mechanical performance and testing method 7.1 Measurement condition Each measurement shall be conducted at a temperature of 15 to 35 oC, and relative humidity of 45 to 85%. Furthermore, these measurements shall be preferably conducted at a temperature of 202 oC, and relative humidity of 60 to 70%, while the capacitors shall be kept enough time in the measuring temperature. 7.2 Voltage treatment If leakage current is doubtful, measure it after performing voltage treatment, which shall contain the following steps: (1) Applied DC rated voltage to the capacitors for 60 minutes at 1052 oC. (2) Cooled down to room temperature with applying voltage. (3) Discharged through a resistor of approximately 1/V. 7.3 Electrical performance 7.3.1 Tolerance on rated capacitance Rated capacitance shall meet within -20% to +20% (M) tolerance against the rated capacitance measured at 120Hz10% at 202 oC. 7.3.2 Leakage current DC rated voltage shall be applied between anode and cathode lead wire terminations of a capacitor through 1k protective resistance, and the leakage current shall be less than or equal to the value listed in table 5 after 2 minutes with the voltage reaching the rated value at 202 oC.If the value is doubtful, measure the leakage current after performing voltage treatment as described in section 7.2. 7.3.3 Tangent of loss angle (tan) Tan values shall be less than or equal to 0.10 measured at 120Hz10% at 202 oC. 7.3.4 Equivalent Series Resistance (ESR) ESR at 100kHz measured under the following conditions listed in Table 8 shall be less than or equal to the value in Table 5. THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:呂姿儀 CHECKED BY:梁名琮 鈺邦科技股份有限公司 TITLE:AP-CON AR5K SERIES SPECIFICATION DOCUMENT NO. APAQ TECHNOLOGY CO., LTD APPROVED BY:陳明宗 REV MES007328 A0 PAGE 7 OF 20 Table 8 Measurement requirement of ESR Equipment Agilent Technology 4263B or equivalent Test Fixture Agilent Technology 16047E or equivalent Compensation Short and Open compensation would be required. Short correction is performed using the shorting plate made of 0.5 thickness copper plate with gold coating. Signal Level 500mV Frequency 100kHz Measurement Point Point of lead wire within 1mm form the body 7.3.5 Impedance at high and low temperature Impedance at 100kHz at -553 oC or 1052 oC shall meet the values listed in Table 9. Table 9 Impedance at low or high temperature Impedance ratio Performance Z(-55 oC)/Z(+20 oC)  1.25 Z(105 oC)/Z(+20 oC)  1.25 7.4 Mechanical performance 7.4.1 Pull strength of lead wire terminations With the body of a capacitor fixed, the load listed in Table 10 shall be applied to the lead wire termination in its draw out direction, gradually up to the specified value and held for 101 seconds. After this test, that capacitor shall not appear any change defective in use. Table 10 Pull strength load of lead wire terminations Lead wire diameter (mm) Load strength (N) Load strength (kgf) 0.35
160AR5K271M0809G13T 价格&库存
很抱歉,暂时无法提供与“160AR5K271M0809G13T”相匹配的价格&库存,您可以联系我们找货
