160AVEA271M0610
160AVEA271M0610
    APAQ(钰邦)
    SMD,D6.3xL9.7mm
    270UF ±20% 16V
160AVEA271M0610 数据手册
客戶名稱: Doc No: MES001899 Rev: A0 CUSTOMER: RoHS Comp. 承認書 Halogen Free APPROVAL SHEET CAP PL 270uF 16V ψ6.3*10.0mm 規格敘述 : 鈺邦料號 : 客戶料號 : Date SMD ±20%, 2000hrs 160AVEA271M0610 Approved by Checked by APAQ R&D 2015.12.02 APPROVAL Approved by Customer (Signing or stamping here) : Approved Date : 鈺邦科技股份有限公司 APAQ TECHNOLOGY CO., LTD 竹南科學園區 苗栗縣竹南鎮科東三路 2&6 號 4 樓 4F., No.2 & 6, Kedong 3rd Rd., Chunan Science Park, Miaoli County 350, Taiwan ,( R.O.C.) PAGE 1 OF 16 AP-CON AVEA SERIES SPECIFICATION 1. Application This specification shall be specified to conductive polymer aluminum solid electrolytic capacitors of AVEA series. 2. Composition of part number 2R5 AVEA 331 M 0610 Rated voltage Series code Capacitance Cap tolerance Size code 2.1 Rated voltage code Table 1 Rated voltage and surge voltage Rated voltage code Rated voltage (V) Surge voltage (V) 2R5 2.5 2.9 4R0 4 4.6 6R3 6.3 7.2 160 16 18.4 250 25 25.0 2.2 Capacitance code Table 2 Rated capacitance Capacitance code Capacitance (uF) 100 10 270 27 101 100 471 470 122 1200 2.3 Capacitance tolerance code Table 3 Capacitance tolerance Cap tolerance code Cap tolerance M 20% 2.4 Size code Table 4 Dimension of radial type capacitors Size code 0610 Diameter (mm) Case length (mm) 6.3 10.0 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY: 鍾佳玲 TITLE:AP-CON AVEA SERIES SPECIFICATION APAQ TECHNOLOGY CO., LTD CHECKED BY:陳明宗 DOCUMENT NO. APPROVED BY:劉士山 REV MES001899 A0 PAGE 2 OF 17 3. Rating 3.1 Category temperature range -55 to +105 ℃ 3.2 Surge voltage Rated voltage x 1.15 3.3 Rated ripple current Rated ripple current shall be in accordance with standard ratings list. These current are rms values for sine wave of 100kHz at 105 ℃. 3.4 Standard ratings Table 5 Standard ratings WV/Vdc Cap Size (SV) (μF) Code 270 0610 Leakage Current tanδ (μA) ESR Rated Ripple Current (mΩmax/20℃, (mArms/ 105℃ 100k to 300kHz) /100kHz) 16 3,500 Part No. 16 (18.4) 864 0.12 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY: 鍾佳玲 TITLE:AP-CON AVEA SERIES SPECIFICATION 160AVEA271M0610 APAQ TECHNOLOGY CO., LTD CHECKED BY:陳明宗 DOCUMENT NO. APPROVED BY:劉士山 REV MES001899 A0 PAGE 3 OF 17 4. Construction and dimensions. 4.1 Construction Vertical type capacitors shall be enclosed wound element, where anode and cathode foils with lead wire termination shall be winded together with separator, with conductive polymer electrolyte in a plastic coated aluminum case and sealed up tightly with rubber. 5 1 2 3 6 4 Fig. 1 Cross-section view Table 6 Construction Compositions Anode foil 1 Element Materials Aluminum Cathode foil Aluminum Separator Synthetic fiber Fixing tape Adhesive tape 2 Seal Rubber 3 Aluminum tab Aluminum 4 Lead wire Tinned Lead 5 Case Plastic coated aluminum 6 Base plate Resin 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY: 鍾佳玲 TITLE:AP-CON AVEA SERIES SPECIFICATION APAQ TECHNOLOGY CO., LTD CHECKED BY:陳明宗 DOCUMENT NO. APPROVED BY:劉士山 REV MES001899 A0 PAGE 4 OF 17 4.2 Outer dimensions Outer dimensions shall be in accordance with Fig. 2, and the dimensions in each size shall be specified on Table 7. Fig. 2 Dimension Table 7 Dimension Size D±0.5 L±0.3 E W0.2 H0.2 C0.2 R P0.2 code (mm) (mm) (mm) (mm) (mm) (mm) (mm) (mm) 0610 6.3 9.7 0.00~0.20 6.6 6.6 7.3 0.6~0.9 2.1 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY: 鍾佳玲 TITLE:AP-CON AVEA SERIES SPECIFICATION APAQ TECHNOLOGY CO., LTD CHECKED BY:陳明宗 DOCUMENT NO. APPROVED BY:劉士山 REV MES001899 A0 PAGE 5 OF 17 5. Marking The following items shall be marked on each capacitor, as showed in Fig. 3. (1) Polarity (2) Series (3) Year code: U-2014(WX),V-2015(WX) (4) Production period code (5) Manufacturer's identification mark (6) Rated capacitance (7) Rated voltage (8) The color of marking ink is red (-) (+) Figure 3 Marking 6. Reflow soldering Soldering condition (temperature and time) should be within the following ranges. Figure 4 Reflow profile Table 8 Recommended condition 260℃ Peak temperature (max) 220℃ over time (max) 90sec 230℃ over time (max) 60sec Reflow number Only 1 time 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY: 鍾佳玲 TITLE:AP-CON AVEA SERIES SPECIFICATION APAQ TECHNOLOGY CO., LTD CHECKED BY:陳明宗 DOCUMENT NO. APPROVED BY:劉士山 REV MES001899 A0 PAGE 6 OF 17 7. Soldering pad dimensions c b a b Figure 5 Soldering pad Table 9 Recommended pad dimensions Size code a b C 0610 2.1 3.5 1.6 8. Taping packing and label marking 8.1 Carrier tape dimensions t E F B W P A T Fig. 6 Carrier tape Table 10 Carrier tape dimensions Size code W0.3 (mm) A0.2 (mm) B0.2 (mm) F0.1 (mm) E0.1 (mm) P0.1 (mm) T0.2 (mm) t0.1 (mm) 0610 16.0 7.0 7.0 7.5 1.75 12.0 10.0 0.4 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY: 鍾佳玲 TITLE:AP-CON AVEA SERIES SPECIFICATION APAQ TECHNOLOGY CO., LTD CHECKED BY:陳明宗 DOCUMENT NO. APPROVED BY:劉士山 REV MES001899 A0 PAGE 7 OF 17 8.2 Reel dimensions W C A B Fig. 7 Reel Table 11 Reel dimensions Size code 0610 A ±2 B ±0.5 (mm) 381.0 (mm) C0.5 (mm) W0.8 (mm) 100 13.0 16.5 8.3 Taping method and polarity Direction of feed End Start No Components Components Leader No Components 160mm Min 100mm Min 400mm Min Fig. 8 Taping method and polarity 8.4 Label Marking The label specified as follows shall be put on the side of reel. (1) Part No. (2) Quantity. (750pcs / reel) (3) Lot No. 8.5 Dimension of outer carton box 750pcs capacitors were packed in a taping reel, 6 reels were packed in a outer shipping carton box (W400*D165*H400mm), 4.5kpcs capacitors in a outer carton box. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY: 鍾佳玲 TITLE:AP-CON AVEA SERIES SPECIFICATION APAQ TECHNOLOGY CO., LTD CHECKED BY:陳明宗 DOCUMENT NO. APPROVED BY:劉士山 REV MES001899 A0 PAGE 8 OF 17 9. The electrical and mechanical performance and testing method 9.1 Measurement condition Each measurement shall be conducted at a temperature of 15 to 35℃, and relative humidity of 45 to 85%. Furthermore, these measurements shall be preferably conducted at a temperature of 20±2℃, and relative humidity of 60 to 70%, while the capacitors shall be kept enough time in the measuring temperature. 9.2 Voltage treatment If leakage current is doubtful, measure it after performing voltage treatment, which shall contain the following steps: (1) Applied DC rated voltage to the capacitors for 60 minutes at 1052℃. (2) Cooled down to room temperature with applying voltage. (3) Discharged through a resistor of approximately 1/V. 9.3 Electrical performance 9.3.1 Tolerance on rated capacitance Rated capacitance shall meet within -20% to +20% (M) tolerance against the rated capacitance measured at 120Hz10% at 202℃. 9.3.2 Leakage current DC rated voltage shall be applied between anode and cathode lead wire terminations of a capacitor through 1k protective resistance, and the leakage current shall be less than or equal to the value listed in table 5 after 2 minutes with the voltage reaching the rated value at 202℃. If the value is doubtful, measure the leakage current after performing voltage treatment as described in section 6.2. 9.3.3 Tangent of loss angle (tan) Tan values shall be less than or equal to 0.12 measured at 120Hz10% at 202℃. 9.3.4 Equivalent Series Resistance (ESR) ESR at 100kHz measured under the following conditions listed in Table 12 shall be less than or equal to the value in Table 5. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY: 鍾佳玲 TITLE:AP-CON AVEA SERIES SPECIFICATION APAQ TECHNOLOGY CO., LTD CHECKED BY:陳明宗 DOCUMENT NO. APPROVED BY:劉士山 REV MES001899 A0 PAGE 9 OF 17 Table 12 Measurement requirement of ESR Equipment Agilent Technology 4263B or equivalent Test Fixture Agilent Technology 16047E or equivalent Compensation Short and Open compensation would be required. Short correction is performed using the shorting plate made of 0.5 thickness copper plate with gold coating. Signal Level 500mV Frequency 100kHz Measurement Point Point of lead wire within 1mm form the body 9.3.5 Impedance at high and low temperature Impedance at 100kHz at -553℃or 1052℃ shall meet the values listed in Table 13. Table 13 Impedance at low or high temperature Impedance ratio Performance Z(-55oC)/Z(+20oC)  1.25 Z(105oC)/Z(+20oC)  1.25 9.4 Mechanical performance 9.4.1 Adhesion by soldering A force of 5N shall be applied for 10 seconds to the capacitor, which was mounted on a print circuit board, in the perpendicular direction to the seal side of the capacitor. After this test, the soldered terminals shall not be damaged. 9.4.2 Vibration Vibration cycle should vary from 10 to 55Hz with total amplitude of 1.5mm and return to 10Hz in about 1 minute. Vibration applied to a capacitor should be three directions, which each perpendicular to the other two as longitudinal axis of capacitor set as z axis, and last for 2 hours in each direction. During this test, measured electrical value shall be stabilized when that capacitor is measured 5 times within 30 minutes before completion of test, and the appearance shall not appear any remarkable abnormality. Capacitance change shall be within ±10% of the initial measured value. 9.4.3 Solder ability The lead surface shall be immersed for 20.5 seconds in the flux of ethanol or isopropyl alcohol solution (252%) of colophonium. Then that lead surface shall be immersed to a solder (H60A, H60S or H63A) of 2355℃ and up to the point 1.5 to 2.0mm from the body and kept for 20.5 seconds, and pulling it out. After this test, solder shall cover at least 3/4 of the lead surface immersed. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY: 鍾佳玲 TITLE:AP-CON AVEA SERIES SPECIFICATION APAQ TECHNOLOGY CO., LTD CHECKED BY:陳明宗 DOCUMENT NO. APPROVED BY:劉士山 REV MES001899 A0 PAGE 10 OF 17 9.4.4 Soldering heat After the capacitors are soldered by the recommended soldering conditions below, the tests of the item Humidity resistance and Load life shall be conducted. After this test, the capacitors shall satisfy their test criteria. 9.5 Environmental performance 9.5.1 Damp heat, steady state A capacitor shall be subjected to a temperature of 602℃and relative humidity of 90 to 95% without voltage applied for a period of 1000+48/-0 hours. Then that capacitor shall be taken out from the above condition to a temperature of 20℃ and it shall meet the characteristics in Table 14. Table 14 Damp heat performance Characteristics Performance Appearance No significant damage Capacitance change  20% of the initial value tan ESR  150% of the initial specified value Leakage current  the initial specified value  150% of the initial specified value 9.5.2 Endurance A capacitor shall be subjected to a temperature of 105±2℃ with test voltage applied for a period of 2,000+72/-0 hours and take out from the above condition to a temperature of 20℃. After this test, that capacitor shall meet the characteristics in Table 15. Besides, the applied voltage shall increase up from 0V to test voltage step by step (maximum 5 minutes), and the impedance of the source shall be equal to about 3/V. Table 15 Endurance performance Characteristics Performance Appearance No significant damage Capacitance change  20% of the initial value tan  150% of the initial specified value ESR  150% of the initial specified value Leakage current  the initial specified value 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY: 鍾佳玲 TITLE:AP-CON AVEA SERIES SPECIFICATION APAQ TECHNOLOGY CO., LTD CHECKED BY:陳明宗 DOCUMENT NO. APPROVED BY:劉士山 REV MES001899 A0 PAGE 11 OF 17 9.5.3 Surge voltage The following specifications in Table 16 shall be satisfied when the capacitors are restored to +20℃ after the surge voltage is applied at a cycle of 360 seconds which consists charge for 305 seconds through a protective resistor of 1k and discharge for 330 seconds, for 1000 cycles at 1052℃. Table 16 Surge voltage performance Characteristics Performance Appearance No significant damage Capacitance change  20% of the initial value tan ESR 150% of the initial specified value Leakage current  the initial specified value  150% of the initial specified value Fig. 9 Surge voltage circuit 10. Instructions of Capacitors 10.1 Cautions on use of Capacitor 10.1.1 Polarity Solid electrolytic capacitors are polarized capacitors. Use capacitors after verifying their positive and negative polarities. If these capacitors are installed in the reverse polarity, its life may shorten because of increasing leakage current or short circuit. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY: 鍾佳玲 TITLE:AP-CON AVEA SERIES SPECIFICATION APAQ TECHNOLOGY CO., LTD CHECKED BY:陳明宗 DOCUMENT NO. APPROVED BY:劉士山 REV MES001899 A0 PAGE 12 OF 17 10.1.2 Types of circuits in which capacitors are prohibited from being used AVEA series may be heated by soldering to increase in its leakage current slightly. This may have some influence on the characteristics capacitors in the following circuits. (1) Time constant circuit (2) Coupling circuit (3) High impedance voltage holding circuit (4) Connection of two or more capacitors in series for higher withstand voltage. 10.1.3 Over voltage If AVEA series is applied a voltage higher than the rated voltage for an instantaneous period, it may be defected due to short circuit. Note that the voltage over the rated voltage must not be applied to capacitors. 10.1.4 Repeat of rapid charging and discharging If AVEA series is used in a rapid charging and discharging circuit or receive the flow of excess rush current, its life may shorten by large leakage current or short circuit. The charging and discharging current through AVEA series should be less than 10A. 10.1.5 Reflow soldering High soldering temperature and long soldering time will affect the characteristics of the capacitors. Use reflow soldering condition within the recommended range. Also, the temperature varies with the location and population of the components, the material and the thickness of printed circuit board. Verify temperature profiles prior to actual production run. 10.1.6 Use of capacitors for industrial equipment When capacitors are used for industrial equipment, the circuits should be designed to have sufficient margins in the ratings of capacitors including capacitance and impedance. Without sufficient margins in the characteristics, the reliability of the capacitors may be reduced by their shorter life. Always contact us if you want to use capacitors for equipment affecting human lives such as space, aviation, atomic power, and medical devices. Never use capacitors for the used without our prior approval. 10.2 Notes on circuit designs for capacitors 10.2.1 Rating and performance Use capacitors within the rating and performance ranges defined in the brochures and delivery specification of capacitors after checking the operating and installation environments. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY: 鍾佳玲 TITLE:AP-CON AVEA SERIES SPECIFICATION APAQ TECHNOLOGY CO., LTD CHECKED BY:陳明宗 DOCUMENT NO. APPROVED BY:劉士山 REV MES001899 A0 PAGE 13 OF 17 10.2.2 Operating temperature If AVEA series is used at a temperature higher than the upper specified temperature (105oC), its life may be remarkably shortened or the leakage current may increase to cause defective. 10.2.3 Ripple current Never make current larger than the rated ripple current through AVEA series. If excess ripple current flows through AVEA series, internal heat may be generated largely to make its life shortened or cause it to be defected due to short circuit. 10.2.4 Leakage current Depending on the reflow soldering conditions, the leakage current of AVEA series may increase slightly. The application of DC voltage enables the capacitors to be repaired by itself. This leads the leakage current to be smaller gradually. The leakage current can be reduced fast if the DC voltage, which is less than the rating voltage, is applied at the temperature close to the upper specified temperature. 10.2.5 Applied voltage Do not apply voltages exceeding the full rated voltage. If such voltage is applied, it may cause short circuit even though it is just a moment. (1) Sum of DC voltage and the peak of ripple voltage AC voltage shall not exceed the rated voltage or category voltage. (2) The sum of the DC voltage plus the negative peak AC voltage shall not allow reverse voltage. (3) Do not apply reverse voltage. (4) For 25V products, the applied voltage shall follow the following figure as the temperature is higher than 85℃。 10.2.6 Failure mode AVEA series contains a conductive polymer as material of cathode electrode. Therefore, like other solid electrolyte capacitors, the life ends mostly due to random failure mode, mainly short circuit. If a current continuously flow through the capacitor due to short circuit, the capacitor would be overheated higher than 300 oC and then aluminum case of the capacitor would be removed by increasing internal pressure due to the vaporization of materials. 10.2.7 Insulation (1) Plastic coated case of capacitors is not secured to insulate. Do not use capacitors in areas requiring insulation. (2) Isolate the case of AVEA series from the positive and negative terminals and adjacent circuit patterns. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY: 鍾佳玲 TITLE:AP-CON AVEA SERIES SPECIFICATION APAQ TECHNOLOGY CO., LTD CHECKED BY:陳明宗 DOCUMENT NO. APPROVED BY:劉士山 REV MES001899 A0 PAGE 14 OF 17 10.2.8 Design of printed circuit board Take note on the subjects when capacitors are installed on printed circuit boards: (1) For surface mount capacitors, design the copper pads/lands of a printed circuit board according to the catalog or product specifications. (2) Do not place heating components on boards to be close to capacitors or in the backside of them. 10.2.9 Parallel connection If AVEA series is connected with another type of a capacitor in parallel, larger ripple current may flow through one of capacitors. Take the current balance among them into account in circuit designs. 10.2.10 Using temperature and frequency The electric characteristics of capacitors depend on the variations of the ambient temperature and frequency. Check the variations in designing circuits. 10.3 Notes on installation of capacitors 10.3.1 Notes on pre-installation of capacitors (1) Do not reuse capacitors installed in a unit with the power supply turned on for another unit. No used capacitors shall be reused excluding those removed to measure their electric characteristics in periodical inspection. (2) If AVEA series stored for a long period may often increase in its leakage current, connect a resistor of approximately 1k to the capacitors for voltage treatment. 10.3.2 Notes at installation of capacitors (1) Install capacitors in a unit after confirming that their ratings (rated capacitance and rated voltages) meet the conditions of the unit. (2) Install capacitors in the correct polarities. (3) Take care not to drop capacitors on floors. Do not use capacitors dropped on floors. (4) Do not deform capacitors to install them in units. (5) Note capacitors may be damaged by mechanical shocks caused by the vacuum head, component checker or centering operation of an automatic mounting machine. (6) Do not dip the body of a capacitor into the solder bath. (7) Do not solder capacitors more than once by reflow. Consult us for reflow-soldering them twice over. (8) Do not apply mechanical stress to the capacitor after soldering to the printed circuit board. (9) Do not use adhesives and coating materials containing halogenated solvents. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY: 鍾佳玲 TITLE:AP-CON AVEA SERIES SPECIFICATION APAQ TECHNOLOGY CO., LTD CHECKED BY:陳明宗 DOCUMENT NO. APPROVED BY:劉士山 REV MES001899 A0 PAGE 15 OF 17 10.4 Notes on use of capacitors in unit (1) Never make your fingers contact with the capacitor terminals. (2) Do not make capacitor terminals to be in contact with each other through a conductor. Do not put conductive liquid such as acid and alkali solutions on capacitors. (3) Confirm that the unit including capacitors is placed in proper conditions. Do not place the unit in the following areas: (a) Area in which they are directly exposed to water, brine, or oil or in condensation status. (b) Area filled with poisonous gases including hydrogen sulfide, sulfurous acid, nitrous acid, chlorine and ammonia. (c) Area to which ultraviolet and/or radial rays are radiated (4) Provide aging for a unit containing capacitors within the period defined for them. (5) It is recommended to use a unit containing capacitors in the normal temperature range of 15℃ to 35℃ and the normal humidity range of 75% or less. 10.5 Action at emergency (1) At the occurrence of short circuit in AVEA series, some heat is generated from it if the short-current rather small. If the short current exceeds the above value, the capacitors are heated excessively. If so, turn off the power of the unit without your face and hands being close to the capacitors. (2) If you should expose your eyes to smoke from the capacitor or inhale it, immediately flush the open eyes and gargle with water. 10.6 Storage (1) Store capacitors in an area in the temperature range between 15 oC to 35 oC and the relative humidity of 75% or less without direct sunshine. In addition, store them in the package states if possible. (2)SMD products are sealed in a special laminated aluminum bag. Use all capacitors once the bag is opened. Return unused capacitors to the bag, and seal it with a zipper. After the bag is opened, please use all capacitors within 1 month. (3) Store capacitors in an airtight bag to keep the terminals in good condition. (4)Store in a location where the capacitor is not exposed to ozone, ultraviolet radiation, or other radiation. (5)Never store capacitors in any area in which they are directly exposed to water, brine, or oil or in condensation status. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY: 鍾佳玲 TITLE:AP-CON AVEA SERIES SPECIFICATION APAQ TECHNOLOGY CO., LTD CHECKED BY:陳明宗 DOCUMENT NO. APPROVED BY:劉士山 REV MES001899 A0 PAGE 16 OF 17 10.7 Exhaustion of capacitors Capacitors are composed of organic compounds, resins and metals. Request an industrial dispose company to dispose of used Capacitors. 11. Export trade control ordinance Item 41-4 in Section 2 of Appendix Table 1 (Section 49 in Chapter 1 of MITI' s Ordinance) and Item 7 in Section 7 of Appendix Table 1 (Section 6 in Chapter 6 of MITI' s Ordinance) state export regulations on pulse use capacitors (750V of higher) and high voltage use capacitors (5,000V or higher). However, aluminum electrolytic capacitors are less than 750V in their voltage range, so that the regulations do not apply to the aluminum electrolytic capacitors. 鈺邦科技股份有限公司 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY: 鍾佳玲 TITLE:AP-CON AVEA SERIES SPECIFICATION APAQ TECHNOLOGY CO., LTD CHECKED BY:陳明宗 DOCUMENT NO. APPROVED BY:劉士山 REV MES001899 A0 PAGE 17 OF 17
160AVEA271M0610 价格&库存
很抱歉,暂时无法提供与“160AVEA271M0610”相匹配的价格&库存,您可以联系我们找货
