ACAS2R0S221E09Y
ACAS2R0S221E09Y
    APAQ(钰邦)
    SMD,4.3x7.3mm
    220UF -35%~+10% 2V
ACAS2R0S221E09Y 数据手册
Doc No: MES002787 Rev: A0 CUSTOMER: RoHS Comp. 承認書 Halogen Free APPROVAL SHEET Specifications description : AP CAP 220uF-2V ESR9 7.3X4.3X1.9mm +10~-35 %,2000hrs APAQ P/N : Customer P/N : Date A ACA S 2R0222 1E0 9 Y Approved by Checked by APAQ R&D 2016.09.26 APPROVAL Approved by Customer (Signing or stamping here) : Approved Date : 鈺邦科技股份有限公司 APAQ TECHNOLOGY CO., LTD 竹南科學園區 苗栗縣竹南鎮科東三路 2&6 號 4 樓 4F., No.2 6, Kedong 3rd Rd., Chunan THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF & APAQ 鈺邦科技股份有限公司 TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED Science Park, Miaoli County 350, AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR APAQ TECHNOLOGY CO., LTD DEVICES WITHOUT PERMISSION. Taiwan ,( R.O.C.) DESIGNED BY:Mark DRAWN BY:張坤煌 CHECKED BY:Mark APPROVED BY:樊雨心 TITLE:AP-CAP ACAS SERIES SPECIFICATION DOCUMENT NO. REV MES000098 A0 PAGE 1 OF 8 AP-CAP ACAS SERIES SPECIFICATION 1. Application This specification shall be specified to chip type conductive polymer aluminum solid electrolytic capacitors of ACAS series. 2. Product Identification ACAS 2R0 S 221 ① ② ③ E09 ④ ⑤ ① Product Code ② Rated Voltage □ ⑥ 2R0:2.0V 2R5:2.5V ③ Case Height S:1.9 mm ④ Capacitance 101:100 μF 820:82 μF ⑤ ESR ⑥ Suffix for special code E18:18 mΩ Y:Capacitance +10 ~ -35%,blank space: Capacitance ±20 % 3. Configuration and Dimensions unit:mm Case size S L 7.3±0.3 WA 4.3±0.3 WB 2.4±0.2 H 1.9±0.2 P 1.3±0.2 THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ 鈺邦科技股份有限公司 TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR APAQ TECHNOLOGY CO., LTD DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:張坤煌 CHECKED BY : 黃俊嘉 APPROVED BY:高良民 TITLE:AP-CAP ACAS SERIES SPECIFICATION DOCUMENT NO. REV MES002787 A2 PAGE 2 OF 8 4. Marking ① ② :Polarity Bar (+) :Rated Capacity ③ :Company Logo ④ :Rated Voltage ⑤ :Year (F for 2014、G for 2015、H for 2016) ⑥ :Week 5. Specifications 5.1 Ratings WV(VDC) 2 18 Ripple Current (A r.m.s) @100kHz -55 to 105℃ 2.5 ACAS2R0S101E18 18.0 18 2.5 ACAS2R0S151E18 0.06 26.4 15 2.7 ACAS2R0S221E15 220 0.06 26.4 15 2.7 ACAS2R0S221E15K 220 0.06 26.4 15 2.7 ACAS2R0S221E15Y 220 0.06 26.4 9 3.0 ACAS2R0S221E09 220 0.06 26.4 9 3.0 ACAS2R0S221E09Y 220 0.06 26.4 6 3.5 ACAS2R0S221E06 220 0.06 26.4 4.5 3.8 ACAS2R0S221E04 330 0.06 39.6 15 2.7 ACAS2R0S331E15 330 0.06 39.6 15 2.7 ACAS2R0S331E15Y 330 0.06 39.6 9 3.0 ACAS2R0S331E09 330 0.06 39.6 9 3.0 ACAS2R0S331E09Y 330 0.06 39.6 6 3.5 ACAS2R0S331E06 330 0.06 39.6 4.5 3.8 ACAS2R0S331E04 Cap (μF)@120Hz tanδ Max. @120Hz Leakage Current Max. (μA) ESR Max. (mΩ) @100kHz 100 0.06 12.0 150 0.06 220 Part No. THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ 鈺邦科技股份有限公司 TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR APAQ TECHNOLOGY CO., LTD DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:張坤煌 CHECKED BY : 黃俊嘉 APPROVED BY:高良民 TITLE:AP-CAP ACAS SERIES SPECIFICATION DOCUMENT NO. REV MES002787 A2 PAGE 3 OF 8 WV(VDC) 2.5 18 Ripple Current (A r.m.s) @100kHz -55 to 105℃ 2.5 ACAS2R5S101E18 33.0 15 2.7 ACAS2R5S221E15 0.06 33.0 9 3.0 ACAS2R5S221E09Y 220 0.06 33.0 6 3.5 ACAS2R5S221E06Y 270 0.06 40.5 7 3.5 ACAS2R5S271E07 270 0.06 40.5 6 3.5 ACAS2R5S271E06 330 0.06 49.5 9 3.0 ACAS2R5S331E09 330 0.06 49.5 9 3.0 ACAS2R5S331E09Y 330 0.06 49.5 6 3.5 ACAS2R5S331E06 Cap (μF)@120Hz tanδ Max. @120Hz Leakage Current Max. (μA) ESR Max. (mΩ) @100kHz 100 0.06 15.0 220 0.06 220 Part No. THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ 鈺邦科技股份有限公司 TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR APAQ TECHNOLOGY CO., LTD DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:張坤煌 CHECKED BY : 黃俊嘉 APPROVED BY:高良民 TITLE:AP-CAP ACAS SERIES SPECIFICATION DOCUMENT NO. REV MES002787 A2 PAGE 4 OF 8 5.2 Environmental Performance Item Conditions Characteristics Category Temperature Range -55 to +105 ℃ Rated Voltage Range 2 to 2.5 V.DC Capacitance Tolerance at 20℃, 120Hz ±20 % (M);Y:+10 ~ -35% Leakage Current at 20℃ after 2 minutes I ≦ 0.06CV (2V.DC to 4V.DC) I:Leakage Current(μA), C:Rated Capacitance(μF), V:Rated Voltage(V) Surge Voltage -55 to +105℃ Rated voltage × 1.25 V Dissipation Factor (tanδ) at 20℃,120Hz Case Height:S Type, 0.06 max. Endurance Damp Heat, Steady State Surge Voltage Appearance No significant damage Capacitance Change ±10% of the initial value Dissipation Factor within the initial specified value Leakage Current within the initial specified value Appearance No significant damage Capacitance Change +70%, -20% of the initial value Dissipation Factor  200% of the initial specified value Leakage Current within the initial specified value Appearance No significant damage Capacitance Change ±10% of the initial value Dissipation Factor within the initial specified value Leakage Current within the initial specified value 105℃, rated voltage applied,1000 hrs 60℃, 90 to 95%RH, 500 hrs The capacitors shall be subjected to 1000 cycles each consisting of charge with the surge voltages, 125% rated voltage, at 105℃ for 30 seconds through a protective resistor(R=1KΩ)and discharge for 5min 30 seconds. Solderability Pb-free solder Around 25% rosin melted ethanol or isopropylalcohol Temperature:230 ± 5 ℃ Immersing time:2 ± 0.5 s More than 95% of outer terminal surface to be covered Resistance to Solvents Solvent:isopropylalcohol Immersing time:30 ± 5 s Room temperature No significant damage and marking readable THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ 鈺邦科技股份有限公司 TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR APAQ TECHNOLOGY CO., LTD DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:張坤煌 CHECKED BY : 黃俊嘉 APPROVED BY:高良民 TITLE:AP-CAP ACAS SERIES SPECIFICATION DOCUMENT NO. REV MES002787 A2 PAGE 5 OF 8 5.3 Mechanical Performance Item Conditions Characteristics Vibration Test for 2 hours each in the directions of X-Y-Z at the frequency of 10 to 2000 Hz and amplitude of 1.5 mm(10-2000-10). Side push direction Force:5 N Holding time:10 ± 0.5s Shear Force Appearance No significant damage Capacitance Change ±10% of the initial value Dissipation Factor within the initial specified value Leakage Current within the initial specified value No significant damage in appearance 6. Reflow Condition Recommended Pad Layout(mm) A 1st rising temperature The normal to 30s to 60s Preheating temperature B Preheating 140℃ to 160℃ 60s to 120s Preheating to 200℃ 20s to 40s 217℃ 260℃ 90s 10s 200℃ to 100℃ 1℃/s ~ 4℃/s nd C 2 rising temperature D Main heating E Regular cooling THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ 鈺邦科技股份有限公司 TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR APAQ TECHNOLOGY CO., LTD DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:張坤煌 CHECKED BY : 黃俊嘉 APPROVED BY:高良民 TITLE:AP-CAP ACAS SERIES SPECIFICATION DOCUMENT NO. REV MES002787 A2 PAGE 6 OF 8 7. Taping Packing and Label Marking 7.1 Carrier Tape Dimensions running direction + unit:mm W P1 E F D0 P0 P2 A0 B0 K0 t Dimension 1 2 .0 0 8 .0 0 1 .7 5 5 .5 0 1 .5 0 4 .0 0 2 .0 0 5 .0 0 7 .6 0 2 .3 0 0 .2 4 Tolerance ± 0 . 1 0 ± 0 .1 0 ± 0 .1 0 ± 0 . 1 0 ﹢ 0 . 1 0 ± 0 . 1 0 ± 0 . 1 0 ± 0 .1 0 ± 0 .1 0 ± 0 . 1 0 ± 0 . 1 0 ﹣ 0.00 7.2 Taping Reel Dimensions Reel Dimension (mm) A B C 13.2±0.3 330±1.0 13.5±0.5 7.3 Label Marking The label specified as follows shall be put on the side of reel. (1) Part No. (2) Quantity. (3.5 kpcs / reel) (3) Lot No. THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ 鈺邦科技股份有限公司 TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR APAQ TECHNOLOGY CO., LTD DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:張坤煌 CHECKED BY : 黃俊嘉 APPROVED BY:高良民 TITLE:AP-CAP ACAS SERIES SPECIFICATION DOCUMENT NO. REV MES002787 A2 PAGE 7 OF 8 7.4 Dimension of inner and outer carton box 3.5 kpcs capacitors were packed in a taping reel, 6 reels were packed in a inner carton box (W374*D370*H116mm) and 2 inner carbon box were packed in a outer shipping carton box (W392*D252*H390mm), 42kpcs capacitors in a outer carton box. Inner Carton Box Outer Carton Box unit:mm unit:mm 8. Precautions for Handling 8.1 Storage:All AP-Cap series are classified as MSL-3 (Moisture Sensitivity Level 3). Product should be packaged in a moisture barrier bags with desiccant and moisture indicator card. The recommended storage condition is as below. Temperature: 5 °C to 30 °C Humidity: Less than 60 % RH The maximum storage period is no more than 1 year before opening bags, and capacitors should be used within 7 days after opening bags. If these conditions are exceeded, the product may absorb moisture and have damage risk to the exterior by heat stress during mounting. Those product should be baked again before mounting, and APAQ’s recommended baking conditions follow the standard of IPC/JEDEC J-STD-033. 8.2 Environment:Capacitors are not subject to direct contact with water, salt water, chemically gas, acidic and alkaline environment. 8.3 Disposal:Treat Capacitors as industrial waste because they consist of various metals and resin. THIS DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF APAQ 鈺邦科技股份有限公司 TECHNOLOGY CO. LTD AND SHALL NOT BE REPRODUCT OR USED AS THE BASIC FOR THE MANUFACTURE OR SALE OF APPARATUS OR APAQ TECHNOLOGY CO., LTD DEVICES WITHOUT PERMISSION. DESIGNED BY:陳明宗 DRAWN BY:張坤煌 CHECKED BY : 黃俊嘉 APPROVED BY:高良民 TITLE:AP-CAP ACAS SERIES SPECIFICATION DOCUMENT NO. REV MES002787 A2 PAGE 8 OF 8
ACAS2R0S221E09Y 价格&库存
很抱歉,暂时无法提供与“ACAS2R0S221E09Y”相匹配的价格&库存,您可以联系我们找货
