1N4001WS-1N4007WS SOD-323
Surface Mount Glass Passivated Standard Rectifier
Reverse Voltage -50~1000 V
Forward Current - 1.0A
Pinning
1.Cathode
FEATURES
1
Low Forward Voltage Drop
Guard Ring Construction for Transient Protection
Negligible Reverse Recovery Time
Low Capacitance
2.Anode
2
SOD-323
Lead free in comply with EU RoHS 2011/65/EU directives
MECHANICAL DATA
Case: SOD-323
Terminals: Solderable per MIL-STD-750, Method 2026
Approx. Weight: 5.48mg / 0.00019oz
Marking Code
1N4001WS
1A
1N4002WS
2A
1N4003WS
3A
1N4004WS
4A
1N4005WS
5A
1N4006WS
6A
1N4007WS
7A
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Paramet
er
Symbols 1N4001 1N4002 1N4003 1N4004 1N4005 1N4006 1N4007
WS
WS
WS
WS
WS
WS
WS
Units
Peak Repetitive Reverse Voltage
VRRM
50
100
200
400
600
800
1000
V
RMS reverse voltage
VRMS
35
70
140
280
420
560
700
V
Working Peak Reverse Voltage
VDC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified
Current
IF(AV)
1
A
Peak Forward Surge Current, 8.3ms
Single Half Sine-wave Superimposed On
Rated Load
IFSM
15
A
Maximum Instantaneous Forward Voltage
1A
VF
1.1
v
IR
5
50
uA
RθJA
55
°C/W
Trr
1.8
uS
Cj
5
pF
Tj, Tstg
-55 ~ +150
°C
Maximum DC Reverse Current Ta=25 °C
at Rated DC Blocking Voltage Ta=125 °C
Typical Thermal Resistance
(1)
Typical reverse recovery time
Typical junction capacitance
(2)
(3)
Operating and Storage Temperature Range
(1)P.C.B. mounted with 0.2" X 0.2" (5 X 5 mm) copper pad areas.
(2)Measured with IF=0.5A,IR =1A, Irr= 0.25A
(3)Measured at 1 MHz and applied reverse voltage of 4 V D.C
www.yfwdiode.com
1/3
Dongguan YFW Electronics Co, Ltd.
Fig.2 Typical Instaneous Reverse
Characteristics
Fig.1 Forward Current Derating Curve
Instaneous Reverse Current ( μ A)
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
resistive or inductive load
0.0
25
75
50
100
125
150
175
100
T J =150°C
10
T J =125°C
T J =100°C
1.0
T J =75°C
0.1
T J =25°C
0.01
Junction Capacitance ( pF)
TJ =
2 5°
C
00
=1
TJ
=1
25
°C
°C
0.5
TJ
Instaneous Forward Current (A)
1.0
0.8
0.9
600
800
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
0.2
0.1
0.6
400
200
Instaneous Reverse Voltage (V)
Case Temperature (°C)
100
T J =25°C
10
1
0.7
1.0
1.1
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
10
5
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
www.yfwdiode.com
2/3
SOD-323
Package Outline
Plastic surface mounted package; 2 leads
E
E
D
b
A
C
A1
∠ALL ROUND
L1
E1
A
C
D
E
E1
b
L1
A1
max
1.1
0.15
1.4
1.8
2.75
0.4
0.45
0.2
min
0.8
0.08
1.2
1.4
2.55
0.25
0.2
max
43
5.9
55
70
108
16
16
min
32
3.1
47
63
100
9.8
7.9
UNIT
mm
9°
8
mil
The recommended mounting pad size
1.4
(55)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
Summary of Packing Options
Package
SOD-323
www.yfwdiode.com
Packing Description
Packing Quantity
Industry Standard
Tape/Reel,7”reel
3000
EIA-481-1
3/3
很抱歉,暂时无法提供与“1N4001WS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.11104
- 600+0.08620
- 1200+0.08491
- 3000+0.07093
- 国内价格
- 1+0.31570
- 200+0.10538
- 1500+0.06589
- 3000+0.05236
- 国内价格
- 20+0.13198
- 200+0.10282
- 600+0.08662
- 3000+0.07787
- 9000+0.06945
- 21000+0.06480
