GBPC3510W
GBPC3510W
    GOODWORK(固得沃克)
    GBPC-W
    GBPC3510W
GBPC3510W 数据手册
GBPC35005WTHRUGBPC3510W SINGLE PHASE 35.0 3 AMP BRIDGE RECTIFIERS VOLTAGE RANGE 50 to 1000 Volts CURRENT 35.0 Ampere GBPC-W Metal Heat Sink FEATURES .335(8.5) .295(7.5) 1.291 MIN. (32.8) * Superior thermal design .042(1.1) DIA. .039(1.0) TYP. * 400 amperes surge capability * Mounting: Hole thru for #8 screw 1.181(30.0) 1.102(28.0) HOLE FOR NO. 10 SCREW .673(17.1) .633(16.1) AC + .732(18.6) .692(17.6) AC 1.181(30.0) .468(11.9) 1.102(28.0) .429(10.9) .732(18.6) .692(17.6) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER GBPC35005W GBPC3501W GBPC3502W GBPC3504W GBPC3506W GBPC3508W GBPC3510W Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 UNITS V V V .375"(9.5mm) Lead Length at Tc=50 C Peak Forward Surge Current, 8.3 ms single half sine-wave 35.0 A superimposed on rated load (JEDEC method) Maximum Forward Voltage Drop per Bridge Element at17.5A D.C. Maximum DC Reverse Current Ta=25 C 400 1.2 10 A V mA 100 +150 +150 mA at Rated DC Blocking Voltage Operating Temperature Range, TJ Storage Temperature Range, TSTG Ta=100 C -65 -65 C C REV 1.0 2015 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (GBPC35005W THRU GBPC3510W) FIG.2-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 60 Single Phase 50 Half Wave 60Hz Resistive Or Inductive Load 40 30 20 10 0 0 25 50 75 100 125 150 175 PEAK FORWARD SURGE CURRENT,(A) AVERAGE FORWARD CURRENT,(A) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE 500 400 300 8.3ms Single Half Tj=25 C Sine Wave 200 JEDEC method 100 0 CASE TEMPERATURE,( C) 1 5 50 10 100 FIG.3-TYPICAL FORWARD FIG.4-TYPICAL REVERSE CHARACTERISTICS CHARACTERISTICS 50 50 10 10 REVERSE LEAKAGE CURRENT, (mA) INSTANTANEOUS FORWARD CURRENT,(A) NUMBER OF CYCLES AT 60Hz 3.0 1.0 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 3.0 1.0 0.1 Tj=25 C .01 0 .2 .4 .6 .8 1.0 FORWARD VOLTAGE,(V) 1.2 1.4 .01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE, (%) REV 1.0 2015 JAN PAGE:2/2
GBPC3510W 价格&库存
很抱歉,暂时无法提供与“GBPC3510W”相匹配的价格&库存,您可以联系我们找货
GBPC3510W
  • 1+11.73960
  • 10+10.03320
  • 50+8.33760
  • 100+7.23600
  • 500+6.73920
  • 1000+6.53400
