序号
(NO.)
品名
(Name)
材质
(Material)
1
A型立式胶芯
1.25 Pitch S/T Wire To
Board Housing(H=4.9)
LCP UL94V-0 本色
2
A型立式WTB端子
Board Terminal(H=4.9)
铜合金/表面镀锡
Copper Alloy/
Tin Plating
3
A型立式WTB焊片
铜合金/表面镀锡
Copper Alloy/
Board Fitting Nail (H=4.9) Tin Plating
4
A型立式WTB吸盖
Board Cover(H=4.9)
LCP UL94V-0 本色
2
A
1
4
WITHOUT COVER
SECTION A-A
A
技术指标(Technical Index) :
(Min)
3
适用线路板(PCB LAYOUT)
1.塑件表面应光洁、无毛边、无明显收缩、缺陷、裂纹等现象.(The surface of the
plastic parts should be smooth,no rough edges,no obvious
shrinkage,defects,cracks and other phenomena)
2.锁扣窗口:2~3PIN为1个,≥4PIN为2个.(Lock Configuration:2 to 3Pin is
1,≥4Pin is 2 )
3.不同Pin位吸盖加入/取出力有差异,实属正常现象.(It is normal that there are
differences between suction cap and suction cap at different Pin positions)
4.温度范围(Temperature range):-65°C~125°C.
5.额定电压(Rated voltage):125V,AC/DC(=等效).
6.接触电阻(Contact resistance):≤0.02 Ω.
7.绝缘电阻(Insulation resistance):≥100M Ω
陈一鸣
2014-02-23
马跃
2014-02-23
邱敏
2014-02-23
1.25PH 立式贴片wafer
HYCW01-LFN-125B
HYC-2112271007
1 OF 1
很抱歉,暂时无法提供与“HYCW01-LF02-125B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.25791
- 200+0.20207
- 600+0.17108
- 1500+0.14721
