2R-5 Series
Gas Discharge Tube (GDT) Data Sheet
Features
Provide ultra-fast response to surge voltage from slow-rising surge of 100V/s to rapid-rising surge of 1KV/μs
Low capacitance(≤1.5pF)
High holdover voltage
High insulation resistance
Stable breakdown voltage
Large absorbing transient current capability
Micro-Gap Design
Operating and Storage Temperature :-40℃ ~ +125℃
Meets MSL Level 1,per J-STD-020
Applications
Telephone Interface, Line cards
Data communication equipment
Line test equipment
Repeaters, Modems
Part Number Code
2
5
R
Electrode Numbers
2R:2Electrodes
DC
Spark-over
Voltage
Lead Type
L:Lead
S: SMD
Electrical
Characteristics
D: 5KA
E: 10KA
Revision:18-Dec-19
Dimensions
5: 5.5mm x 6mm
1/7
www.ftrqg.com
2R-5 Series
Electrical Characteristics
DC
Spark-over
Part Number
Voltage
Maximum
Impulse
Spark-over
Voltage
Impulse
Minimum
Life
Insulation
Test
Resistance
10/1000us
Test
100A
Voltage
(v)
(times)
DC(V)
100V/S
1KV/us
(v)
(GΩ)
Nominal
Maximum
Impulse
Capacitance
Discharge
Current
Alternating
Discharge
Current
(1MHz 1V)
8/20us
50Hz,1S
(pF)
(KA)
(A)
Device
Marking
Code
2RD070L-5
2RD070S-5
70±20%
800
300
25
1
1.5
5
5
2RD070-5
2RD075L-5
2RD075S-5
75±20%
800
300
25
1
1.5
5
5
2RD075-5
2RD090L-5
2RD090S-5
90±20%
700
300
50
1
1.5
5
5
2RD090-5
2RD120L-5
2RD120S-5
120±20%
700
300
50
1
1.5
5
5
2RD120-5
2RD150L-5
2RD150S-5
150±20%
700
300
100
1
1.5
5
5
2RD150-5
2RD230L-5
2RD230S-5
230±20%
700
300
100
1
1.5
5
5
2RD230-5
2RD250L-5
2RD250S-5
250±20%
700
300
100
1
1.5
5
5
2RD250-5
2RD300L-5
2RD300S-5
300±20%
900
300
100
1
1.5
5
5
2RD300-5
2RD350L-5
2RD350S-5
350±20%
900
300
100
1
1.5
5
5
2RD350-5
2RD400L-5
2RD400S-5
400±20%
1000
300
100
1
1.5
5
5
2RD400-5
2RD470L-5
2RD470S-5
470±20%
1100
300
250
1
1.5
5
5
2RD470-5
2RD600L-5
2RD600S-5
600±20%
1500
300
250
1
1.5
5
5
2RD600-5
2RD800L-5
2RD800S-5
800±20%
1700
300
250
1
1.5
5
5
2RD800-5
DC
Spark-over
Voltage
Part Number
Maximum
Impulse
Spark-over
Voltage
Impulse
Minimum
Life
Insulation
Test
Resistance
10/1000us
Test
100A
Voltage
(v)
(times)
DC(V)
100V/S
1KV/us
(v)
(GΩ)
Nominal
Maximum
Impulse
Capacitance
Discharge
Current
Alternating
Discharge
Current
Device
Marking
(1MHz 1V)
8/20us
50Hz,1S
(pF)
(KA)
(A)
Code
2RE070L-5
2RE070S-5
70±20%
600
500
25
1
1.5
10
10
2RE070-5
2RE075L-5
2RE075S-5
75±20%
600
500
25
1
1.5
10
10
2RE075-5
2RE090L-5
2RE090S-5
90±20%
600
500
50
1
1.5
10
10
2RE090-5
2RE120L-5
2RE120S-5
120±20%
600
500
50
1
1.5
10
10
2RE120-5
2RE150L-5
2RE150S-5
150±20%
700
500
100
1
1.5
10
10
2RE150-5
2RE230L-5
2RE230S-5
230±20%
700
500
100
1
1.5
10
10
2RE230-5
2RE250L-5
2RE250S-5
250±20%
800
500
100
1
1.5
10
10
2RE250-5
2RE300L-5
2RE300S-5
300±20%
900
500
100
1
1.5
10
10
2RE300-5
2RE350L-5
2RE350S-5
350±20%
900
500
100
1
1.5
10
10
2RE350-5
2RE400L-5
2RE400S-5
400±20%
1000
500
100
1
1.5
10
10
2RE400-5
2RE470L-5
2RE470S-5
470±20%
1100
500
250
1
1.5
10
10
2RE470-5
2RE600L-5
2RE600S-5
600±20%
1500
500
250
1
1.5
10
10
2RE600-5
2RE800L-5
2RE800S-5
800±20%
1700
500
250
1
1.5
10
10
2RE800-5
Revision:18-Dec-19
2/7
www.ftrqg.com
2R-5 Series
Dimensions
L Type
S Type
Symbol
Dimension (mm)
D
5.50±0.50
T
6.00±0.50
d
0.80±0.10
L
30 max.
D
5.50±0.50
T
6.00±0.50
B
0.50±0.10
Electrical Ratings
Items
DC spark-over
voltage
Test Condition/Description
Requirement
The voltage is measured with voltage ramp dv/dt=100V/s.
Maximum
Impulse
Spark-over
Voltage
The maximum impulse spark-over voltage is measured with voltage ramp
dv/dt=1000V/μs.
Insulation
Resistance
The resistance of gas tube shall be measured between two electrodes.
Capacitance
The capacitance of gas tube shall be measured between two electrodes. Test
frequency: 1MHz
Maximum 8/20μs surge current that can be applied between two electrodes, 5
positive and 5 negative surges, with 3 minutes interval time, without causing
the DC spark-over voltage to change more than 25% from its initial value.
To meet the
Specified
value
Crest value
100
90
Current (%)
Impulse
Discharge
Current
50
20µs
10
8µs
Time
Impulse Width
Alternating
Discharge Current
Revision:18-Dec-19
Rated RMS value of AC current at 50Hz, 1 sec. for 10 times with interval time 3
min. DC spark-over voltage shall not change more than ±25% from its initial
8
value.IR>10 ohms (-20%, +30% for 70~90V).
3/7
www.ftrqg.com
2R-5 Series
Soldering Recommendation
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25
to Peak
Time
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TLto TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
150℃
-Temperature Max (TS max)
200℃
-Time (min to max)( tS)
60-180 seconds
TS maxto TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
217℃
-Time (tL)
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual PeakTemperature
(tP)
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
Revision:18-Dec-19
20-40 seconds
8 minutes max.
4/7
www.ftrqg.com
2R-5 Series
Wave Soldering
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds(max.)
Soldering
1 time
Packaging
Axial Packing
Sking packing
Symbol
Dimension (mm)
A
265 ± 5.0
B
146 ± 5.0
H
6.8 ± 0.5
Quantity:100pcs
Inner box
A0
270 ± 2.0
B0
150 ± 2.0
H0
50 ± 2.0
Quantity: 500pcs
Tape
Revision:18-Dec-19
5/7
P
10.0 ± 0.5
W
65.0 ± 1.0
E
6.0 ± 0.5
www.ftrqg.com
2R-5 Series
Reel
F
26.5 ± 0.5
d
0.8 ± 0.1
A1
330.0 ± 2.0
B1
70.0 ± 2.0
C1
82.0 ± 2.0
D
25.0 ± 0.5
t
2.0 ± 0.2
Quantity: 1000pcs
SMD packing
Tape
P0
P1
P2
D0
B
T
E
F
W
B0
A
A
Dimension (mm)
W
16.00±0.20
P0
4.00±0.10
P1
12.00±0.20
P2
2.00±0.10
D0
Φ1.55±0.05
E
1.75±0.10
F
7.50±0.10
A0
5.85±0.1
B0
7.00±0.1
K0
6.20±0.1
T
0.50±0.1
D
330.0±2.0
d
13.0±0.5
K0
B
SECTION B-B
A0
SECTION A-A
Reel
Revision:18-Dec-19
Symbol
6/7
www.ftrqg.com
2R-5 Series
L
20.0±2.0
t
2.0±0.2
Quantity: 800PCS
Revision:18-Dec-19
7/7
www.ftrqg.com
很抱歉,暂时无法提供与“2RD800L-5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.11637
- 50+1.68081
- 150+1.49408
- 500+1.22742
- 2500+1.12374
- 5000+1.06154
