3RD090S-5S
3RD090S-5S
    FTR(乔光电子)
    SMD,5x7.6mm
    90V 5KA 3端 贴片GDT
3RD090S-5S 数据手册
3R-5S Series Gas Discharge Tube (GDT) Data Sheet Features ■ ■ ■ ■ ■ ■ ■ ■ ■ Provide ultra-fast response to surge voltage from slow-rising surge of 100V/s to rapid-rising surge of 1KV/μs Low capacitance (≤2pF) High holdover voltage High insulation resistance Stable breakdown voltage Large absorbing transient current capability Micro-Gap Design Operating and Storage Temperature :-40℃ ~ +125℃ Meets MSL Level 1,per J-STD-020 Applications ■ ■ ■ ■ Telephone Interface, Line cards Data communication equipment Line test equipment Repeaters, Modems Part Number Code 3 R Electrode Numbers 3R:3Electrodes 5 DC Spark-over Voltage Dimensions 5S: 5mm x 7.6mm Lead Type L:Lead S: SMD Electrical Characteristics D: 5KA E: 10KA Revision:18-Dec-19 S 1/5 www.ftrqg.com 3R-5S Series Electrical Characteristics DC Spark-over Voltage Part Number 3RD075S-5S Maximum Impulse Spark-over Voltage Nominal Impulse Minimum Life Insulation Test Resistance 100V/S 1KV/us 10/1000us 100A Test Voltage (v) (v) (times) DC(V) 75±20% 600 300 25 Alternating Maximum Impulse Capacitance Discharge Current Discharge Current Device Marking Code (1MHz 1V) 8/20us 50Hz,1S (pF) (KA) (A) 1 2.0 5 5 3RD075-5 (GΩ) 3RD090S-5S 90±20% 600 300 50 1 2.0 5 5 3RD090-5 3RD120S-5S 120±20% 600 300 50 1 2.0 5 5 3RD120-5 3RD150S-5S 150±20% 600 300 100 1 2.0 5 5 3RD150-5 3RD200S-5S 200±20% 650 300 100 1 2.0 5 5 3RD200-5 3RD230S-5S 230±20% 650 300 100 1 2.0 5 5 3RD230-5 3RD250S-5S 250±20% 650 300 100 1 2.0 5 5 3RD250-5 3RD300S-5S 300±20% 800 300 100 1 2.0 5 5 3RD300-5 3RD350S-5S 350±20% 800 300 100 1 2.0 5 5 3RD350-5 3RD400S-5S 400±20% 900 300 100 1 2.0 5 5 3RD400-5 3RD420S-5S 420±20% 900 300 250 1 2.0 5 5 3RD420-5 3RD470S-5S 470±20% 900 300 250 1 2.0 5 5 3RD470-5 3RD600S-5S 600±20% 1000 300 250 1 2.0 5 5 3RD600-5 Dimensions Revision:18-Dec-19 2/5 SymboS Dimension (mm) D 5. 00±0.20 T 7.60±0.30 B 0.40±0.10 B1 1.50±0.20 d 4.80±0.10 www.ftrqg.com 3R-5S Series ESectricaS Ratings Items DC spark-over voStage Test Condition/Description Requirement The voStage is measured with voStage ramp dv/dt=100V/s. Maximum ImpuSse Spark-over VoStage The maximum impuSse spark-over voStage is measured with voStage ramp dv/dt=1000V/μs. InsuSation Resistance The resistance of gas tube shaSS be measured between two eSectrodes. Capacitance The capacitance of gas tube shaSS be measured between two eSectrodes. Test frequency: 1MHz Maximum 8/20μs surge current that can be appSied between two eSectrodes, 5 positive and 5 negative surges, with 3 minutes intervaS time, without causing the DC spark-over voStage to change more than 25% from its initiaS To meet the Specified vaSue vaSue. Crest value ImpuSse Discharge Current 100 90 50 20µs 10 0 8µs Time Impulse Width ASternating Discharge Current Revision:18-Dec-19 Rated RMS vaSue of AC current at 50Hz, 1 sec. for 10 times with intervaS time 3 min. DC spark-over voStage shaSS not change more than ±25% from its initiaS vaSue.IR> 108 ohms (-20%, +30% for 70~90V). 3/5 www.ftrqg.com 3R-5S Series SoSdering Recommendation RefSow SoSdering Critical Zone TL to TP tP TP Ramp-up TL tL TS max TS min Ramp-down tS Preheat 25 t 25 to Peak Time ProfiSe Feature Pb-Free AssembSy 3℃/second max. Average ramp-up rate (TSto TP) Preheat 150℃ 200℃ -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max)( tS) 60-180 seconds TS maxto TS -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TS) 217℃ -Time (tS) 60-150 seconds 260℃ Peak Temperature (TP) Time within 5 ℃ of actuaS PeakTemperature (tP) 6℃/second max. Ramp-down Rate Time 25℃ to Peak Temperature Revision:18-Dec-19 20-40 seconds 8 minutes max. 4/5 www.ftrqg.com 3R-5S Series Packaging Tape P0 P1 P2 D0 B A Dimension (mm) W 16.00±0.20 P0 4.00±0.10 P1 12.00±0.20 P2 2.00±0.10 D0 Φ1.55±0.05 E 1.75±0.10 F 7.50±0.10 A0 7.40±0.1 B0 5.40±0.1 K0 5.50±0.1 T 0.50±0.1 D 330.0±2.0 d 13.0±0.5 S 20.0±2.0 t 2.0±0.2 T E F A SymboS W B0 K0 B SECTION B-B A0 SECTION A-A ReeS Quantity: 1000PCS Revision:18-Dec-19 5/5 www.ftrqg.com
3RD090S-5S 价格&库存
很抱歉,暂时无法提供与“3RD090S-5S”相匹配的价格&库存,您可以联系我们找货
3RD090S-5S
库存:68
3RD090S-5S
  • 1+2.95820
  • 10+2.38310
  • 30+2.13620
  • 100+1.81200
  • 500+1.50430
  • 1000+1.41860
库存:68
