2RS800L-8
2RS800L-8
    FTR(乔光电子)
    插件,8x6mm
    800V 400A 2
2RS800L-8 数据手册
2RS800L-8 Gas Discharge Tube (GDT) Data Sheet Features ■ ■ ■ ■ ■ ■ ■ ■ ■ Provide ultra-fast response to surge voltage from slow-rising surge of 100V/s to rapid-rising surge of 1KV/μs Low capacitance(≤1.5pF) High holdover voltage Stable breakdown voltage Large absorbing transient current capability Surface mounted gas arrester Micro-Gap Design Operating and Storage Temperature :-40℃ ~ +125℃ Meets MSL Level 1,per J-STD-020 Applications ■ ■ ■ ■ Telephone Interface, Line cards Data communication equipment Line test equipment Repeaters, Modems Part Number Code 2 8 R Electrode Numbers 2R:2Electrodes DC Spark-over Voltage Electrical Characteristics S: Switching spark gaps Revision:18-Dec-19 Dimensions 8: 8mm x 6mm Lead Type L:Lead S: SMD 1/3 Internal control code www.ftrqg.com 2RS800L-8 Electrical Characteristics DC Switching Spark-over Operations Voltage @25°C Part Number 100V/S 800±20% Insulation Voltage Resistance Times Voltage (v) (GΩ) DC(V) 10 5 1000 100 Maximum Peak Capacitance dischargecurrent Device Marking Code Test (v) 2RS800L-8 Minimum Test (1MHz 1V) (A) (pF) 1 1.5 KG8 400 800 Dimensions T D Symbol Dimension (mm) D 8.00±0.50 T 6.00±0.50 d 0.80±0.10 L 8.00±1.00 F 10.00±1.00 Symbol Dimension (mm) A0 270 ± 2.0 B0 150 ± 2.0 H0 50 ± 2.0 d L F Packaging Quantity:1000pcs Revision:18-Dec-19 2/3 www.ftrqg.com 2RS800L-8 Soldering Recommendation Reflow Soldering Critical Zone TL to TP tP TP Ramp-up TL tL Temperature TS max TS min Ramp-down tS Preheat 25 t 25 to Peak Time Profile Feature Pb-Free Assembly Average ramp-up rate (TLto TP) 3℃/second max. Preheat -Temperature Min (TS min) 150℃ -Temperature Max (TS max) 200℃ -Time (min to max)( tS) 60-180 seconds TS maxto TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) 217℃ -Time (tL) 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual PeakTemperature 20-40 seconds (tP) Ramp-down Rate 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max. Wave Soldering 300 Preheating Maximum Wave 265℃ Soldering Cooling Temperature (℃) 250 200 150 100 50 0 0 0.5 1 1.5 2 2.5 3 3.5 4 Time (minutes) Revision:18-Dec-19 Item Conditions Peak Temperature 265℃ Dipping Time 10 seconds(max.) Soldering 1 time 3/3 www.ftrqg.com
2RS800L-8 价格&库存
很抱歉,暂时无法提供与“2RS800L-8”相匹配的价格&库存,您可以联系我们找货
