2RE1000L-8
Gas Discharge Tube (GDT) Data Sheet
Features
Provide ultra-fast response to surge voltage from slow-rising surge of 100V/s to rapid-rising surge of 1KV/μs
Low capacitance(≤1.5pF)
High holdover voltage
Stable breakdown voltage
Large absorbing transient current capability
Surface mounted gas arrester
Micro-Gap Design
Operating and Storage Temperature :-40℃ ~ +125℃
Meets MSL Level 1,per J-STD-020
Applications
Telephone Interface, Line cards
Data communication equipment
Line test equipment
Repeaters, Modems
Part Number Code
2
8
R
Electrode Numbers
2R:2Electrodes
DC
Spark-over
Voltage
Lead Type
L:Lead
S: SMD
Electrical
Characteristics
E:10KA
F: 20KA
Revision:18-Dec-19
Dimensions
8: 8mm x 6mm
1/4
www.ftrqg.com
2RE1000L-8
Electrical Characteristics
Maximum
DC
Spark-over
Voltage
Part Number
2RE1000L-8V
Impulse
Impulse
Spark-over
Voltage
Life
Insulation
Test
Resistance
10/1000us
Test
100A
Voltage
(v)
(times)
DC(V)
1800
300
250
100V/S
1KV/us
(v)
1000±20%
Nominal
Minimum
Maximum
Impulse
Capacitance
Discharge
Current
(GΩ)
Alternating
Discharge
(1MHz 1V)
8/20us
50Hz,1S
(pF)
(KA)
(A)
1.5
10
10
1
Device
Current
Marking
Code
2RE1000-8
Dimensions
Symbol
Dimension (mm)
D
8.00±0.50
T
6.00±0.50
d
0.80±0.10
L
30 max.
Soldering Recommendation
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25
to Peak
Time
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TLto TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
150℃
-Temperature Max (TS max)
200℃
-Time (min to max)( tS)
60-180 seconds
TS maxto TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
217℃
-Time (tL)
60-150 seconds
Peak Temperature (TP)
Time
within
5
260℃
of
actual
PeakTemperature (tP)
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
Revision:18-Dec-19
20-40 seconds
8 minutes max.
2/4
www.ftrqg.com
2RE1000L-8
Electrical Ratings
Items
DC spark-over
voltage
Test Condition/Description
Requirement
The voltage is measured with voltage ramp dv/dt=100V/s.
Maximum
Impulse
Spark-over
Voltage
The maximum impulse spark-over voltage is measured with voltage ramp
dv/dt=1000V/μs.
Insulation
Resistance
The resistance of gas tube shall be measured between two electrodes.
Capacitance
The capacitance of gas tube shall be measured between two electrodes. Test
frequency: 1MHz
Maximum 8/20μs surge current that can be applied between two electrodes, 5
positive and 5 negative surges, with 3 minutes interval time, without causing
the DC spark-over voltage to change more than 25% from its initial value.
To meet the
Specified
value
Crest value
100
90
Current (%)
Impulse
Discharge
Current
50
20µs
10
8µs
Time
Impulse Width
Alternating
Discharge Current
Rated RMS value of AC current at 50Hz, 1 sec. for 10 times with interval time 3
min. DC spark-over voltage shall not change more than ±25% from its initial
8
value.IR>10 ohms (-20%, +30% for 70~90V).
Packaging
Axial Packing
Sking packing
Symbol
Dimension (mm)
A
265 ± 5.0
B
146 ± 5.0
H
8.5 ± 0.5
Quantity:100pcs
Inner box
Revision:18-Dec-19
A0
3/4
270 ± 2.0
www.ftrqg.com
2RE1000L-8
B0
150 ± 2.0
H0
50 ± 2.0
Quantity: 500pcs
Tape
Reel
P
10.0 ± 0.5
W
65.0 ± 1.0
E
6.0 ± 0.5
F
26.5 ± 0.5
d
0.8 ± 0.1
A1
330.0 ± 2.0
B1
70.0 ± 2.0
C1
82.0 ± 2.0
D
25.0 ± 0.5
t
2.0 ± 0.2
Quantity: 800pcs
Revision:18-Dec-19
4/4
www.ftrqg.com
很抱歉,暂时无法提供与“2RE1000L-8”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.67106
- 50+2.13765
- 200+1.90912
- 500+1.49980
- 2500+1.37279
- 5000+1.29654
