380-RK
380-RK
    PANAVISE
    REPAIR KIT BASE PANAVISE
380-RK 数据手册
| Join-Leave Email List | | View Cart | Check Out | Home Company News Trade Shows Find Sales Rep International Sources Request Catalog By Mail Request A Sales Call Contact Us Product Map Downloads Vises, Work Holding Tools : Vise Accessories Vises, Work Holding Tools Company History 0 item(s) : $0.00 Advanced Search or Input Simple Search Here--> Search here Vise Accessories Vise Combinations Vise Heads Vise Bases Vise Base Mounts Circuit Board Holders Vises, Heavy Duty Vise Accessories PanaPress. Mini Arbor Press The ribbed jaws of our Model 336 Wide Opening Head work well holding smaller circuit boards. Mobile Electronics Mounts InDash Custom Dash Mounts Click Here or On Above Image for More Information. iPhone/Smartphone Holders-Mounts Smartphone Accessories Mobile Power Action Camera Mounts Click on the product Part Number, Title or Image to navigate to a page with further details about that product. CCTV, Security Camera Mounts Audio/Video Mounts Protect the finish of your project with these add-on Jaw Pads. 204 Neoprene Pads for 201, 203, 207 and 209 Neoprene Pads slip over the existing jaws. Soft and gentle, with plenty of holding power! $3.49 Quantity 1 Add To Cart Accessory for 201, 203, 207 and 209 239 Speed Control Handle Easy on, Easy off handle for faster jaw movement & fine tuning control. $3.49 Quantity 1 Add To Cart Excellent electrical insulation! 343 Nylon Jaws Standard replacement Jaws for 303 and 304 Vise Heads as well as 301 and 381 Vise Combos. $2.99 Quantity 1 Add To Cart Click on any of the above images to find out more about the products pictured. Perfect for small tubes, rods or circuit boards! 344 Grooved Nylon Jaws For 303 and 304 Vise Heads as well as 301 and 381 Vise Combos. Excellent electrical insulation with a grooved surface. $3.99 Quantity 1 Add To Cart Gentle pads with plenty of holding power! 346 Deluxe Neoprene Jaw Pads These versatile neoprene pads slip over the metal arms on the 366 and 376 Vise Heads. $2.99 Quantity 1 Add To Cart Gentle pads with non-marking holding power 346NM Deluxe Non-Marking Neoprene Jaw Pads These versatile neoprene pads slip over the metal arms on the 366 and 376 Vise Heads. $3.99 Quantity 1 Add To Cart The name says it all! 352 High Heat Jaws For 303 and 304 Vise Heads as well as 301 and 381 Vise Combos. Recommended for high heat applications. $12.99 Quantity 1 Add To Cart Your heavy-duty alternative! 353 Plated Steel Jaws For 303 and 304 Vise Heads as well as 301 and 381 Vise Combos. Recommended for high heat, industrial environments. $11.99 Quantity 1 Add To Cart A gentler, high-heat choice! 354 Brass Jaws For 303 and 304 Vise Heads as well as 301 and 381 Vise Combos. A non-marring alternative. $12.99 Quantity 1 Add To Cart A handy time save that keeps your leads and tools organized! 358 Wire Manager Specifically designed for use with the 366 and 376 Vise Heads. $21.99 Quantity 1 Add To Cart Keep your soldering iron and solder close at hand! 371 Solder Station This unique accessory is perfect for use with the 308 and 312 Base Mounts. $16.99 Quantity 1 Add To Cart Repair your torn or damaged vacuum base pad! 380-RK Vacuum Base Repair Kit For use with PanaVise 380 and 381 vacuum bases. $14.99 Quantity 1 Add To Cart Webiste and content, copy right PanaVise Products, Inc. 1996 - 2015. PanaVise, PanaPress, PV Jr, Posi-Stop, Slimline, Slimline 2000, Unif lex, Stay -Put, PortaGrip, PortaGrip 2000, InDash, WindowGrip, Deluxe Multi Media Mount, Clip Caddy , and Vise Buddy are registered trademarks or trademarks of PanaVise Products, Inc. in the U.S. and in other countries. PanaVise's products are protected under one or more of the f ollowing U.S. Patents: 2,898,068; 3,661,376; 5,118,058; 5.187,744; 5,465,932; D390,849: D582,894. Patents pending on additional products in the U.S. and in other countries. PanaVise has a long history of v igorously prosecuting v iolations and/or protecting both its phy sical and intellectual property rights. All PanaVise Products are cov ered by a Limited Lif etime Warranty
380-RK 价格&库存
很抱歉,暂时无法提供与“380-RK”相匹配的价格&库存,您可以联系我们找货
