437
437
    PANAVISE
    ROUND SPACER #8 ALUMINUM 1-3/4"
437 数据手册
Model: 437 Heavy Duty Head A rugged Fixturing Head for heavy duty projects! • Recommended for use with the 400 Heavy Duty Base • Four "universal" slots 0.29" (7.37mm) wide for attaching forms, parts, etc... • Flat Head is 3" x 6" (76.2mm x 152.4mm) • Shaft is 1" (25.4mm) in diameter and 3.25" (82.5mm) long. Shaft is drilled and tapped 1/4-20 (screw included) for permanently securing to base • Height (bottom of shaft to top of head): 4" (101.6mm), Weight: 0.86 lbs. (0.4kg)
很抱歉,暂时无法提供与“437”相匹配的价格&库存,您可以联系我们找货
