3251-21-01/TP3251-31-01/70
    TRIPUS
3251-21-01/TP3251-31-01/70 数据手册
Tripus systems GmbH Schalt- und Steuergeräte Am Hohen Rain 2 89347 Bubesheim Tel: 08221 - 9016-0 Fax: 08221 - 32073 Data sheet for built-in switch with low voltage release TP3251 Usage: Multifaceted use in devices from domestic and industrial sectors Switching of motors and heating circuits Certificates: VDE according to DIN EN 60947-1 (depending on type) VDE according to DIN EN 60947-4-1 (depending on type) UL (depending on type) Characteristics: positively driven contact Flat connection 6,3 x 0,8 mm option coil connection (A1) flat connectors 2,8 x 0,8 mm (depending on type) Operating mechanism with rocker or push buttons several sealing versions available Housing material: black: PA66 GF25 / Schulamid 66 GF25 FR 5A black Operating mechanism: Mechanical ON/OFF, mechanical ON/ electrical OFF Technical data: Rated frequency: Rated insulation voltage Ui: Degree of pollution: Conventional thermal current Ith: Utilization category: Rated operational voltage Ue: Rate operational current Ie: Mechanical durability: Electrical durability AC1: Electrical durability AC3: 50/60 Hz (depending on type) 230 V 3 16 A AC1 AC3 230 V 230 V 1~ 1~ 16 A 14,5 A 50.000 Switching cycles 50.000 Switching cycles with 16A 50.000 Switching cycles with 10A 35.000 Switching cycles with 14,5A Switching cycles: 600 cycles/hour Protection class: Protection class with sealing: IP54 IP65 Mounting: Snap in version 2 Drilling holes Ø 4,2mm – 42mm 2 Drilling holes Ø 4,2mm – 62mm Panel cutout Ca. 46,5mm x 22,1mm allowed ambient temperature: -5 oC to 40 oC Coil versions: Voltage / Frequency 115V / 50Hz 230V / 50Hz 115V / 60Hz 120V / 60Hz 230V / 60Hz Zuletzt gespeichert von Georg Schilling Seite 1 von 2 Current Consumption 26mA 12mA Resistance 1250Ω +/- 50Ω 5000Ω +/- 400Ω 900Ω +/- 50Ω 1100Ω +/- 50Ω 3800Ω +/- 200Ω 11.06.2018 Weight: dimensions: depending on type Zuletzt gespeichert von Georg Schilling Approx. 71-90 gr. Seite 2 von 2 11.06.2018
3251-21-01/TP3251-31-01/70 价格&库存
很抱歉,暂时无法提供与“3251-21-01/TP3251-31-01/70”相匹配的价格&库存,您可以联系我们找货
