2003P
2003P
    OTHER
2003P 数据手册
TECHNICAL DATA SHEET Presssure The 2000 Series of pressure instruments offer a wide range of hand-held manometers. Easy to operate, reliable and built to last, the 2000 Series has been developed in order to meet the performance and cost demands of today's markets. The 2000 Series of pressure instruments offers the widest range of hand-held manometers world-wide. New innovative functions designed to make the operator’s job easier set new standards in pressure measurements. Pressure Scale mbar Pa in H2O m H2O in Hg 20x0P 20x1P 20x3P 20x5P 20x6P 20x7P 0 to 1999 µbar 0.00 to 19.99 mbar 0.0 to 199.9 mbar 20x2P 0 to 1999 mbar 0.0 to 199.9 mbar 0 to 1999 mbar + + 0.0 to 199.9mbar 0.0 to 199.9mbar + + + + + + 0.00 to 25.00 mbar 0.0 to 130.0 mbar 0 to 1999 mbar 0.00 to 7.00 bar 0 to 1999 mbar 0.00 to 10.00 bar 0 to 500mbar 0.0 to 199.9 Pa 0.00 to 19.99 kPa 0.0 to 199.9 kPa 0.00 to 19.99 kPa 0.0 to 199.9 kPa + + + + + 0.00 to 19.99kPa 0.00 to 19.99kPa + + 0 Pa to 2500 Pa 0.0 to 199.9 kPa 0 to 700 kPa 0.0 to 199.9 kPa 0 to 1000 kPa 0.0 to 50.0kPa 0.00 to 10.05” 0.00 to 13.00 kPa 0.00 to 52.28” 0.0 to 199.9” 0.0 to 199.9” 0.0 to 199.9” 0.0 to 199.9" 0.0 to 199.9" + + + + + 0 to 804” 0 to 2815” 0 to 804” 0 to 4022” 0 to 201" 0 to 402" 0.00 to 20.43 m 0.00 to 19.99 m 0.00 to 20.43 m 0.00 to 19.99 m 0.00 to 5.11m 0.00 to 10.22m 0.00 to 14.75" 0.00 to 29.5" 0.00 to 19.99cm + 0.00 to 19.99cm + 0.0 to 37.5cm 0.0 to 75.0cm 0.00 to 7.25psi 0.00 to 14.50psi 0.0 to 199.9 mm + + + 0.0 to 255.3 mm 0 to 1320 mm 0.0 to 71.5 m 0.00 to 0.73” 0.00 to 3.83” 0.00 to 59.00” 0.00 to 19.99” + 0.0 to 102.2 m 0.00 to 59.00” 0.00 to 0.36 psi 0.00 to 19.99 mm 0.00 to 19.99 cm + + 0.0 to 97.5 mm 0.0 to 150.0 cm 0.00 to 1.88 psi 0.00 to 29.00 psi 0.00 to 5.25 m 0.00 to 19.99” + 0.0 to 206.7” PSI 0.0 to 100.0kPa 0.0 to 199.9” 0.00 to 19.99 mm 0.00 to 18.75 mm 0 to 1000mbar + + m Hg 20x8P 0.0 to 295.3” 0.00 to 19.99 cm 0.00 to 7.50m + 0.0 to 150.0 cm 0.00 to 19.99 psi 0.00 to 29.00 psi 0.00 to 19.99 psi + + 0.0 to 101.5 psi 0.0 to 145.0 psi Key Features Pressure ranges from 1mbar to 10bar (0.40218 inH2O to 4021.8 inH2O) Pressure range configurable from 10 to 500bar with an external transducer (2024P & 2084P only)* Logging and leak testing Autoranging displays for precise readings Selectable auto switch-off 2 year warranty Overrange protection IP67 (1m depth for 30 mins) BSI Cert 229/000132 Negative and positive reading *We can supply a range of suitable pressure transducers according to the pressure range. Transducer accuracy needs to be combined with instrument for total accuracy. Version 1.3 TECHNICAL DATA SHEET Common Specification Operating Temperature 0°C to +50°C/+14°F to 122°F (ambient) Battery Type Two AA or equivalent cells (not supplied) Battery Life Typically 200 hours Low Battery Check Display symbol appears on display 12.7mm / 0.5" custom L.C.D. Overrange/Underrange 'Out' shows on display Environmental Specifications IP67 (as std) with hose connected Auto Switch-Off Time 12 minutes Dimensions 155 x 67 x 40mm/6.1 x 2.6 x 1.6” 180g/6.4oz Weight Instrument accuracies 0.15%rdg +0.15%fs +1 digit From -10°C to +50°C/+14°F to 0.3%rdg +0.3%fs + 1 digit (-Ve Pressures) +122°F The overall performance of the instrument is obtained by combining the stated accuracy and any uncertainty due to the measurement process Pressure Application 2000P Series Option Table 2000P 25mbar 2001P 130mbar 2007P 500mbar 2008P 1 bar 2002P 2bar 2003P 7bar 350mbar 750mbar 1bar 2 bar 4bar 10bar Backlight Out of range • • • • • • • • • • • • 2005P 2bar absolute 4bar absolute • • Zeroing Hold Smoothing Units of Pressure Range Lock Max/Min Zeroing Absolute Averaging Leak Testing • • • • • • • • • • • • • Operating Range Overrange 2020P 25mbar 2021P 130mbar 2027P 500mbar 2028P 1 bar 2022P 2bar 2023P 7bar 350mbar 750mbar 1bar 2 bar 4bar 10bar • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • Logging Operating Range 2026P 2024P 0 to 10bar † External transducer 2025P 2bar 2080P 25mbar 2081P 130mbar 2087P 500mbar 2088P 1bar 2082P 2bar 2083P 7bar 2086P 2084P 0 to 10bar † External transducer 2085P 2bar 350mbar 750mbar 1bar 2bar 4bar 10bar 21bar * • • • • • • • • • • • • • • • • 4bar absolute • • • • • 21bar * Backlight Out of range • • • • 4bar absolute • • Zeroing Hold Smoothing Units of Pressure Range Lock Max/Min Zeroing Absolute Averaging Leak Testing • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • Overrange Logging
2003P 价格&库存
很抱歉,暂时无法提供与“2003P”相匹配的价格&库存,您可以联系我们找货
