5.0SMDJ36A-H
5.0SMDJ36A-H
    YINT(音特电子)
    SMC(DO-214AB)
    ACQE-101
5.0SMDJ36A-H 数据手册
Automotive and High Reliability TVS Diodes Surface Mount – 5000W > 5.0SMDJ-H Series Trustworthy electronic circuit protection expert 5.0SMDJ-H Series General Information The 5.0SMDJ-H series is designed to protect voltage sensitive components from high voltage, high energy transients. They have excellent clamping capability, high surge capability, low zener impedance and fast response time. The 5.0SMDJ-H series is supplied in YINT Semiconductor’s exclusive, cost-effective, highly reliable and is ideally suited for use in communication systems, automotive, numerical controls , process controls, medical equipment, business machines, power supplies Molded plastic and many other industrial/consumer Applications. glass passivated junction. Features Applications ●Case: DO-214AB/SMC TVS ●For surface mounted applications in order to optimize board space. protection of I/O Interfaces, VCC bus ●Polarity: Color band denoted positive end (cathode) except Bidirectional. and other vulnerable circuits used in ●Typical failure mode is short from over-specified voltage or current Telecom, ●High Temperature soldering:260°C/10 seconds at terminals. Consumer electronic applications. devices are ideal for Computer, Industrial ●Terminal: Solder plated, solderable per MIL-STD-750,Method 2026. ●AEC-Q101 qualified Electrical Characteristics (@ TA = 25°C Unless Otherwise Noted) Parameter Minimum Peak Pulse Power Dissipation (T = 1 ms) (note 2) Symbol Value Unit PPK 5000 Watts IFSM 300 Amps PM(AV) 6.5 Watts VF 5 Volts TJ -55 to +150 °C TSTG -55 to +150 °C Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) (Note 3) Steady State Power Dissipation @ TL = 50 °C Maximum Instantaneous Forward Voltage @ I PP = 50 A (For Unidirectional Units Only) Operating Temperature Range Storage Temperature Range 1. Non-repetitive current pulse, per Pulse Waveform graph and derated above TA = 25 °C per Pulse Derating Curve. 2. Thermal Resistance Junction to Lead. 3. 8.3 ms Single Half-Sine Wave duty cycle = 4 pulses maximum per minute (unidirectional units only). 4. Single Phase, Half Wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20 %. www.yint.com.cn Rev:19.3 1 the and Automotive and High Reliability TVS Diodes Surface Mount – 5000W > 5.0SMDJ-H Series Electrical Characteristics (TA = 25 °C unless otherwise noted) Trustworthy electronic circuit protection expert Part Part Number Number (Bi) (Uni) 5.0SMDJ11CA-H Breakdown Reverse MARKING Stand off Voltage VR Voltage VBR Test (Volts)@IT Current IT(mA) Maximum Maximum Maximum Reverse Peak Pulse Clamping Leakage IR Current Voltage VC @ VR(μA) Ipp(A) @I pp(V) BI UNI (Volts) Min .V Max.V 5.0SMDJ11A-H HBEN HPEN 11.0 12.20 13.50 10 800 275.00 18.2 5.0SMDJ12CA-H 5.0SMDJ12A-H HBEP HPEP 12.0 13.30 14.70 10 800 252.00 19.9 5.0SMDJ13CA-H 5.0SMDJ13A-H HBEQ HPEQ 13.0 14.40 15.90 10 500 233.00 21.5 5.0SMDJ14CA-H 5.0SMDJ14A-H HBER HPER 14.0 15.60 17.20 10 200 216.00 23.2 5.0SMDJ15CA-H 5.0SMDJ15A-H HBES HPES 15.0 16.70 18.50 1 100 205.00 24.4 5.0SMDJ16CA-H 5.0SMDJ16A-H HBET HPET 16.0 17.80 19.70 1 50 193.00 26.0 5.0SMDJ17CA-H 5.0SMDJ17A-H HBEU HPEU 17.0 18.90 20.90 1 20 181.00 27.6 5.0SMDJ18CA-H 5.0SMDJ18A-H HBEV HPEV 18.0 20.00 22.10 1 10 172.00 29.2 5.0SMDJ20CA-H 5.0SMDJ20A-H HBEW HPEW 20.0 22.20 24.50 1 2 155.00 32.4 5.0SMDJ22CA-H 5.0SMDJ22A-H HBEX HPEX 22.0 24.40 26.90 1 2 141.00 35.5 5.0SMDJ24CA-H 5.0SMDJ24A-H HBEZ HPEZ 24.0 26.70 29.50 1 2 129.00 38.9 5.0SMDJ26CA-H 5.0SMDJ26A-H HBFE HPFE 26.0 28.90 31.90 1 2 119.00 42.1 5.0SMDJ28CA-H 5.0SMDJ28A-H HBFG HPFG 28.0 31.10 34.40 1 2 110.00 45.4 5.0SMDJ30CA-H 5.0SMDJ30A-H HBFK HPFK 30.0 33.30 36.80 1 2 103.00 48.4 5.0SMDJ33CA-H 5.0SMDJ33A-H HBFM HPFM 33.0 36.70 40.60 1 2 93.90 53.3 5.0SMDJ36CA-H 5.0SMDJ36A-H HBFP HPFP 36.0 40.00 44.20 1 2 86.10 58.1 5.0SMDJ40CA-H 5.0SMDJ40A-H HBFR HPFR 40.0 44.40 49.10 1 2 77.60 64.5 5.0SMDJ43CA-H 5.0SMDJ43A-H HBFT HPFT 43.0 47.80 52.80 1 2 72.10 69.4 5.0SMDJ45CA-H 5.0SMDJ45A-H HBFV HPFV 45.0 50.00 55.30 1 2 68.80 72.7 5.0SMDJ48CA-H 5.0SMDJ48A-H HBFX HPFX 48.0 53.30 58.90 1 2 64.70 77.4 5.0SMDJ51CA-H 5.0SMDJ51A-H HBFZ HPFZ 51.0 56.70 62.70 1 2 60.70 82.4 5.0SMDJ54CA-H 5.0SMDJ54A-H HBGE HPGE 54.0 60.00 66.30 1 2 57.50 87.1 5.0SMDJ58CA-H 5.0SMDJ58A-H HBGG HPGG 58.0 64.40 71.20 1 2 53.50 93.6 5.0SMDJ60CA-H 5.0SMDJ60A-H HBGK HPGK 60.0 66.70 73.70 1 2 51.70 96.8 5.0SMDJ64CA-H 5.0SMDJ64A-H HBGM HPGM 64.0 71.10 78.60 1 2 48.60 103.0 5.0SMDJ70CA-H 5.0SMDJ70A-H HBGP HPGP 70.0 77.80 86.00 1 2 44.30 113.0 5.0SMDJ75CA-H 5.0SMDJ75A-H HBGR HPGR 75.0 83.30 92.10 1 2 41.40 121.0 5.0SMDJ78CA-H 5.0SMDJ78A-H HBGT HPGT 78.0 86.70 95.80 1 2 39.70 126.0 5.0SMDJ85CA-H 5.0SMDJ85A-H HBGV HPGV 85.0 94.40 104.00 1 2 36.50 137.0 5.0SMDJ90CA-H 5.0SMDJ90A-H HBGX HPGX 90.0 100.00 111.00 1 2 34.30 146.0 5.0SMDJ100CA-H 5.0SMDJ100A-H HBGZ HPGZ 100.0 111.00 123.00 1 2 30.90 162.0 5.0SMDJ110CA-H 5.0SMDJ110A-H HBHE HPHE 110.0 122.00 135.00 1 2 28.30 177.0 5.0SMDJ120CA-H 5.0SMDJ120A-H HBHG HPHG 120.0 133.00 147.00 1 2 26.00 193.0 5.0SMDJ130CA-H 5.0SMDJ130A-H HBHK HPHK 130.0 144.00 159.00 1 2 24.00 209.0 5.0SMDJ150CA-H 5.0SMDJ150A-H HBHM HPHM 150.0 167.00 185.00 1 2 20.60 243.0 5.0SMDJ160CA-H 5.0SMDJ160A-H HBHB HPHP 160.0 178.00 197.00 1 2 19.30 259.0 5.0SMDJ170CA-H 5.0SMDJ170A-H HBHR HPHR 170.0 189.00 209.00 1 2 18.20 275.0 www.yint.com.cn Rev:19.3 2 Automotive and High Reliability TVS Diodes Surface Mount – 5000W > 5.0SMDJ-H Series Trustworthy electronic circuit protection expert Functional Diagram Uni-directional Bi-directional I-V Curve Characteristics Bi-directional Uni-directional Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP V RWM IR V BR IT Working Peak Reverse Voltage Maximum Reverse Leakage Current @V RWM Breakdown Voltage @ IT Test Current www.yint.com.cn Rev:19.3 3 Automotive and High Reliability TVS Diodes Surface Mount – 5000W > 5.0SMDJ-H Series Trustworthy electronic circuit protection expert Rating & Characteristic Curves Figure 2- Maximum Non-Repetitive Surge Current Figure 1- Pulse Derating Curve Figure 3- Typical Junction Capacitance Figure 4- Pulse Waveform Figure 6- Pulse Rating Curve Figure 5- Steady State Power Derating Curve www.yint.com.cn Rev:19.3 4 Automotive and High Reliability TVS Diodes Surface Mount – 5000W > 5.0SMDJ-H Series PACKAGE OUTLINE DIMENSIONS in inches (millimeters) Trustworthy electronic circuit protection expert DO-214AB(SMC) Mounting Pad Layout Disclaimer Specifications are subject to change without notice. The device characteristics and parameters in this data sheet can and do vary in different applications and actual device performance may vary over time. Users should verify actual device performance in their specific applications. www.yint.com.cn Rev:19.3 5
