ESD12VAP
ESD12VAP
    YINT(音特电子)
    SOT-23
    反向截止电压(Vrwm) 12 反向漏电流(IR) 1 击穿电压(VBR) 13.3 钳位电压(Vc)@Ipp 19 峰值脉冲功率(Ppp) 300 结电容(Cj)@57MHz 60
ESD12VAP 数据手册
ESD Protection Diode ESD12VAP Trustworthy electronic circuit protection expert ESD12VAP Description ESD12VAP is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. Features ●Ultra low leakage Functional Diagram ●Operating voltage: 12V ●Package: SOT-23 ●Protects one bidirectional line or two unidirectional ●Low clamping voltage ●Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±8kV – IEC61000-4-4 (EFT) 40A (5/50ns) Applications – IEC61000-4-5 (Lightning) 5A (8/20μs) ●Portable Electronics ●Cellular Handsets and Accessories ●Industrial Controls ●Portable instrumentation ●Set-Top Box ●Peripherals Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Unit PPP 300 Watts ±15 KV ±8 KV VESD ESD per IEC 61000−4−2 (Contact) Lead Soldering Temperature TL 260 (10 sec) °C Operating Temperature Range TJ -55 to +150 °C TSTJ -55 to +150 °C Storage Temperature Range www.yint.com.cn 1 Rev:19.3 ESD Protection Diode ESD12VAP Trustworthy electronic circuit protection expert Electrical Characteristics (TA = 25 °C unless otherwise noted) Parameter Reverse Stand-off Voltage Reverse Breakdown Voltage Reverse Leakage Current Symbol Conditions Min. Typ. VRWM VBR IR Units 12 V 15.8 V =VRWM 1 μA 19 V It = 1mA VR Max. 13.3 Clamping Voltage VC @IPP Junction Capacitance CJ VR=0V, f = 1MHz 60 pF Characteristics Curves Figure 1- Power Derating Curve Figure 2- ESD Pulse Waveform (according to IEC 61000-4-2) Figure3- 8/20µs Pulse Waveform www.yint.com.cn 2 Rev:19.3 ESD Protection Diode ESD12VAP Trustworthy electronic circuit protection expert ACKAGE OUTLINE DIMENSIONS in millimeters (inches) :SOT-23 Mounting Pad Layout Disclaimer Specifications are subject to change without notice. The device characteristics and parameters in this data sheet can and do vary in different applications and actual device performance may vary over time. Users should verify actual device performance in their specific applications. www.yint.com.cn 3 Rev:19.3
ESD12VAP 价格&库存
很抱歉,暂时无法提供与“ESD12VAP”相匹配的价格&库存,您可以联系我们找货
