ESD Protection Diode
ESD5V0D5B
Trustworthy electronic circuit protection expert
ESD5V0D5B
Description
ESD5V0D5B
is
designed
to
protect
voltage
sensitive
components from ESD and transient voltage events. Excellent
clamping capability, low leakage, and fast response time, make
these parts ideal for ESD protection on designs where board
space is at a premium.
Features
●100 Watts Peak Pulse Power per Line (tp=8/20µs)
Functional Diagram
●Operating voltage: 5V
●Low leakage current
●Package: SOD-523
●Low clamping voltage
●Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±15kV
Applications
Contact discharge: ±8kV
●Cell Phone Handsets and Accessories
– IEC61000-4-4 (EFT) 40A (5/50ηs)
●Microprocessor based equipment
●Personal Digital Assistants (PDA's)
●Notebooks, Desktops, and Servers
●Portable Instrumentation
●Peripherals
●Pagers
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Value
PPP
200
Watts
±15
KV
±8
KV
VESD
ESD per IEC 61000−4−2 (Contact)
Unit
Lead Soldering Temperature
TL
260 (10 sec)
°C
Operating Temperature Range
TJ
-40 to +125
°C
TSTJ
-55 to +150
°C
Storage Temperature Range
www.yint.com.cn
1
Rev:19.3
ESD5V0D5B
Electrical Characteristics (TA = 25 °C unless otherwise noted)
Parameter
Reverse Stand-off
Voltage
Reverse Breakdown
Voltage
Reverse Leakage
Current
Symbol
Conditions
Min.
VRWM
VBR
It = 1mA
IR
Clamping Voltage
VC
Junction Capacitance
CJ
VR
IPP=5A,
IPP=MAX,
=VRWM
tP = 8/20μs
tP = 8/20μs
VR=0V, f = 1MHz
5.6
Typ.
Max.
Units
5
V
7.8
V
1
μA
11.6
V
18.6
V
25
pF
Characteristics Curves
Figure 1- Power Derating Curve
Figure 2- ESD Pulse Waveform
(according to IEC 61000-4-2)
Figure3- 8/20µs Pulse Waveform
www.yint.com.cn
2
Rev:19.3
ESD5V0D5B
ACKAGE OUTLINE DIMENSIONS in millimeters (inches) :SOD523
Disclaimer
Specifications are subject to change without notice.
The device characteristics and parameters in this data sheet can and do vary in different applications and actual device
performance may vary over time.
Users should verify actual device performance in their specific applications.
www.yint.com.cn
3
Rev:19.3
很抱歉,暂时无法提供与“ESD5V0D5B”相匹配的价格&库存,您可以联系我们找货
