ESD36VD3B
ESD36VD3B
    YINT(音特电子)
    SOD-323
    ESD 36V截止
ESD36VD3B 数据手册
ESD36VD3B Trustworthy electronic circuit protection expert ESD36VD3B Description ESD36VD3B is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. Because of its small size, it is suited for use in cellular phones, MP3 players, digital cameras and many other portable applications where board space is at a premium Features Functional Diagram ●Ultra low leakage: nA level ●Operating voltage: 36V ●Package: SOD-323 ●Low clamping voltage ●Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Applications Contact discharge: ±30kV ●Cell Phone Handsets and Accessories – IEC61000-4-4 (EFT) 40A (5/50ns) ●Microprocessor based equipment – IEC61000-4-5 (Lightning) 12A (8/20μs) ●Personal Digital Assistants (PDA’s) ●Notebooks, Desktops, and Servers ●Portable Instrumentation ●Peripherals ●Pagers Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Symbol Peak Pulse Power (8/20µs) PPP ESD per IEC 61000−4−2 (Air) VESD ESD per IEC 61000−4−2 (Contact) Value Unit 320 Watts ±30 KV ±30 KV Lead Soldering Temperature TL 260 (10 sec) °C Operating Temperature Range TJ -55 to +150 °C TSTJ -55 to +150 °C Storage Temperature Range 1 www.yint.com.cn VRE 5.0 ESD36VD3B Trustworthy electronic circuit protection expert Electrical Characteristics (TA = 25 °C unless otherwise noted) Parameter Reverse Stand-off Voltage Reverse Breakdown Voltage Reverse Leakage Symbol Conditions Min. Typ. VRWM VBR It = 1mA 38 40 Units 36 V 45 V 1 μA IR VR Clamping Voltage VC IPP=1A, tP = 8/20μs 60 V Clamping Voltage VC IPP=4A, tP = 8/20μs 75 V Junction Capacitance CJ 50 pF Current =VRWM Max. VR=0V, f = 1MHz 25 Characteristics Curves Figure 1- Power Derating Curve Figure 2- ESD Pulse Waveform (according to IEC 61000-4-2) 2 www.yint.com.cn VRE 5.0 ESD36VD3B Trustworthy electronic circuit protection expert Figure3- 8/20µs Pulse Waveform ACKAGE OUTLINE DIMENSIONS in millimeters (inches) :SOD323 Mounting Pad Layout Disclaimer Specifications are subject to change without notice. The device characteristics and parameters in this data sheet can and do vary in different applications and actual device performance may vary over time. Users should verify actual device performance in their specific applications. 3 www.yint.com.cn VRE 5.0
