ESD5V0D3B
ESD5V0D3B
    YINT(音特电子)
    SOD-323
    5V
ESD5V0D3B 数据手册
ESD Protection Diode ESD5V0D3B Trustworthy electronic circuit protection expert ESD5V0D3B Description ESD5V0D3B is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. Because of its small size, it is suited for use in cellular phones, MP3 players, digital cameras and many other portable applications where board space is at a premium Features Functional Diagram ●Ultra low leakage: nA level ●Operating voltage: 5V ●Package: SOD-323 ●Low clamping voltage ●Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Applications Contact discharge: ±8kV ●Cell Phone Handsets and Accessories – IEC61000-4-4 (EFT) 40A (5/50ns) ●Microprocessor based equipment – IEC61000-4-5 (Lightning) 12A (8/20μs) ●Personal Digital Assistants (PDA’s) ●Notebooks, Desktops, and Servers ●Portable Instrumentation ●Peripherals ●Pagers Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Unit PPP 320 Watts ±15 KV ±8 KV VESD ESD per IEC 61000−4−2 (Contact) Lead Soldering Temperature TL 260 (10 sec) °C Operating Temperature Range TJ -55 to +150 °C Storage Temperature Range TSTJ -55 to +150 °C www.yint.com.cn 1 Rev:19.3 ESD Protection Diode ESD5V0D3B Trustworthy electronic circuit protection expert Electrical Characteristics (TA = 25 °C unless otherwise noted) Parameter Reverse Stand-off Voltage Reverse Breakdown Voltage Reverse Leakage Current Symbol Conditions Min. VRWM It = 1mA VR IR VC Junction Capacitance CJ Max. 5 VBR Clamping Voltage Typ. 6 =VRWM Units V V 10 μA IPP=1A, tP = 8/20μs 9.8 V IPP=24A, tP = 8/20μs 17 V 260 pF VR=0V, f = 1MHz Characteristics Curves Figure 1- Power Derating Curve Figure 2- ESD Pulse Waveform (according to IEC 61000-4-2) Figure3- 8/20µs Pulse Waveform www.yint.com.cn 2 Rev:19.3 ESD Protection Diode ESD5V0D3B Trustworthy electronic circuit protection expert CKAGE OUTLINE DIMENSIONS in millimeters (inches) :SOD323 Mounting Pad Layout Disclaimer Specifications are subject to change without notice. The device characteristics and parameters in this data sheet can and do vary in different applications and actual device performance may vary over time. Users should verify actual device performance in their specific applications. www.yint.com.cn 3 Rev:19.3
ESD5V0D3B 价格&库存
很抱歉,暂时无法提供与“ESD5V0D3B”相匹配的价格&库存,您可以联系我们找货
ESD5V0D3B
  • 10+0.45717
  • 100+0.35349
  • 300+0.30165
库存:100
