600-1007
600-1007
    INTEGRITY
    MOP FRAME, 394MM X 99MM X 146MM
600-1007 数据手册
Technical Data Sheet Integrity® Mop Frame & Hardware The Integrity® Mop Frame & Hardware is made of high-grade type 304 stainless steel, low profiled for easy cleaning in hard to reach areas. Industry leading design with quick squeeze, frame-locking mechanism allows for easy changing of mop and sponge heads. Continual surface contact at any angle permits mopping in “S” motion, accurately balanced for non-flipping. Swivel also locks into any position by tightening wing-nut. FEATURES • Quick squeeze, easy mop head changing mechanism • Autoclavable at 121°C for 30 minutes • Extremely durable stainless steel components • 16” (40cm) x 5” (12.7cm) coverage area with a single pass • Designed specifically for use in controlled environments • Type 304 Stainless Steel BENEFITS • Mop frame compatible with polymer or stainless steel handles • Impervious to most chemicals, will not rust, corrode or oxidize PRODUCT CODE SIZE PACK SIZE 600-1007 394mm x 99mm x 146mm (15 1/2” x 3 7/8” x 5 3/4”) Each Call +44 (0) 1473 836205 Email info@integritycleanroom.com /integrity_eu /company/integrity-cleanroom IIMPORTANT NOTICE: This data sheet and its contents (the “Information”) belong to Integrity® Cleanroom or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but Integrity® Cleanroom assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where Integrity® Cleanroom was aware of the possibility of such loss or damage arising) is excluded. © Integrity® Cleanroom. PAGE 1 Mop Frame Hardware | 26 May 2015 2:28 PM
600-1007 价格&库存
很抱歉,暂时无法提供与“600-1007”相匹配的价格&库存,您可以联系我们找货
