607-0004
607-0004
    INTEGRITY
    INTEGRITY - 607-0004 - Technical Paper, ISO 5 Cleanroom, A4, 75gsm, Plain, Green, 250 Sheets - Techn...
607-0004 数据手册
Technical Data Sheet A4 Technical Paper FEATURES AND BENEFITS • ISO 6 Cleanroom processed • Excellent IPA resistant material • Compatible with most inks in writing without smearing • Ultra low ionic contamination • Ultra low particle and fiber generation • Excellent heat resistant material for laser printing and photocopiers • ROHS compliant • Available sterile by Gamma Irradiation APPLICATIONS • Note taking • Printing • Form & Logsheet SPECIFICATIONS CLEAROOM PAPER (73 g/m2) TESTING CONDITIONS 25°C, 55% RH PARAMETERS MEASUREMENT STANDARD TESTING VALUE TESTING METHOD Weight g/m 70±3.0 70.0 gsm Width (CD) mm 210mm±0.5mm 210 Length (MD) mm 297mm±0.5mm 297 Thickness µm 89±4 91.0 Bulk cm3/g 1.24±0.1 1.25 Smoothness (front side) Sec 40±10 42↑ Bekk Type Smoothness (Reverse side) Sec 40±10 38↑ Bekk Type Size degree Sec 5 Sec↑ 15 Wet Tensile St. MD 1.0↑ 1.16 CD 0.8↑ 1 MD 6.0↑ 7.90 CD 4.5↑ 5.30 Dry Tensile St. 2 Micrometer Horizontal Type (Kg/15mm) PARTICLE DATA PARTICE (DRY) TESTING METHOD TESTING RESULT MEASUREMENT ≥0.3µm IES-RP-CC003.3 221 count/ft3 ≥0.5µm IES-RP-CC003.3 139 count/ft3 ≥1.0µm IES-RP-CC003.3 82.4 count/ft3 Call +44 (0) 1473 836205 Email info@integritycleanroom.com /integrity_eu /company/integrity-cleanroom IIMPORTANT NOTICE: This data sheet and its contents (the “Information”) belong to Integrity® Cleanroom or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but Integrity® Cleanroom assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where Integrity® Cleanroom was aware of the possibility of such loss or damage arising) is excluded. © Integrity® Cleanroom. PAGE 1 607-0001-technical-paper.indd | 6 February 2018 2:14 PM Technical Data Sheet PRODUCT CODE DESCRIPTION COLOUR GSM SIZE PACK SIZE 607-0005 Cleanroom Paper White 73 A4 250 sheets 607-0001 Cleanroom Paper Blue 73 A4 250 sheets 607-0002 Cleanroom Paper Pink 73 A4 250 sheets 607-0003 Cleanroom Paper Yellow 73 A4 250 sheets 607-0004 Cleanroom Paper Green 73 A4 250 sheets 607-0007 Cleanroom Paper White 72 A5 250 sheets NOTE: *Data shown are typical values and should not be used as specifications. Call +44 (0) 1473 836205 Email info@integritycleanroom.com /integrity_eu /company/integrity-cleanroom IIMPORTANT NOTICE: This data sheet and its contents (the “Information”) belong to Integrity® Cleanroom or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but Integrity® Cleanroom assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where Integrity® Cleanroom was aware of the possibility of such loss or damage arising) is excluded. © Integrity® Cleanroom. PAGE 2 607-0001-technical-paper.indd | 6 February 2018 2:14 PM
607-0004 价格&库存
很抱歉,暂时无法提供与“607-0004”相匹配的价格&库存,您可以联系我们找货
