600-0203
600-0203
    INTEGRITY
    INTEGRITY - 600-0203 - Wipe, 120GSM, Polyester, 229mm Length, 229mm Width, 150 Pack
600-0203 数据手册
Technical Data Sheet 100% Polyester Wipe DESCRIPTION The Heavy weight laser sealed edged Polyester wiper is a double knit 100% continuous-filament polyester. All four edges are laser cut and sealed to prevent particle and fibre release. FEATURES • Laser sealed edge ensures ultra low lint and particle level • Good absorbency and wiping efficiency • Resists abrasion under rigorous use • Available in various sizes and packaging configurations • Solvent safe, double bagged and vacuum cleanroom packed • Available sterile by gamma irradiation APPLICATIONS • Suitable for class ISO4 – ISO6 cleanrooms • Cleaning of surfaces to control submicron particles, fibres, and chemical residue TECHNICAL DATA PERFORMANCE CHARACTERISTICS Basis Weight 120gsm Thickness (micrometer) 0.48mm Absorbency Rate & Capacity (IEST-RP-CC 004.3) Sorptive capacity 320ml/m2 Rate (Drop Disappearance mtd.) 0.5 sec CONTAMINATION CHARACTERISTICS Nonvolatile Residue, NVR (IEST-RP-CC 004.3,Analysis for Unspecified Extractable Matter) IPA Extractant 0.52 mg/g DIW Extractant 0.14 mg/g FTIR Ion Content (IEST-RP-CC 004.3, Thorough Extraction Method) Chloride (Cl) Nitrates (NO3) Nitrite (NO2) Sulphate (SO4) Sodium (Na) Potassium (K) Magnesium (Mg) Calcium (Ca) NO Silicon Oil, Amide and DOP detected 0.000174 mg/g 0.000019 mg/g 0.000025 mg/g 0.000083 mg/g 0.000312 mg/g 0.000227 mg/g 0.000049 mg/g 0.000021 mg/g Call +44 (0) 1473 836205 Email info@integritycleanroom.com /integrity_eu /company/integrity-cleanroom IMPORTANT NOTICE: This data sheet and its contents (the “Information”) belong to the Integrity or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Integrity assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Integrity was aware of the possibility of such loss or damage arising) is excluded. © Integrity. PAGE 1 600-0220 120gsm 100 polester | 4 December 2014 10:59 AM Technical Data Sheet Releasable Particles LPC ( > 0.5 um) (IEST-RP-CC 004.3-orbital shake mtd) 6.5 x 106 particles/m2 APC (Helmke Drum Test @10rpm); > 0.5 um 50 counts/pc./cfm -9”x9” (IES-RP-CC003.2) 9.71 x 102 counts/m2/cfm NOTE: *Data shown are typical values and should not be used as specifications. Order Code Pack Qty Size 600-0230 200 wipes 7”x7” – Stack 600-0210 150 wipes 12”x12” – Bulk 600-0203 150 wipes 9”x9” – Bulk Call +44 (0) 1473 836205 Email info@integritycleanroom.com /integrity_eu /company/integrity-cleanroom IMPORTANT NOTICE: This data sheet and its contents (the “Information”) belong to the Integrity or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Integrity assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Integrity was aware of the possibility of such loss or damage arising) is excluded. © Integrity. PAGE 2 600-0220 120gsm 100 polester | 4 December 2014 10:59 AM
600-0203 价格&库存
很抱歉,暂时无法提供与“600-0203”相匹配的价格&库存,您可以联系我们找货
