600-2009
600-2009
    INTEGRITY
    INTEGRITY - 600-2009 - Cleanroom Notebook, Non-Sterile, Lined, Rounded Corners, White, A5 Size
600-2009 数据手册
Technical Data Sheet Integrity® Cleanroom Notebook The Integrity® Spiral-bound cleanroom notebook featuring antistatic covers to prevent static charge build-up • Cleanroom processed and cleanroom packaged with cleanroom bags • Cleaned and packed in controlled ISO 5 Cleanroom Environment COVERS • High-density polypropylene material which offer impregnated antistatic properties • Precision cut with round edge corners • Excellent chemical resistance material PAPER • Durable Clean Image cleanroom paper • Low-sodium inks printed • 50 sheets per book BENEFITS HIGH DENSITY POLYPROPYLENE COVERS • Excellent chemical resistance material • Antistatic material to prevent static charge build-up • Round corners construction to prevent tearing of gloves by sharp edges APPLICATIONS • Note-taking in critical environment • Logbook TECHNICAL DATA CLEANROOM PAPER CONTAMINATION CHARACTERISTICS Ion Chromatography (IC) ANION TYPICAL VALUE CATION TYPICAL VALUE Cl 0.3191 ug/cm² Li NOT DETECTED F 0.0016 ug/cm² Na 2.23 ug/cm² Br NOT DETECTED NH4 NOT DETECTED NO 0.0017 ug/cm² K 0.11 ug/cm² NO 0.0128 ug/cm² Mg 0.04 ug/cm² PO4 NOT DETECTED Ca 1.10 ug/cm² SO 0.1517 ug/cm² 2 3 4 Liquid Particle Count (LPC) Wet Test ( > 0.5 um) 190 counts/cm2 Airborne Particle Count (APC) Dry Test (0.5um) 50 counts/ft3/cm2 Call +44 (0) 1473 836205 Email info@integritycleanroom.com /integrity_eu /company/integrity-cleanroom IMPORTANT NOTICE: This data sheet and its contents (the “Information”) belong to the Integrity or are licensed to it. No licence is granted for the use of it other than for information purposes in connection with the products to which it relates. No licence of any intellectual property rights is granted. The Information is subject to change without notice and replaces all data sheets previously supplied. The Information supplied is believed to be accurate but the Integrity assumes no responsibility for its accuracy or completeness, any error in or omission from it or for any use made of it. Users of this data sheet should check for themselves the Information and the suitability of the products for their purpose and not make any assumptions based on information included or omitted. Liability for loss or damage resulting from any reliance on the Information or use of it (including liability resulting from negligence or where the Integrity was aware of the possibility of such loss or damage arising) is excluded. © Integrity. PAGE 1 integrity-note-book | 4 December 2014 11:37 AM Technical Data Sheet COVER Extractable Organic Silicon NOT DETECTED Amide NOT DETECTED ESD PROPERTIES Surface Resistivity Static Charge Generation PRODUCT CODE 4.9 x 1010 ohms/sq
600-2009 价格&库存
很抱歉,暂时无法提供与“600-2009”相匹配的价格&库存,您可以联系我们找货
