83-14719
83-14719
    ARDUINO
    ARDUINO - 83-14719 - Arduino Starter Kit
83-14719 数据手册
The Arduino Starter Kit Here is The Arduino Starter Kit! This kit walks you through the basics of using the Arduino in a hands-on way. You'll learn through building several creative projects. The kit includes a selection of the most common and useful electronic components with a book of 15 projects. Starting the basics of electronics, to more complex projects, the kit will help you control the physical world with sensor and actuators. The projects in the kit are: 01 GET TO KNOW YOUR TOOLS an introduction to the concepts you'll need to use this kit 02 SPACESHIP INTERFACE design to control panel for your startship 03 LOVE-O-METER measure how hot-blooded you are 04 COLOR MIXING LAMP produce any color with a lamp that uses light as an input 05 MOOD CUE clue people in to how you're doing 06 LIGHT THEREMIN create a musical instrument you play by waving your hands 07 KEYBOARD INSTRUMENT play music and make some noise with this keyboard 08 DIGITAL HOURGLASS a light-up hourglass that can stop you from working too much 09 MOTORIZED PINWHEEL a color wheel that will have your head spinning 10 ZOETROPE create a mechanical animation you can play forward or reverse 11 CRYSTAL BALL a mystical tour to answer all your tough question 12 KNOCK LOCK tap out the secret code to open the door 13 TOUCHY-FEEL LAMP a lamp that responds to your touch 14 TWEAK THE ARDUINO LOGO control your personal computer from your Arduino 15 HACKING BUTTONS create a master control for all your devices! Once you’ve mastered this knowledge, you’ll have a palette of software and circuits that you can use to create something beautiful, and make someone smile with what you invent. Then build it, hack it and share it. Because Arduino is you! What in the kit is listed below. Click on the name of the component to download the datasheet of the part. This document will describe the design and functionality of the component. 1 Arduino Projects Book (170 pages) 1 1 1 1 1 70 2 6 3 10 1 1 1 1 1 8 8 8 3 1 1 1 1 2 5 2 5 3 5 5 3 1 20 5 5 5 10 5 5 Arduino UNO board rev.3 USB cable Breadboard Easy-to-assemble wooden base 9v battery snap Solid core jumper wires Stranded jumper wires Photoresistor [VT90N2 LDR] Potentiometer 10kilohm Pushbuttons Temperature sensor [TMP36] Tilt sensor alphanumeric LCD (16x2 characters) LED (bright white) LED (RGB) LEDs (red) LEDs (green) LEDs (yellow) LEDs (blue) Small DC motor 6/9V Small servo motor Piezo capsule [PKM17EPP-4001-B0] H-bridge motor driver [L293D] Optocouplers [4N35] Transistor [BC547] Mosfet transistors [IRF520] Capacitors 100nF Capacitors 100uF Capacitor 100pF Diodes [1N4007] Transparent gels (red, green, blue) Male pins strip (40x1) Resistors 220 ohm Resistors 560 ohm Resistors 1 kilohm Resistors 4.7 kilohm Resistors 10 kilohm Resistors 1 megohm Resistors 10 megohm
83-14719 价格&库存
很抱歉,暂时无法提供与“83-14719”相匹配的价格&库存,您可以联系我们找货
