A000058
A000058
    ARDUINO
    ARDUINO WIFI SHIELD W/ ANTENNA
A000058 数据手册
Shield – WiFi The Arduino WiFi Shield connects your Arduino to the internet wirelessly. Connect it to your wireless network by following a few simple instructions to start controlling your world through the internet. As always with Arduino, every element of the platform – hardware, software and documentation – is freely available and open-source. This means you can learn exactly how it's made and use its design as the starting point for your own circuits. Check out the reference page of the WiFi library to understand how the shield can easily provide an internet connection to your Arduino board. Technical Specifications          Requires and Arduino board (not included) Operating voltage 5V (supplied from the Arduino Board) Connection via: 802.11b/g networks Encryption types: WEP and WPA2 Persoanl Connection with Arduino on SPI port on-board micro SD slot ICSP headers FTDI connection for serial debugging of WiFi shield Micro-USB for updating WiFi shield firmware The WiFi Shield communicates with Arduino using the SPI bus (through the ICSP header), so is compatible with any of the boards that have this type of bus. This version of WiFi shield have an integrated antenna on the PCB, what you have to do is just connect the shield to the Arduino.
A000058 价格&库存
很抱歉,暂时无法提供与“A000058”相匹配的价格&库存,您可以联系我们找货
