AKX00016
AKX00016
    ARDUINO
    BCM2837B0 Application Processors and SOC Evaluation Kit 1400MHz CPU 1GB RAM
AKX00016 数据手册
PRO GATEWAY L o R a ® C O N N E C T I V I TY ARDUINO.CC OPEN-SOURCE ELECTRONICS PLATFORM A R DUI NO GATE WAY W ITH L OR A C ON N E C TIV IT Y, IS THE D O O R TO ENTER I NTO THE L OR A W OR L D. D IS C OV E R THE E N D L E SS POS S I BI LI TI E S OF THE G ATE WAY A N D THE A R D U IN O C R E AT E PL ATFOR M The Arduino gateway kit provides LoRa (Long Range) connectivity using ultra-long range and high interference immunity on the 868 MHz radio bands. The gateway offers up to 8 LoRa Channels in the 868Mhz frequency allowing it to receive up to 8 LoRa packets simultaneously making it the ideal device to use in LoRaWAN gateways applications. It is designed around the SX1301 from Semtech, which enables robust connection between the gateway and a massive amount of wireless end-points spread over a very wide range of distances. It has the Listen Before Talk capability. When enabled, the device monitors channels continuously and transmits only if the channel is free. It's the perfect companion of the Arduino MKR WAN 1300 . Installation, provisioning and remote management the Gateway are made incredibly simple through the our Arduino Create platform. This gateway enables people to leverage the LoRa connectivity in many use cases: TECH SPECS WHAT’S IN YOUR ARDUINO PRO GATEWAY? • A UT OMAT E D ME T E R R E A DI NG • E NVI R ONME NTA L MONI T OR • S MA R T CI T I E S • HOME A ND BU I LDI NG A UT OMATIO N • W I R E LE S S A L A R M A ND S E CU R IT Y SYSTEM • I NDUS T R I A L MONI T OR I NG A ND CO N TRO L • LONG R A NG E I R R I G AT I ON S YS TEM • A G R I CU LT U R A L MONI T OR I NG Raspberry Pi 3 model B+ • LOR A G AT E WAY CA PE A DA PT E R • CHI PS E T SEMTECH SX1301 WITH TWO SX12 57 • OPE R AT I NG VOLTA G E 5V • CU R R E NT CONS U MPT I ON 815MA ( TX@ +2 7DBM); 60 0 MA (RX) • MODUL AT I ON L O RA® SP READ SP ECTRUM, F SK, GFSK • OPE R AT I NG FR E Q U E NCY 868MHZ (EU) • OPE R AT I NG T E MPE R AT U R E - 40 °C TO + 85°C • R F OU T PU T POW E R UP TO +2 7DBM • S E NS I T I VI T Y UP TO -137DBM Arduino Radio Module Adapter FEATURES: LoRa® Radio Module • LI S T E N BE FOR E TA LK (LBT ) CAPABIL IT Y • ON-BOA R D U FL A NT E NNA • 8 LOR A CHA NNE LS • FPG A S UPPOR T S LOR A S PE CT RAL SCAN ASSEMBLY AND SETUP INSTRUCTIONS: 1 2 1 . I nse rt the S D c ard the n attach t h e fan as sh own in the p ic tu re the n sc re w to ge ther t h e en closur e pan el w ith the S MA p igtail. 2. W ire th e Fan cables wit h t h e c lip s as sho w n in the im age abov e. 5 6 3 4 3. Con n ect t h e SMA pigt ail t o t h e X1 an t en n a con n ect or. 4. In ser t t h e boar ds in t o t h e en cl o s ure Impor t an t : make sur e t o t ake n ot e of t h e code fro m t h e st icker on t h e r adio module, befor e placing i t in side t h e en closur e (you’ ll n eed it lat er). KIT BOX INCLUDES 1 Aluminium Enclosure 1 Raspberry Pi 3 model B+ 1 Arduino Radio Module Adapter 1 LoRa® Radio module 5 . Co nne c t the ante nna. 6. Plug- in t h e power supply and the Ethe rne t Cab le . 7 . Visit: CREATE.ARDUINO.CC/GETTING-STARTED/LORAGW 1 Fan 1 Ethernet cable 1 AC power adapter (with multi plug) Fo llo w the instru c tio ns and e n t er t h e code you n ot ed in the 4 . Yo u ’re all se t! We lc o me t o t h e L oRa® wor ld! 1 Micro UFL to SMA Pigtail 1 SMA Antenna 1 MicroSD card For further info, visit: STORE.ARDUINO.CC/ARDUINO-PRO-GATEWAY
AKX00016 价格&库存
很抱歉,暂时无法提供与“AKX00016”相匹配的价格&库存,您可以联系我们找货
