ABX00028
ABX00028
    ARDUINO
    ABX00028
ABX00028 数据手册
31/5/2019 https://store.arduino.cc/usa/datasheet/index/index/url_key/nano-every-reseller/ Arduino Nano Every Turn your ideas into a reality quickly with the new Arduino Nano Every. SKU: ABX00028 Country of origin: IT Taric: 85235210 EECN: EAR-99 HTS: 8542310001 Overview This small, robust and powerful board has the same classic Nano footprint loved worldwide. It can be programmed with the easy to use Arduino IDE available offline and online. Get started in minutes with thousands of sketches available in open-source or write your own: it is the perfect choice for your everyday projects. Based on the ATMega4809 AVR processor, the Arduino Nano Every is flexible to the requirements of your design. It can be used in a breadboard when mounting pin headers, or as a SMT directly soldered on a PCB thanks to its castellated pads. An SAMD11 ARM Cortex M0+ processor acts as a high performance USB to serial converter that can be re-programmed by skilled users to expand further the applications of this board. Tech Specs This board is based on the ATMega4809 microcontroller. Clock Flash SRAM EEPROM 20MHz 48KB 6KB 256byte https://store.arduino.cc/usa/datasheet/index/index/url_key/nano-every-reseller/ 1/3 31/5/2019 https://store.arduino.cc/usa/datasheet/index/index/url_key/nano-every-reseller/ A ATSAMD11D14A Processor takes care of the USB to SERIAL communication and it is connected to the following pins of the ATMega4809 microcontroller. ATMega4809 Pin ATMega4809 Acronym SAMD11 Pin SAMD11 Acronym Description 9 PB05 15 PA22 SAMD11 TX -> ATMega4809 RX 8 PB04 16 PA23 ATMega4809 TX -> SAMD11 RX 41 UPDI 12 PA15 UPDI RX 11 PA14 UPDI TX The board has a two 15 pins connectors - one on each side -, pin to pin compatible with the original Arduino Nano. Pin 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 Funcion D13 +3V3 AREF A0/DAC0 A1 A2 A3 A4/SDA A5/SCL A6 A7 +5V RST GND VIN TX RX RST GND D2 D3/PWM D4 D5/PWM Type Digital Power Out Analog Analog Analog Analog Analog Analog Analog Analog Analog Power Out Digital In Power Power In Digital Digital Digital Power Digital Digital Digital Digital Description SPI SCK, GPIO Internally generated power output to external devices Analog Reference; can be used as GPIO ADC in/DAC out; can be used as GPIO ADC in; can be used as GPIO ADC in; can be used as GPIO ADC in; can be used as GPIO ADC in; I2C SDA; Can be used as GPIO ADC in; I2C SCL; Can be used as GPIO ADC in; can be used as GPIO ADC in; can be used as GPIO Internally generated power output to external devices Active low reset input (duplicate of pin 18) Power Ground Vin Power input USART TX; can be used as GPIO USART RX; can be used as GPIO Active low reset input (duplicate of pin 13) Power Ground GPIO GPIO; can be used as PWM GPIO GPIO; can be used as PWM https://store.arduino.cc/usa/datasheet/index/index/url_key/nano-every-reseller/ 2/3 31/5/2019 https://store.arduino.cc/usa/datasheet/index/index/url_key/nano-every-reseller/ 24 25 26 27 28 29 30 D6/PWM D7 D8 D9/PWM D10/PWM D11/MOSI D12/MISO Digital Digital Digital Digital Digital Digital Digital GPIO; can be used as PWM GPIO GPIO GPIO; can be used as PWM GPIO; can be used as PWM SPI MOSI; can be used as GPIO SPI MISO; can be used as GPIO https://store.arduino.cc/usa/datasheet/index/index/url_key/nano-every-reseller/ 3/3
ABX00028 价格&库存
很抱歉,暂时无法提供与“ABX00028”相匹配的价格&库存,您可以联系我们找货
ABX00028
  • 2+114.10740
库存:115
ABX00028
    • 1+119.67220
    库存:48
