ABX00041
ABX00041
    ARDUINO
    ATSAMD11,BNO055,MP6522 电机控制器/驱动器 电源管理 Arduino Nano 平台评估扩展板
ABX00041 数据手册
Arduino Nano Motor Carrier Code: ABX00041 / Barcode: 7630049202245 Nano Motor Carrier provides a quick and easy way to connect and control motors in your Engineering Kit R2. Overview Nano Motor Carrier is the perfect add-on for the Nano 33 IoT board as it works to extend and power up its functionality. Designed to facilitate motor control, Nano Motor Carrier takes care of the electronics required to control motors, allowing students to focus on prototyping and building their projects. It can also be used to connect other actuators and sensors via a series of 3-pin male headers. The board features are: on board 9 axis accelerometer, gyroscope and magnetometer. It includes a battery charger for single cell Li-ion batteries and it contains 2 ports for quadrature encoder counting. To use the carrier, simply connect it to a Nano 33 board and attach the motors you need for your project. Once connected, attach the USB cable to the Nano 33 IoT. Download Arduino Motor Carrier library from the library manager and you’re all set up to start programming and controlling your motors using the motor drivers. When working with motors, you need an external power source to feed the motor drivers and power the motors. You can do this by connecting a 1 cell Li-Ion battery to the battery connector or by using an external power source. Technical Specifications MICROCONTROLLER MOTOR DRIVERS (X4) MAX INPUT VOLTAGE (POWER TERMINALS) MAX OUTPUT CURRENT PER MOTOR DRIVER MOTOR DRIVER OUTPUT VOLTAGE OVER TEMPERATURE SHUTDOWN PROTECTION (FOR DC MOTOR DRIVERS) BATTERY CHARGING MAX BATTERY CHARGING CURRENT POWER TERMINALS (CONNECTORS) SERVO CONNECTOR ENCODER INPUTS DC MOTOR CONTROL 3V DIGITAL/ANALOG SENSOR INPUT/OUTPUT IMU ATSAMD11 ( Arm Cortex-M0+ @48 Mhz) MP6522 4V (1S Li-Ion Battery) 500 Amp 12V Yes Yes 500mA (configurable) XT-30 and 2POS terminal block 4 terminals 2 ports 4 ports 4 ports BNO055 9axis Acc/Gyr/Mag
ABX00041
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚集电极,6脚发射极。
4. 参数特性:工作温度范围为-40~85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现电信号的传输,具有抗干扰能力强、响应速度快等特点。
6. 应用信息:广泛应用于工业控制系统、医疗设备、通信设备等领域。
7. 封装信息:采用DIP6封装形式。
ABX00041 价格&库存
很抱歉,暂时无法提供与“ABX00041”相匹配的价格&库存,您可以联系我们找货
