8492K1
8492K1
    SAFRAN(赛峰)
    SAFRAN POWER - 8492K1 - Switch Finger Guard, Safran Electric & Power
8492K1 数据手册
SWITCH GUARDS & SHIELDS Switch Guards MIL-G-7703 and Industrial Grade FEATURES • For use with 2 or 3 position switches • Lever covers molded in various colors • Cover closure transfers toggle lever. See code number for details. • Metal and molded covers • Flush and One Hole Mounted (OHM) mounting styles • MS approved and QPL'd per MIL-G7703 • Covers are molded out of Thermoset Code 1 Code 2, 3, 16, 17 Code 7, 8, 10-14 Code 4, 5 Code 18-25 Code 26-29 • • molding materials Guard covers are spring loaded to either close or lock in open position One hole mounting and three hole mounting available Code 9 • Keyway orientation variations offered on some guards Code 6 Code 15 SELECTION TABLE Switch Guard Code Number 1 Switch Mounting Flush Switch Positions Marking  Color  Hinged End Other End Location of Keyway Tab Military Part Number 3 Phenolic Red — — — MS25223-1 8496K1 Lever Material Catalog Number 2 Flush 2 Phenolic Red — — — MS25224-2 8497K2 3 Flush 3 Phenolic Red — — — MS25225-2 8498K2 4 Flush 2 Metal Green — — — MS25452-1 8499K1 5 Flush 2 Metal Green EMERGENCY — NAF47851-1 K2 — 6 Flush/OHM 2 or 3 Metal Black — — MS25221-1 8495K1 7 OHM 3 Phenolic Red — — Opp. Hinged End MS25214-2 8494K2 8 OHM 3 Phenolic Red — — Hinged End MS25214-3 K3 9 OHM 3 Phenolic Red — — Opp. Hinged End MS25223-2 8496K2 10 OHM 2 Phenolic Red — — Opp. Hinged End MS25224-1 8497K1 11 2 Phenolic Red — — Hinged End MS25224-3 8497K3 12 2 Phenolic Red ON OFF Opp. Hinged End — 3 Phenolic Red — — Opp. Hinged End MS25225-1 14 3 Phenolic Red — — Hinged End MS25225-3 K3 15 2 or 3 Metal Black — — Opp. Pin Hole MS24417-1 8492K1 2 or 3 Phenolic Red — — Opp. Hinged End MS27752-1 8498K6 3 Phenolic Red — — MS25214-1 8494K1 13 OHM 16 17 Flush — K7 8498K1 18 3 Red — — Hinged End 19 3 Red — — Opp. Hinged End K5 Red — — Hinged End K6 20 OHM 2 Metal 8493K4 21 2 Red — — Opp. Hinged End K7 22 3 Black — — Hinged End K8 23 3 Black — — Opp. Hinged End 24 2 Black — — Hinged End Black — — Opp. Hinged End K11 Red — — Right Side K12 25 OHM 26 29 Metal 3 27 28 2 3 OHM 3 Metal 3 8493K9 K10 Red — — Left Side K13 Black — — Right Side K14 Black — — Left Side K15  Will not return lever when mounting plate is over .0625 [1,58] thick. Custom lettering or symbols available. Guard has no moving lever.  Optional colors: black phenolic available for 8497. Where other colors are required, they are sprayed over standard color. F2 SAFRAN ELECTRICAL & POWER SWITCH GUARDS & SHIELDS Switch Guards MIL-G-7703 and Industrial Grade SPECIFICATIONS Code 1 and 9 • For three-position switches • Returns lever to center position from either extreme • Guard housing is spring loaded to retain closed position Code 17 • For three-position flush mount switches • Guard lever remains fixed in open or closed position • Return lever to center position from either extreme Code 2, 10, 11 and 12 • For full throw single throw switches • Returns lever to OFF position Code 7 and 8 • For three-position switches • Returns lever to center position from either extreme • Guard housing remains fixed in open and closed position Code 3, 13 and 14 • For three-position switches • Returns lever from up position to center position • Will not change toggle position when it is in down position Code 4 and 5 • For two-position full throw switches • Permits locking toggle in extreme up position Code 6 and 15 • Insertion of pin through guard prevents accidental operation • Prevents transfer of single throw switches • Permits operation from first position to center on three-posi - tion switches Code 16 • For two- or three-position switches • Closing guard does not affect toggle position Code 18, 19, 22 and 23 • For three-position switches • Returns lever from up position to center position • Will not change toggle position when it is in down position Code 20, 21, 24 and 25 • For two-position full throw switches • Returns lever from up position to down position Code 26-29 • For three-position switches • With both guards in closed position, switch toggle lever is locked in center position. With one guard each in open and closed position, switch can be toggled between center and open guard position; with both guards in open position, switch can be toggled between left, center, and right position. SAFRAN ELECTRICAL & POWER F3 SWITCH GUARDS & SHIELDS Switch Guard Application Table Switch Catalog Number Switch Guard Code Number Switch Catalog Number 8200K7 8201K6, K14 8209K6 8210K7 8211K7 1, 2, 3, 6 2, 8837K4 & K94 K5 & K95 K6 & K96 K7 & K97 K8 & K98 Switch Guard Code Number 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 15, 16, 21, 25 13, 15, 16, 19, 23, 26-29 7, 9, 13, 15, 16 11, 15, 16 8212K6 8500K1 K2 K3 K4 3, 6 7, 9, 13, 14, 15, 16, 18, 19, 22, 23, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 20, 21, 24, 25 8837K9 & K99 K10 & K910 K11 & K911 8838K1 & K91 K2 & K92 10, 12, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 7, 9, 13, 14, 15, 16, 18, 19, 22, 23, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 8500K5 K6 K7 K8 K9 10, 11, 15, 16, 21, 25 13, 15, 16, 19, 23, 26-29 7, 9, 13, 15, 16 11, 15, 16 10, 12, 15, 16, 21, 25 8838K3 & K93 K4 & K94 K5 & K95 K6 & K96 K7 & K97 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 15, 16, 21, 25 13, 15, 16, 19, 23, 26-29 7, 9, 13, 15, 16 8500K10 K11 K12 K13 8501K1 10, 11, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 15, 16 13, 15, 16, 19, 23 7, 9, 13, 14, 15, 16, 18, 19, 22, 23, 26-29 8838K8 & K98 K9 & K99 K10 & K910 K11 & K911 8868K1, K51, K61 11, 15, 16 10, 12, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 7, 9, 13, 14, 15, 16, 18, 19, 22, 23, 26-29 8501K2 K3 K4 K5 K6 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 15, 16, 21, 25 13, 15, 16, 19, 23, 26-29 8868K2, K52, K62 K3, K53, K63 K4, K54, K64 K5, K55, K65 K6, K56, K66 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 15, 16, 21, 25 9, 13, 15, 16 8501K7 K8 K9 K10 K11 7, 9, 13, 15, 16 11, 15, 16 10, 12, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 8868K7, K57, K67 K8, K58, K68 8869K1, K1X, K51, K51X, K61, K61X K2, K2X, K52, K52X, K62, K62X K3, K3X, K53, K53X, K63, K63X 10, 12, 15, 16, 21, 25 10, 12, 15, 16, 21, 25 7, 9, 13, 14, 15, 16, 18, 19, 22, 23, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 8501K12 K13 K14 thru K19 8502K1 K2 15, 16 13, 15, 16, 19, 23 7, 9, 13, 15, 16, 18, 19, 22, 23, 26-29 7, 9, 13, 14, 15, 16, 18, 19, 22, 23, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 8869K4, K4X, K54, K54X, K64, K64X K5, K5X, K55, K55X, K65, K65X K6, K6X, K56, K56X, K66, K66X K7, K7X, K57, K57X, K67, K67X 8867K8, K8X, K58, K58X, K68, K68X 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 15, 16, 21, 25 7, 9, 13, 15, 16 10, 12, 15, 16, 21, 25 10, 12, 15, 16, 21, 25 8502K3 K4 K5 K6 K7 13, 14, 15, 16, 18, 19, 22, 23, 26-29 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 15, 16, 21, 25 13, 15, 16, 19, 23, 26-29 7, 9, 13, 15, 16 8869 K9, K9X, K59, K59X, K69, K69X K10, K10X, K510, K510X,K610,K610X K11, K11X, K511, K511X, K611, K611X 8854K1 8854K2 7, 9, 13, 14, 15, 16, 18, 19, 22, 23, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 7, 9, 13, 14, 15, 16, 18, 19, 22, 23, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 8502K8 K9 K10 K11 K12 11, 15, 16 10, 12, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 15, 16 8854K3 K4 K5 K6 K7 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 15, 16, 21, 25 7, 9, 13, 15, 16 10, 12, 15, 16, 21, 25 8502K13 K15 thru K17 8700K15 8701K14 8709K15 13, 15, 16, 19, 23 7, 9, 13,15, 16, 18, 19, 22, 23, 26-29 1, 3, 6, 17 4, 5, 6 3, 6 8854K8 K9 K10 K11 10, 12, 15, 16, 21, 25 7, 9, 13, 14, 15, 16, 18, 19, 22, 23, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 8718K5 8740K12 8742K10 8744K10 8790K4 3, 2, 3, 2, 6 8570K1-16, -20 K2-16, -20 K3-16, -20 K4-16, -20 K5-16, -20 7, 9, 13, 14, 16, 18, 19, 22, 23, 26-29 13, 14, 16, 18, 19, 22, 26-29 13, 14, 16, 18, 19, 22, 26-29 10, 11, 16, 20, 21, 24, 25 10, 11, 16, 21, 25 8792K3 8836K1 & K91 K2 & K92 K3 & K93 K4 & K94 6 7, 9, 13, 14, 15, 16, 18, 19, 22, 23, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 20, 21, 24, 25 8570K6-16, -20 K7-16, -20 K8-16, -20 K9-16, -20 K10-16, -20 13, 16, 19, 23, 26-29 7, 9, 13, 16 11, 16 10, 12, 16, 21, 25 10, 11, 16, 21, 25 8836K5 & K95 K6 & K96 K7 & K97 K8 & K98 K9 & K99 10, 11, 15, 16, 21, 25 13, 15, 16, 19, 23, 26-29 7, 9, 13, 15, 16 11, 15, 16 10, 12, 15, 16, 21, 25 8570K11-16, -20 K12-16, -20 K13-16, -20 8571K1-16, -20 K2-16, -20 10, 11, 16, 21,25 16 13, 16, 19, 23 7, 9, 13, 14, 16, 18, 19, 22, 23, 26-29 13, 14, 16, 18, 19, 20, 26-29 8836K10 & K910 K11 & K911 8837K1 & K91 K2 & K92 K3 & K93 10, 11, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 7, 9, 13, 14, 15, 16, 18, 19, 22, 23, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 8571K3-16, -20 K4-16, -20 K5-16, -20 K6-16, -20 K7-16, -20 13, 14, 16, 18, 19, 22, 26-29 10, 11, 16, 20, 21, 24, 25 10, 11, 16, 21, 25 13, 16, 19, 23, 26-29 7, 9, 13, 16 3, 6, 17 4, 5, 6 6 6 6 6 6, 17 6  Listing covers only those switches that can be used with a switch guard. F4 SAFRAN ELECTRICAL & POWER SWITCH GUARDS & SHIELDS Switch Guard Application Table Switch Catalog Number Switch Guard Code Number Switch Catalog Number Switch Guard Code Number 8571K8-16, -20 K9-16, -20 K10-16, -20 K11-16, -20 K12-16, -20 11, 16 10, 12, 16, 21, 25 10, 11, 16, 21, 25 10, 11, 16, 21, 25 16 8520K1 K4 K9 8521K1 K4 7, 9, 13, 14, 15, 16, 18, 19, 22, 23, 26-29 10, 11, 15, 16, 20, 21, 24, 25 10, 12, 15, 16, 21, 25 7, 9, 13, 14, 15, 16, 18, 19, 22, 23 10, 11, 15, 16, 20, 21, 24, 25 8571K13-16, -20 K17-16, -20 K18-16, -20 K19-16, -20 8572K1-16, -20 13, 16, 19, 23 7, 9, 13, 16, 18, 19, 22, 23, 26-29 13, 14, 16, 18, 19, 22, 26-29 13, 14, 16, 18, 19, 22, 26-29 7, 9, 13, 14, 16, 18, 19, 22, 23, 26-29 8521K9 8522K1 K4 K9 8526K2 10, 12, 15, 16, 20, 21, 24, 25 7, 9, 13, 14, 15, 16, 18, 19, 22, 23, 26-29 10, 11, 15, 16, 20, 21, 24, 25 10, 12, 15, 16, 21, 25 13, 14, 15, 16, 18, 19, 22, 26-29 8572K2-16, -20 K3-16, -20 K4-16, -20 K5-16, -20 K6-16, -20 13, 14, 16, 18, 19, 22, 26-29 13, 14, 16, 20, 21, 24, 25 10, 11, 16, 20, 21, 24, 25 10, 11, 16, 21, 25 13, 16, 19, 23, 26-29 8526K3 K5 8527K2 K3 K5 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 21, 25 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 21, 25 8572K7-16, -20 K8-16, -20 K9-16, -20 K10-16, -20 K11-16, -20 7, 9, 13, 16 11, 16 10, 12, 16, 21, 25 10, 11, 16, 21, 25 10, 11, 16, 21, 25 8528K2 K3 K5 8530K1, K31, K91 K2, K32, K92 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 21, 25 7, 9, 13, 14, 15, 16, 18, 19, 22, 23, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 8572K12-16, -20 K13-16, -20 K15-16, -20 K16-16, -20 K17-16, -20 16 13, 16, 19, 23 7, 9, 13, 16, 18, 19, 22, 23, 26-29 13, 14, 16, 18, 19, 22, 26-29 13, 14, 16, 18, 19, 22, 26-29 8530K3, K33, K93 K4, K34, K94 K5, K35, K95 K6, K36, K96 K7, K37, K97 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 15, 16, 21, 25 13, 15, 16, 19, 23, 26-29 7, 9, 13, 15, 16 8510K1 K2 K3 K4 K5 7, 9, 13, 14, 15, 16, 18, 19, 22, 23, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 16, 21, 25 8530K8, K38, K98 K9, K39, K99 K10, K310, K910 K11, K311, K911 K12, K312, K912 11, 15, 16 10, 12, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 15, 16 8510K6 K7 K8 K9 K10 13, 15, 16, 18, 23, 26-29 7, 9, 13, 15, 16 11, 15, 16 10, 12, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 8530 K13, 8531 K1, K2, K3, K4, K313, K913 K31, K91 K32, K92 K33, K93 K34, K94 13, 15, 16, 19, 23 7, 9, 13, 14, 15, 18, 19, 22, 23, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 20, 21, 24, 25 8510K11 K12 K13 8511K1 K2 10, 11, 15, 16, 21, 25 15, 16 13, 15, 16, 19, 23 7, 9, 13, 14, 15, 16, 18, 19, 22, 23, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 8531 K5, K6, K7, K8, K9, K35, K95 K36, K96 K37, K97 K38, K98 K39, K99 10, 11, 15, 16, 21, 25 13, 15, 16, 19, 23, 26-29 7, 9, 13, 15, 16 11, 15, 16 10, 12, 15, 16, 21, 25 8511K3 K4 K5 K6 K7 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 15, 16, 21, 25 13, 15, 16, 19, 23, 26-29 7, 9, 13, 15, 16 8531K10, K310, K910 K11, K311, K911 K12, K312, K912 K13, K313, K913 K14, K314, K914 10, 11, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 15, 16 13, 15, 16, 19, 23 7, 9, 13, 15, 16, 18, 19, 22, 23, 26-29 8511K8 K9 K10 K11 K12 11, 15, 16 10, 12, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 15, 16 8531K15, K315, K915 K16, K316, K916 K17, K317, K917 K18, K318, K918 K19, K319, K919 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 7, 9, 13, 15, 16, 18, 19, 22, 23, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 8511K13 K14 K15 K16 8512K1 13, 15, 16, 18, 23 7, 9, 13, 15, 16, 18, 19, 22, 23, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 7, 9, 13, 14, 15, 16, 18, 19, 22, 23, 26-29 8532K1, K31, K91 K2, K32, K92 K3, K33, K93 K4, K34, K94 K5, K35, K95 7, 9, 13, 14, 15, 16, 18, 19, 22, 23, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 15, 16, 21, 25 8512K2 K3 K4 K5 K6 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 15, 16, 21, 25 13, 15, 16, 19, 23, 26-29 8532K6, K36, K96 K7, K37, K97 K8, K38, K98 K9, K39, K99 K10, K310, K910 13, 15, 16, 19, 23, 26-29 7, 9, 13, 15, 16 11, 15, 16 10, 12, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 8512K7 K8 K9 K10 K11 7, 9, 13, 15, 16 11, 15, 16 10, 12, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 8532K11, K311, K911 K12, K312, K912 K13, K313, K913 K15, K315, K915 K16, K316, K916 10, 11, 15, 16, 21, 25 15, 16 13, 15, 16, 19, 23 7, 9, 13, 15, 16, 18, 19, 22, 23, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 8512K12 K13 K15 K16 K17 15, 16 13, 15, 16, 19, 23 7, 9, 13, 15, 16, 18, 19, 22, 23, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 8532K17, K317, K917 13, 14, 15, 16, 18, 19, 22, 26-29  Listing covers only those switches that can be used with a switch guard. SAFRAN ELECTRICAL & POWER F5 SWITCH GUARDS & SHIELDS Switch Guard Application Table Switch Catalog Number Switch Guard Code Number A3-10 SERIES A3-32 SERIES A3-33 SERIES A3-40 SERIES A3-200-01 10, 12, 15, 16, 21, 25 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 15, 16, 20, 21, 24, 25 7, 9, 13, 14, 15, 16, 18, 19, 22, 23 A3-200-02 -03 -04 -05 13, 14, 15, 16, 18, 19, 13, 14, 15, 16, 18, 19, 13, 14, 15, 16, 18, 19, 10, 11, 15, 16, 20, 21, A3-200-07 A3-202-01 -02 -03 -04 10, 11, 15, 16, 21, 25 7, 9, 13, 14, 15, 16, 18, 19, 22, 23 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 A3-202-05 -06 -07 A3-204-01 -02 10, 11, 16, 20, 21, 24, 25 10, 11, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 7, 9, 13, 14, 15, 16, 18, 19, 22, 23 13, 14, 15, 16, 18, 19, 22, 26-29 A3-204-03 -04 -05 -06 -07 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 A3-206-01 -02 -03 -04 -05 7, 9, 13, 14, 15, 16, 18, 19, 22, 23 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 20, 21, 24, 25 22, 22, 22, 24, 26-29 26-29 26-29 25  Listing covers only those switches that can be used with a switch guard. F6 SAFRAN ELECTRICAL & POWER Switch Catalog Number A3-206-06 -07 A3-208-01 -02 -03 A3-208-04 -05 -06 -07 A3-210-02 -03 -04 -05 -06 A3-210-07 A3-212-01 -02 -03 -04 A3-212-05 -06 -07 A3-214-01 -02 A3-214-03 -04 -05 -06 -07 Switch Guard Code Number 10, 11, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 7, 9, 13, 14, 15, 16, 18, 19, 22, 23 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 7, 9, 13, 14, 15, 16, 18, 19, 22, 23 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 15, 16, 21, 25 10, 11, 15, 16, 21, 25 7, 9, 13, 14, 15, 16, 18, 19, 22,23 12, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 13, 14, 15, 16, 18, 19, 22, 26-29 10, 11, 15, 16, 20, 21, 24, 25 10, 11, 15, 16, 21, 25 10, 11, 15, 16, 21, 25
8492K1 价格&库存
很抱歉,暂时无法提供与“8492K1”相匹配的价格&库存,您可以联系我们找货
