8556K32X32M
8556K32X32M
    SAFRAN(赛峰)
    SAFRAN POWER - 8556K32X32M - 8556K32X32M 07C1205
8556K32X32M 数据手册
ECONOSWITCH SEALED ROCKER SWITCHES Series - 8554, 8555, 8556 Econoswitch Sealed Rocker Switches CURRENT RATINGS SPECIFICATIONS Features • Environmentally sealed • 1, 2 and 4 pole circuitry • 2 & 3 position with maintained and momentary action • Pinned rocker button • Rocker button style and color variations • Multi-circuits • Thermoplastic rocker buttons in opaque colors (serrated and smooth face) • Panel mounting variations Flush panel Sub-panel Snap-in • Watertight per MIL-STD-108E and designed to meet IP68 • UL recognized and CSA certified • Temperature range: -50°F to +150°F (-46°C to + 66°C) • Life: 50,000 operations at rated load 100,000 operations mechanical life • Three standard types of terminals Screw 6-32 UNC-2A Solder lug .125 [3,17] dia. hole Spade .250 [6,35] x .032 [0.82] thick No. of Poles Catalog Number Type of Operation 115VAC 60 or 400Hz 28VDC Resistive Inductive Load Load 1 2 4 8554 8555 8556 Lamp Load Resistive Inductive Lamp Load Load Load Maintained 20 15 5 15 10 3 Momentary 15 10 4 11 7 2 4 Maintained 20 15 7 15 15 Momentary 18 10 5 11 8 2 Maintained 20 12 5 15 15 4 Momentary 18 10 4 11 8 2 Note: See page C28 for UL and CSA current ratings. when ordering specify . . . • Catalog number of base switch followed by suffix letters and numbers for mounting bracket, rocker color and style as listed in selection table. Order Example: 8555K1 Base Switch S 32 M Mounting Rocker Style Bracket Rocker Color 8555K1S32M Complete Number One Pole Snap-in Bezel Mounting Two Pole Flush Panel Mounting Four Pole Sub-Panel Mounting SELECTION TABLE Circuit with Lever in . . . Up Position Center Position BASE CATALOG NUMBER Down Position (Keyway) SUFFIX NUMBERS & LETTERS - ADD TO BASE CATALOG NUMBER MOUNTING BRACKET Screw Terminals Solder Terminals Spade Terminals ON OFF ON NONE ON* ON* ON* OFF* ON* ON* NONE NONE 8554K1 K9 K4 K6 K5 K2 K7 K10 K11 K3 K12 K13 8554K91 K99 K94 K96 K95 K92 K97 K910 K911 K93 K912 K913 8554K31 K39 K34 K36 K35 K32 K37 K310 K311 K33 K312 K313 ON OFF ON NONE ON* ON* ON* OFF* ON* ON* NONE NONE ON ON* ON* ON ON* ON* 8555K1 K9 K4 K6 K5 K2 K7 K10 K11 K3 K12 K13 K14 K15 K16 K17 K18 K19 8555K91 K99 K94 K96 K95 K92 K97 K910 K911 K93 K912 K913 K914 K915 K916 K917 K918 K919 8555K31 K39 K34 K36 K35 K32 K37 K310 K311 K33 K312 K313 K314 K315 K316 K317 K318 K319 Frame Style Mounting Code Letter Holes ROCKER STYLE Style ROCKER COLOR Code No. Color Code Letter 32 White M Black V Red T One Pole ON ON ON ON ON * ON NONE ON OFF ON * ON ON OFF NONE NONE OFF NONE OFF OFF NONE NONE OFF ON ON ON ON ON ON ON * ON NONE ON OFF ON * ON ON ON ON * ON ON ON * ON OFF NONE NONE OFF NONE OFF OFF NONE NONE OFF ON ON ON ON ON ON ON ON Two Pole * Momentary Contact. Sub-Panel MountingClearance Holes 0.152 Sub-Panel Mounting6-32 Tapped Holes UNC-2B Flush Panel MountingClearance Holes 0.152 R W Serrated S Flush Panel 6-32 MountingUNC-2B Tapped Holes T Snap-in Bezel --Mounting X Smooth 33 SAFRAN ELECTRICAL & POWER “Safran Electrical & Power Proprietary Information. Information contained in this document is Safran Electrical & Power Proprietary Information and is disclosed in confidence. It is the property of Safran Electrical & Power and shall not be used, disclosed to others, or reproduced without the express written agreement of Safran Electrical & Power. If consent is given for reproduction in whole or in part, this notice set forth on each page of this document shall appear in any such reproduction in whole or in part. Unauthorized export or re-export is prohibited.” C13 ECONOSWITCH SEALED ROCKER SWITCHES Series - 8554, 8555, 8556 Econoswitch Sealed Rocker Switches SELECTION TABLE Circuit with Lever in . . . Up Position Center Position BASE CATALOG NUMBER Down Position (Keyway) SUFFIX NUMBERS & LETTERS - ADD TO BASE CATALOG NUMBER MOUNTING BRACKET Screw Terminals Solder Terminals Spade Terminals 8556K1 K9 K4 K6 K5 K2 K7 K10 K11 K3 K12 K13 K15 K16 K17 8556K91 K99 K94 K96 K95 K92 K97 K910 K911 K93 K912 K913 K915 K916 K917 8556K31 K39 K34 K36 K35 K32 K37 K310 K311 K33 K312 K313 K315 K316 K317 Style Mounting Code Letter Holes ROCKER STYLE Style Code No. ROCKER COLOR Color Code Letter Four Pole ON ON ON ON ON * ON NONE ON OFF ON * ON ON ON ON * ON OFF NONE NONE OFF NONE OFF OFF NONE NONE OFF ON ON ON ON ON ON OFF ON NONE ON* ON* ON* OFF* ON* ON* NONE NONE ON ON* ON* Sub-Panel MountingClearance Holes Sub-Panel MountingTapped Holes Flush Panel MountingClearance Holes 0.152 6-32 UNC-2B 0.152 R W Serrated White M Black V Red T 32 S Smooth Flush Panel MountingTapped Holes 6-32 UNC-2B T Snap-in Bezel Mounting --- X 33 * Momentary contact. See pages C26-C27 and C29-C31 for circuit diagrams.  Incomplete Catalog Number - add suffix letters and numbers for Mounting Bracket, Rocker Style and Rocker Color - see "When Ordering Specify." STANDARD 0.00 = inches [0,0] = mm Dimensions for reference only. C14 SAFRAN ELECTRICAL & POWER “Safran Electrical & Power Proprietary Information. Information contained in this document is Safran Electrical & Power Proprietary Information and is disclosed in confidence. It is the property of Safran Electrical & Power and shall not be used, disclosed to others, or reproduced without the express written agreement of Safran Electrical & Power. If consent is given for reproduction in whole or in part, this notice set forth on each page of this document shall appear in any such reproduction in whole or in part. Unauthorized export or re-export is prohibited.” ECONOSWITCH SEALED ROCKER SWITCHES Series - 8554, 8555, 8556 Econoswitch Sealed Rocker Switches MOUNTING DIMENSIONS - ONE POLE / 8554 RECOMMENDE D PANEL CUT -OUT .690 .718 .670 MTG. HOLES 2 REQ. 6-32 UNC-2B .152[3,86 1.625 1.250 1.937 KEYW AY .61R .388 .545 .253 6-32 UNC-2A TERMINAL SCREW MAX. 2.96 SUB P ANEL MTG. FLUSH P ANEL MTG. MAX. 1.86 MAX. 1.56 .125[3,18] DIA. HOLE SUB P ANEL MTG. MAX. 1.33 ,SEMS SUB P ANEL MTG. MAX. FLUSH P ANEL MTG. 1.63 MAX. 1.35 .098 SUB P ANEL MTG. MAX. 1.65 FLUSH P ANEL MTG. .382 .674 .250[6,35]X.032[0,81] THK .594 1.25 1 2 3 SOLDER LUG 2 1 3 SCREW TERMINAL 1 2 3 SPADE TERMINAL 90-6912.AI MOUNTING DIMENSIONS - SNAP-IN BEZEL ONE POLE / 8554 RECOMMENDED PANEL CUT-OUT .900 ± .015 .680 .670 MAX .830 1.19 RECOMMENDED PANEL THICKNESS: .040 TO .140 1.45 1.550 ± .015 .61 ± .01R KEYWAY .218 ± .065 .336 ± .065 .030 ± .015 NOTE: WIRES ATTACHED TO THIS SWITCH MUST HAVE RING LUGS TO FIT #5 SCREW. DO NOT USE SPADE LUG OR WRAP WIRE AROUND TERMINAL SCREW. 1.55 ± .07 .04 1.89 MAX .030 ± .015 1.66 MAX .060 ± .023 1.68 MAX .076 ± .043 6-32 UNC-2A TERMINAL SCREWS, SEMS .250 ± .005 x .032 ± .002 THK. .125 ± .010 DIA. HOLE 1.25 ± .02 .594 ± .020 6-32 UNC-2A TERMINAL SCREW 1 2 3 SCREW TERMINAL 1 2 SOLDER LUG 3 1 2 3 SPADE TERMINAL SAFRAN ELECTRICAL & POWER “Safran Electrical & Power Proprietary Information. Information contained in this document is Safran Electrical & Power Proprietary Information and is disclosed in confidence. It is the property of Safran Electrical & Power and shall not be used, disclosed to others, or reproduced without the express written agreement of Safran Electrical & Power. If consent is given for reproduction in whole or in part, this notice set forth on each page of this document shall appear in any such reproduction in whole or in part. Unauthorized export or re-export is prohibited.” C15 ECONOSWITCH SEALED ROCKER SWITCHES Series - 8554, 8555, 8556 Econoswitch Sealed Rocker Switches MOUNTING DIMENSIONS - TWO POLE / 8555 RECOMMENDE D PANEL CU T-OUT .690 .718 .648 .1670 MTG HOLES 6-32 UNC-2B .152 [3,86] DIA. 1.625 1.250 1.937 .38 8 KEYW AY .61R .545 .253 FLUSH P ANEL MTG. MAX. 1.90 MAX. 1.60 .125[3,18] DIA. HOLE SUB P ANEL MTG. MAX. 1.37 6-32 UNC-2A TERMINAL SCREW, SEMS SUB P ANEL MTG. MAX. 1.67 1.39 SUB P ANEL MTG. FLUSH P ANEL MTG. .098 MAX. FLUSH P ANEL MTG. 1.69 MAX. .382 .674 .250[6,35] X .032[0,81] 1.32 5 6 1 2 3 4 5 6 1 2 3 4 5 6 1 2 3 .89 4 SPADE TERMINAL SOLDER LUG SCREW TERMINAL 90-9613.AI MOUNTING DIMENSIONS - SNAP-IN BEZEL TWO POLE / 8555 RECOMMENDED PANEL CUT-OUT .900 ± .015 .670 MAX .648 ± .008 .680 .125° APPROX. .830 1.19 RECOMMENDED PANEL THICKNESS: .040 TO .140 1.45 1.550 ± .015 KEYWAY .61 ± .0XX .218 ± .065 .336 ± .065 .060 ± .023 .030 ± .015 .030 ± .015 NOTE: WIRES ATTACHED TO THIS SWITCH MUST HAVE RING LUGS TO FIT #5 SCREW. DO NOT USE SPADE LUG OR WRAP WIRE AROUND TERMINAL SCREW. STANDARD 6-32 UNC-2A TERMINAL SCREW, SEMS Dimensions for reference only. C16 1.93 MAX 1.70 MAX 1.55 ± .07 .04 .250 ± .005 x .032 ± .002 THK. .125 ± .010 DIA. HOLE 1.32 ± .02 4 5 4 6 0.00 = inches [0,0] = mm 1.72 MAX .075 ± .043 5 6 2 3 4 5 6 2 3 .89 ± .02 1 2 3 SCREW TERMINAL 1 SOLDER LUG 1 SPADE TERMINAL SAFRAN ELECTRICAL & POWER “Safran Electrical & Power Proprietary Information. Information contained in this document is Safran Electrical & Power Proprietary Information and is disclosed in confidence. It is the property of Safran Electrical & Power and shall not be used, disclosed to others, or reproduced without the express written agreement of Safran Electrical & Power. If consent is given for reproduction in whole or in part, this notice set forth on each page of this document shall appear in any such reproduction in whole or in part. Unauthorized export or re-export is prohibited.” ECONOSWITCH SEALED ROCKER SWITCHES Series - 8554, 8555, 8556 Econoswitch Sealed Rocker Switches MOUNTING DIMENSIONS - FOUR POLE / 8556 .690 [17,53] RECOMMENDED PANEL CUT - OUT .718 .648 MTG HOLES 6-32 UNC-2B .152 [3,86] DIA. 1.625 1.250 [31,75] 1.937 KEYW AY .61R .388 .545 .253 10 11 9 7 11 7 9 4 6 1.64 1 90-9614.AI 2 FLUSH P ANEL MTG. MAX. 1.90 MAX. 11 12 9 7 8 5 8 5 6 4 .250[6,35] X .032[0,81] THK. 10 12 8 5 1.60 .125[3,18] DIA. HOLE 10 12 SUB P ANEL MTG. MAX. 1.37 6-32 TERMINAL SCREW ,SEMS 1.32 SUB P ANEL MTG. MAX. 1.67 FLUSH P ANEL MTG. MAX. 1.39 .098 SUB P ANEL MTG. FLUSH P ANEL MTG. 1.69 MAX. .382 .674 3 1 2 6 4 3 1 3 SPADE TERMINAL SOLDER LUG SCREW TERMINAL 2 MOUNTING DIMENSIONS - SNAP-IN BEZEL FOUR POLE / 8556 RECOMMENDED PANEL CUT-OUT .900 ± .045 .670 MAX .648 ± .008 .680 .125° APPROX. .830 1.19 RECOMMENDED PANEL THICKNESS: .040 TO .140 1.45 1.550 ± .015 KEYWAY .61 ± .01R .218 ± .045 .336 ± .065 .060 ± .023 .030 ± .015 .030 ± .015 NOTE: WIRES ATTACHED TO THIS SWITCH MUST HA E RING LUGS TO IT 5 SCREW . DO NOT USE SPADE LUG OR WRAP WIRE AROUND TERMINAL SCREW. 1.72 MAX .075 ± .043 1.55 ± .07 .04 .250 ± .005 x .032 ± .002 THK. .125 ± .010 DIA. HOLE 1.32 ± .02 10 6-32 UNC-2A TERMINAL SCREW, SEMS 1.93 MAX 1.70 MAX 11 12 10 11 12 8 1.64 ± .02 8 STANDARD 0.00 = inches 7 9 4 6 5 [0,0] = mm 1 SCREW TERMINAL 2 SOLDER LUG 3 7 9 4 6 5 1 2 3 SPADE TERMINAL Dimensions for reference only. SAFRAN ELECTRICAL & POWER “Safran Electrical & Power Proprietary Information. Information contained in this document is Safran Electrical & Power Proprietary Information and is disclosed in confidence. It is the property of Safran Electrical & Power and shall not be used, disclosed to others, or reproduced without the express written agreement of Safran Electrical & Power. If consent is given for reproduction in whole or in part, this notice set forth on each page of this document shall appear in any such reproduction in whole or in part. Unauthorized export or re-export is prohibited.” C17 ECONOSWITCH SEALED ROCKER SWITCHES Series - 8554, 8555, 8556 Econoswitch Sealed Rocker Switches OPTIONS/ACCESSORIES • Special color rockers • Hot stamped lettering on rockers - smooth rockers only • Special plated bezels • Special marking on switches • Optional Actuator • Gold plated contacts C18 SAFRAN ELECTRICAL & POWER “Safran Electrical & Power Proprietary Information. Information contained in this document is Safran Electrical & Power Proprietary Information and is disclosed in confidence. It is the property of Safran Electrical & Power and shall not be used, disclosed to others, or reproduced without the express written agreement of Safran Electrical & Power. If consent is given for reproduction in whole or in part, this notice set forth on each page of this document shall appear in any such reproduction in whole or in part. Unauthorized export or re-export is prohibited.”
8556K32X32M 价格&库存
很抱歉,暂时无法提供与“8556K32X32M”相匹配的价格&库存,您可以联系我们找货
