8510K10
8510K10
    SAFRAN(赛峰)
    SAFRAN ELECTRICAL AND POWER - 8510K10 - TOGGLE SWITCH, SPST, 15A, 28VDC
8510K10 数据手册
INDUSTRIAL - ENVIRONMENTALLY SEALED SWITCHES Series - 8510, 8511, 8512 Environmentally Sealed Toggle Switches CURRENT RATINGS Features • Completely sealed against dust, moisture, and other contaminants • 1, 2 and 4 pole circuitry • One hole mounting for easy installation • Multi-circuits offered • 2 & 3 position with maintained and momentary action • Molded-in terminal inserts • Molded-in terminal numbers • See 8520-8528 for UL recognized and CSA certified version on page 5 • • • • • Water tight seal per MIL-STD-108E and designed to meet IP68 Thermoset molding materials meet flame retardant requirements Temperature Range: -50°F to +150°F (-46°C to +66°C) Life: 20,000 operations at rated load Bushing: 15/32" - 32 thread No. of Catalog Type of Poles Number Operation 115 VAC 60 or 400Hz 28VDC Lamp Resistive Inductive Lamp Resistive Inductive Load Load Load Load Load Load 1 8510 2 8511 4 8512 SELECTION TABLE Maintained 5 20 15 3 15 10 Momentary 4 15 10 2 15 7 Maintained 7 20 15 4 15 15 Momentary 5 18 10 2 11 8 Maintained 5 20 12 4 15 15 Momentary 4 18 10 2 11 8 FLUSH TERMINAL SCREWS 8511 8510 Circuit with Lever in . . . Up Position Center Position One Pole ON OFF ON NONE ON* ON* ON* OFF* ON* ON* NONE NONE ON ON* ON* ON ON* ON* OFF NONE NONE OFF NONE OFF OFF NONE NONE OFF ON ON ON ON ON ON ON ON ON/OFF * Momentary contact. Four Pole Down Position (Keyway) Catalog Number ON ON ON ON ON * ON NONE ON OFF ON * ON ON ON ON * ON ON ON * ON ON Two Pole 8512 ON 8510K1 K9 K4 K6 8510K5 K2 K7 K10 K11 8510K3 K12 K13 — — — — — — — Catalog Number 8511K1 K9 K4 K6 8511K5 K2 K7 K10 K11 8511K3 K12 K13 8511K14 K15 K16 8511K17 K18 K19 — Catalog Number 8512K1 K9 K4 K6 8512K5 K2 K7 K10 K11 8512K3 K12 K13 8512K15 K16 K17 — — — 8512K20 See Page A71 for circuit diagrams. A2 SAFRAN ELECTRICAL & POWER “Safran Electrical & Power Proprietary Information. Information contained in this document is Safran Electrical & Power Proprietary Information and is disclosed in confidence. It is the property of Safran Electrical & Power and shall not be used, disclosed to others, or reproduced without the express written agreement of Safran Electrical & Power. If consent is given for reproduction in whole or in part, this notice set forth on each page of this document shall appear in any such reproduction in whole or in part. Unauthorized export or re-export is prohibited.” INDUSTRIAL - ENVIRONMENTALLY SEALED SWITCHES Series - 8510, 8511, 8512 Environmentally Sealed Toggle Switches MOUNTING DIMENSIONS - ONE POLE / 8510 0.432 0.076 [1,93] [10,97] KEYWAY 0.240 DIA. [6,10] 33° 0.470 [11,94] 0.690 [17,53] 16.5 ° 0.250 [6.35] 1.18 [29,9] MAX. 15/32- 32 UN-2A THREAD TO WITHIN 0.060 [1,52] OF SHOULDER 1 2 3 0.635 [16,13] MAX #6- 32 TERMINAL SCREW WITHINTERNAL TOOTH LOCKWASHER (SEMS) Terminal 0.380 Identification 0.380 [9,65] [9,65] 1.270 .432 MAX [32,26][10,97] .076 [1,93] MOUNTING DIMENSIONS - TWO POLE / 8511 KEYWAY .240 DIA. [6,10] 33° .130 [3,30] [0,0] = mm .380 [9,65] .910 MAX [23,11] 5 6 2 3 .380 [9,65] 4 1 #6-32 TERMINALSCREW WITH INTERNAL TOOTH LOCKWASHER (SEMS) STANDARD 0.00 = inches 1.370 MAX [34,80] .250 [6,35] .130 [3,30] 15/32-32 UN-2A THREAD TO WITHIN .060 [1,52] OF SHOULDER 1.100 MAX [27,94] .470 [11,94] .690 [17,53] 16.5° .380 [9,65] 1.340 MAX [34,04] Terminal Identification Mounting dimensions for reference only. 90-4077.AI Non-functional terminals not supplied. SAFRAN ELECTRICAL & POWER “Safran Electrical & Power Proprietary Information. Information contained in this document is Safran Electrical & Power Proprietary Information and is disclosed in confidence. It is the property of Safran Electrical & Power and shall not be used, disclosed to others, or reproduced without the express written agreement of Safran Electrical & Power. If consent is given for reproduction in whole or in part, this notice set forth on each page of this document shall appear in any such reproduction in whole or in part. Unauthorized export or re-export is prohibited.” A3 INDUSTRIAL - ENVIRONMENTALLY SEALED SWITCHES Series - 8510, 8511, 8512 Environmentally Sealed Toggle Switches MOUNTING DIMENSIONS - FOUR POLE / 8512 .076 [1,93] .432 [10,97] KEYWAY .240 DIA. [6.10] 33° .130 [3,30] 1.370 [34,80] MAX .250 [6,35] .130 [3,30] 15/32-32 UN-2A THREAD TO WITHIN .060 [1,52] OF SHOULDER 1.100 MAX [27,94] .470 [11,94] .690 [17,53] 16.5° 2 3 1.660 MAX [42,16] .370 [9,40] 9 5 6 4 1 .370 .370 [9,40] [9,40] 7 8 10 12 11 #6-32 TERMINALSCREW WITH INTERNAL TOOTH LOCKWASHER (SEMS) .380 .380 [9,65] [9,65] 1.340 MAX [34,04] Terminal90-4078.AI Identification OPTIONS/ACCESSORIES PANEL CUTOUT DIMENSIONS • Special mounting hardware • Mounting hardware furnished assembled • Terminal screws furnished assembled 15/32 DIA. BUSHING • Special toggle levers 0.480 DIA. HOLE [12,19] • Special circuits • Panel seal, Part Number 32-341 0.375 [9,52] • Spade terminal adapters available LOCKING RING 0.445 [11,30] 0.480 DIA. HOLE [12,19] 0.130 [3,30] KEYWAY 0.062 [1,57] STANDARD 0.00 = inches [0,0] = mm Mounting dimensions for reference only. A4 Non-functional terminals not supplied. SAFRAN ELECTRICAL & POWER “Safran Electrical & Power Proprietary Information. Information contained in this document is Safran Electrical & Power Proprietary Information and is disclosed in confidence. It is the property of Safran Electrical & Power and shall not be used, disclosed to others, or reproduced without the express written agreement of Safran Electrical & Power. If consent is given for reproduction in whole or in part, this notice set forth on each page of this document shall appear in any such reproduction in whole or in part. Unauthorized export or re-export is prohibited.”
8510K10 价格&库存
很抱歉,暂时无法提供与“8510K10”相匹配的价格&库存,您可以联系我们找货
