8530K94
8530K94
    SAFRAN(赛峰)
    SAFRAN ELECTRICAL AND POWER - 8530K94 - TOGGLE SWITCH, SPST, 20A, 28VDC, PANEL - Switch Operation:On...
8530K94 数据手册
INDUSTRIAL - ENVIRONMENTALLY SEALED SWITCHES Econoswitch Sealed Toggle Switches Series - 8530, 8531, 8532 Features SPECIFICATIONS • Environmentally sealed • 1, 2 and 4 pole Circuitry • One hole mounting for easy installation • Multi-circuits • 2 & 3 position with maintained and momentary action • Three types of termination offered as standard • Watertight seal per MIL-STD-108E and designed to meet IP68 • UL recognized and CSA certified • Three standard types of terminals: Screw 6-32 UNC-2A Solder lug .125 [3,17] dia. hole Spade .250 [6,35] x .032 [0,81] thick • Life: 50,000 operations at rated load. 100,000 operations mechanical life. • Temperature Range: -50°F to +150°F (-46°C to + 66°C) CURRENT RATINGS No. of Catalog Type of Poles Number Operation 115VAC 60 or 400Hz 28VDC Lamp Resistive Inductive Lamp Resistive Inductive Load Load Load Load Load Load 1 8530 2 8531 4 8532 Maintained 5 20 15 3 15 10 Momentary 4 Maintained 7 15 10 2 11 7 20 15 4 15 15 Momentary 5 18 10 2 11 8 Maintained 5 20 12 4 15 15 Momentary 4 18 10 2 11 8 For the UL/CSA ratings, see page A70. STANDARD LEVER SELECTION TABLE Circuit with Lever in . . . Up Position Center Position Catalog Number Down Position (Keyway) Screw Terminals Solder Lug Terminals Spade Terminals 8530K1 K9 K4 K6 8530K5 K2 K7 K10 K11 8530K3 K12 K13 8530K91 K99 K94 K96 8530K95 K92 K97 K910 K911 8530K93 K912 K913 8530K31 K39 K34 K36 8530K35 K32 K37 K310 K311 8530K33 K312 K313 One Pole ON ON ON ON ON ON* NONE ON OFF ON ON* ON 8530 OFF NONE NONE OFF NONE OFF OFF NONE NONE OFF ON ON ON OFF ON NONE ON* ON* ON* OFF* ON* ON* NONE NONE Two Pole ON ON ON ON ON ON* NONE ON OFF ON ON* ON ON ON ON* ON ON ON* 8531 OFF NONE NONE OFF NONE OFF OFF NONE NONE OFF ON ON ON ON ON ON ON ON ON OFF ON NONE ON* ON* ON* OFF* ON* ON* NONE NONE ON ON* ON* ON ON* ON* 8531K1 K9 K4 K6 8531K5 K2 K7 K10 K11 8531K3 K12 K13 K14 K15 8531K16 K17 K18 K19 8531K91 K99 K94 K96 8531K95 K92 K97 K910 K911 8531K93 K912 K913 K914 K915 8531K916 K917 K918 K919 8531K31 K39 K34 K36 8531K35 K32 K37 K310 K311 8531K33 K312 K313 K314 K315 8531K316 K317 K318 K319 ON OFF ON NONE ON* ON* ON* OFF* ON* ON* NONE NONE ON ON* ON* 8532K1 K9 K4 K6 8532K5 K2 K7 K10 K11 8532K3 K12 K13 K15 K16 K17 8532K91 K99 K94 K96 8532K95 K92 K97 K910 K911 8532K93 K912 K913 K915 K916 K917 8532K31 K39 K34 K36 8532K35 K32 K37 K310 K311 8532K33 K312 K313 K315 K316 K317 Four Pole ON ON ON ON ON * ON NONE ON OFF ON * ON ON ON ON * ON 8532 OFF NONE NONE OFF NONE OFF OFF NONE NONE OFF ON ON ON ON ON * Momentary contact. See page A71 for circuit diagrams. SAFRAN ELECTRICAL & POWER “Safran Electrical & Power Proprietary Information. Information contained in this document is Safran Electrical & Power Proprietary Information and is disclosed in confidence. It is the property of Safran Electrical & Power and shall not be used, disclosed to others, or reproduced without the express written agreement of Safran Electrical & Power. If consent is given for reproduction in whole or in part, this notice set forth on each page of this document shall appear in any such reproduction in whole or in part. Unauthorized export or re-export is prohibited.” A11 ECONOSWITCH - ENVIRONMENTALLY SEALED SWITCHES Series - 8530, 8531, 8532 Econoswitch Sealed Toggle Switches MOUNTING DIMENSIONS - ONE POLE / 8530 .076 [1,93] .432 [10.97] KEYWAY 33 .240 DIA. [6,10] .470 [11,94] .690 [17,53] 16.5 .125 DIA. HOLE [3,17] #6-32 UNC-2A TERMINAL SCREW, SEMS 1.51 [12,9] MAX 1.28 [32,5] MAX 1.30 MAX [33,0] 15/32-32 UN-2A THREAD TO WITHIN .060 [1,52] OF SHOULDER .250 X .032 THK [6,35] X [0,81] SCREW TERMINAL SOLDER LUG 3 2 1 3 2 1 3 2 1 .594 [15,09] 1.25 [31,75] SPADE TERMINAL Terminal Identification MOUNTING DIMENSIONS - TWO POLE / 8531 90-9609.AI STANDARD Terminal Identification 0.00 = inches [0,0] = mm Mounting dimensions for reference only. A12 Non-functional terminals not supplied. SAFRAN ELECTRICAL & POWER “Safran Electrical & Power Proprietary Information. Information contained in this document is Safran Electrical & Power Proprietary Information and is disclosed in confidence. It is the property of Safran Electrical & Power and shall not be used, disclosed to others, or reproduced without the express written agreement of Safran Electrical & Power. If consent is given for reproduction in whole or in part, this notice set forth on each page of this document shall appear in any such reproduction in whole or in part. Unauthorized export or re-export is prohibited.” Series - 8530, 8531, 8532 ECONOSWITCH - ENVIRONMENTALLY SEALED SWITCHES Econoswitch Sealed Toggle Switches .432 [10,97] .076 [1,93] MOUNTING DIMENSIONS - FOUR POLE/ 8532 KEYWAY .240 DIA. [6,10] .125 DIA HOLE [3,17] 6-32 UNC-2A TERMINAL SCREW, SEMS 10 1.32 [33,5] 11 12 10 11 9 1.64 [41,66] 4 6 5 .250 X .032 THK [6,35] X [0,81] 10 12 8 7 2 3 11 12 8 8 7 9 7 9 4 6 4 6 5 1 1.55 MAX [39,3] 1.34 [34,0] MAX 15/32-32 UNS-2A THREAD TO WITHIN .060 [1,52] OF SHOULDER 1.32 MAX [33,5] .468 [11,89] .69 [17,5] 33° 16.5° 5 1 SCREW TERMINAL 2 3 1 SOLDER LUG 2 3 SPADE TERMINAL Terminal Identification Non-functional terminals not supplied. • Special mounting hardware • Mounting hardware furnished assembled • Terminal screws furnished assembled • Special circuits • Panel seal, Part Number 32-341 • Custom wire harnesses • Mating connector available for two poles with spade terminal • External jumpers available - bussing jumper - reversing jumpers PANEL CUTOUT DIMENSIONS 15/32 DIA. BUSHING 0.480 DIA. HOLE [12,19] 0.375 [9,52] OPTIONS/ACCESSORIES LOCKING RING 0.445 [11,30] 0.480 DIA. HOLE [12,19] 0.130 [3,30] KEYWAY 0.062 [1,57] STANDARD 0.00 = inches [0,0] = mm Mounting dimensions for reference only. SAFRAN ELECTRICAL & POWER “Safran Electrical & Power Proprietary Information. Information contained in this document is Safran Electrical & Power Proprietary Information and is disclosed in confidence. It is the property of Safran Electrical & Power and shall not be used, disclosed to others, or reproduced without the express written agreement of Safran Electrical & Power. If consent is given for reproduction in whole or in part, this notice set forth on each page of this document shall appear in any such reproduction in whole or in part. Unauthorized export or re-export is prohibited.” A13
8530K94 价格&库存
很抱歉,暂时无法提供与“8530K94”相匹配的价格&库存,您可以联系我们找货
