95/00387989
95/00387989
    OTHER
95/00387989 数据手册
M. K. JUCHHEIM GmbH & Co JUMO Instrument Co. Ltd. JUMO PROCESS CONTROL INC. Delivery address:Mackenrodtstraße 14, 36039 Fulda, Germany Postal address: 36035 Fulda, Germany Phone: +49 661 6003-0 Fax: +49 661 6003-607 E-mail: mail@jumo.net Internet: www.jumo.net JUMO House Temple Bank, Riverway Harlow, Essex CM 20 2TT, UK Phone: +44 1279 635533 Fax: +44 1279 635262 E-mail: sales@jumo.co.uk Internet: www.jumo.co.uk 885 Fox Chase, Suite 103 Coatesville PA 19320, USA Phone: 610-380-8002 1-800-554-JUMO Fax: 610-380-8009 E-mail: info@JumoUSA.com Internet: www.JumoUSA.com Data Sheet 95.1530 JUMO di 32 / di 08 Digital microprocessor indicators with 1 measurement input and a maximum of 3 signal outputs, case for flush-panel mounting to DIN 43 700 Brief description The single-channel digital indicators with the bezel sizes 48mm x 24mm and 96mm x 48mm are available for displaying measurements and monitoring limit values in industrial applications. The configurable analog input permits the direct connection of thermocouples, resistance thermometers, resistance transmitters, potentiometers or transducers with a standard signal. The sampling rate for the measurement input is 4 measurements per second. The indicators have a clearly legible 4-digit LED display which, depending on the version, is 10mm (JUMO di 32) or 20mm (JUMO di 08) high, and serves to display the measurements, as well as being available for dialogs. Only three buttons are used for configuration. The parameter setting is arranged dynamically, and after two seconds without any operation the value is accepted automatically. The front protection is to IP66, at the rear IP20. The electrical connection is by plug-in screw terminals. The possible input and output configurations are shown in the following block structure. Type 951530/... Type 951531/... Block structure Features k structured operating and programming layout k customer-specific linearization correction k 2 limit comparators for limit monitoring k digital input filter with programmable filter time constant k time-delayed switching, programmable per relay k switch-on delay after power-on is programmable 09.01/00383037 Page 1/7 M. K. JUCHHEIM GmbH & Co • 36035 Fulda, Germany Data Sheet 95.1530 Page 2/7 Technical data Input for thermocouple Designation Fe-Con Fe-Con Cu-Con Cu-Con NiCr-Ni NiCr-Con NiCrSi-NiSi Pt10Rh-Pt Pt13Rh-Pt Pt30Rh-Pt6Rh W3Re-W25Re W5Re-W26Re Range limits L J U T K E N S R B D C EN 60 584 EN 60 584 EN 60 584 EN 60 584 EN 60 584 EN 60 584 EN 60 584 EN 60 584 -200 + 900°C -210 +1200°C -200 + 600°C -270 + 400°C -270 +1372°C -270 +1000°C -270 +1300°C -50 +1768°C -50 +1768°C 0 — 1820°C 0 — 2495°C 0 — 2320°C Range -200 + 900°C -200 +1200°C -200 + 600°C -200 + 400°C -200 +1372°C -150 +1000°C -100 +1300°C 0 — 1768°C 0 — 1768°C +300 +1820°C 0 — 2495°C 0 — 2320°C Measurement accuracy in range Ambient temperature error ≤0.4% ≤0.4% ≤0.4% ≤0.4% ≤0.4% ≤0.4% ≤0.4% ≤0.4% ≤0.4% ≤0.4% ≤0.4% ≤0.4% 100 ppm/°C 100 ppm/°C 100 ppm/°C 100 ppm/°C 100 ppm/°C 100 ppm/°C 100 ppm/°C 100 ppm/°C 100 ppm/°C 100 ppm/°C 100 ppm/°C 100 ppm/°C Sampling rate 4 measurements per second Cold junction Pt100 internal or external constant (CJT) Decimal place configurable Input for resistance thermometer Designation Connection circuit Range Measurement accuracy Ambient temperature error Pt100 EN 60 751 2-wire -200 +850°C ≤0.1% 50 ppm/°C Pt100 EN 60 751 3-wire -200 +850°C ≤0.1% 50 ppm/°C Pt1000 EN 60 751 2-wire -200 +850°C ≤0.1% 50 ppm/°C Pt1000 EN 60 751 3-wire -200 +850°C ≤0.1% 50 ppm/°C 2-wire -50 +150°C ≤1.0% 50 ppm/°C KTY11-6 Sensor lead resistance 20Ω max. per lead in 2-wire and 3-wire circuit Measuring current Lead compensation 250µA not required for 3-wire circuit. For 2-wire circuit, lead compensation can be implemented in software through actual-value correction. Decimal place configurable = factory setting Input for resistance transmitter Designation Range Measurement accuracy Ambient temperature error 0 — 4kΩ 0 — 4kΩ ≤0.5% 50 ppm/°C Sensor lead resistance 20Ω max. per lead Measuring current 25µA or 250µA (depending on size of resistance) Decimal place configurable Input for potentiometer Designation Connection circuit Range Measurement accuracy Ambient temperature error 0 — 4kΩ 2-wire 0 — 4kΩ ≤0.4% 50 ppm/°C 0 — 4kΩ 3-wire 0 — 4kΩ ≤0.4% 50 ppm/°C Sensor lead resistance Measuring current Lead compensation Decimal place 09.01/00383037 20Ω max. per lead in 2-wire and 3-wire circuit 250µA not required for 3-wire circuit. For 2-wire circuit, lead compensation can be implemented in software through actual-value correction. configurable M. K. JUCHHEIM GmbH & Co • 36035 Fulda, Germany Data Sheet 95.1530 Page 3/7 Input for standard signals Designation Range Measurement accuracy Ambient temperature error Voltage 0 — 10V, input resistance RE > 100kΩ 2 — 10V, input resistance RE > 100kΩ ≤0.1% ≤0.1% 100 ppm/°C 100 ppm/°C Current 4 — 20mA, voltage drop ≤ 1V 0 — 20mA, voltage drop ≤ 1V ≤0.15% ≤0.15% 100 ppm/°C 100 ppm/°C Decimal place configurable Measurement circuit monitoring1 Transducer Out-of-range • • • • • • • • Thermocouple Resistance thermometer Resistance transmitter Potentiometer Voltage 2 — 10V 0 — 10V Current 4 — 20mA 0 — 20mA 1 Probe/lead short-circuit1 Probe/lead break • • • • - • • • • • • - In fault condition, the outputs move to a defined state (configurable: active or inactive). • recognized - not recognized Logic input Assignment Type 951530/... Type 951531/... Number 1 (instead of the logic output only) 1 (standard) Function (configurable) Hold, Min/Max reset, level inhibit Operation through floating contact Outputs Assignment Type 951530/... Type 951531/... Output 1 relay relay Output 2 logic output or logic input relay and parallel logic output Relay contact rating contact life make contact (n.o.) 3A at 230VAC resistive load 150,000 operations at rated load Logic output current limiting load resistance 0/5V 20mA Rload ≥250Ω Feature time-delayed switching of relays separately programmable per relay within the range 0 — 9999sec = factory setting Switch-on delay Switch-on delay after power ON Feature 09.01/00383037 programmable within the range 4 — 9999sec display and relays will only be activated after the programmed time has elapsed M. K. JUCHHEIM GmbH & Co • 36035 Fulda, Germany Data Sheet 95.1530 Page 4/7 Electrical data Supply (switch-mode power supply) Test voltages (type test) Power drawn Data backup Electrical connection EMC - interference emission - immunity to interference Safety regulation 10 — 18V DC ±0% or 110 — 240V AC -15/+10% 48 — 63Hz, or 20 — 53V AC/DC 48 — 63Hz to EN 61 010, Part 1, March 1994, overvoltage category II, pollution degree 2, for Type 951530/... overvoltage category III, pollution degree 2, for Type 951531/... 5VA max. EEPROM at the rear, via plug-in screw terminals, conductor cross-section ≤ 1.5mm2 (1.0mm2 for Type 951530/...) or 2x 1.5mm2 (1.0mm2 for Type 951530/...), with core end sleeves EN 61 326 Class B to industrial requirements to EN 61 010-1 Case Case type Size in mm (for Type) Bezel Depth behind panel plastic case for panel mounting to DIN 43 700 Type 951530/... Type 951531/... 48 x 24 96 x 48 100 70 Panel cutout Ambient/storage temperature range Climatic conditions Operating position Protection 45+0.6 x 22.2+0.3 Weight 92+0.8 x 45+0.6 0 — 55°C / -40 to +70°C ≤ 75% rel. humidity, no condensation any to EN 60 529, front IP66, rear IP20 75g approx. 160g approx. Displays and controls (1) Display Height of digits Display range/unit Decimal places (2) Status indicators (3) Buttons q i,d q+d 1 7-segment display, 4 digits, red Type 951530/...: 10mm, Type 951531/...: 20mm -1999 to +9999 digit / ° C/ °F none, one, two two LEDs for the outputs 1 and 2, yellow select next parameter, select parameter and configuration level (> 2sec) increase1, decrease1 parameter value instant return to basic status Dynamic value setting; automatic acceptance of value after two seconds without pressing a button (also configuration codes) 09.01/00383037 Example Type 951530/... M. K. JUCHHEIM GmbH & Co • 36035 Fulda, Germany Connection diagrams JUMO di32, Type 951530/... JUMO di08, Type 951531/... 09.01/00383037 Data Sheet 95.1530 Page 5/7 M. K. JUCHHEIM GmbH & Co • 36035 Fulda, Germany Dimensions Type 951530/… Type 951531/... Side-by-side mounting (minimum spacing of panel cutouts) Type 951530/... 951531/... 09.01/00383037 horizontal > 8mm > 10mm vertical > 8mm > 10mm Data Sheet 95.1530 Page 6/7 M. K. JUCHHEIM GmbH & Co • 36035 Fulda, Germany Order details: Digital microprocessor indicators with 1 measurement input and a maximum of 3 signal outputs, case for flush-panel mounting to DIN 43 700 (1) Basic version 951530/ di32 - size 48mm x 24mm 951531/ di08 - size 96mm x 48mm x x x x 888 999 (2) Input (programmable) factory-set configuration to customer specification1 x x x x x x 16 22 23 (3) Supply 10 — 18V DC ±0% 20 — 53V AC/DC 48 — 63Hz 110 — 240V AC +10/-15% 48 — 63Hz (1) Order code Order example 1 (2) / 951530 / (3) - 888 - 23 For configuration to customer specification, please specify the probe type and the required settings in plain text. Standard accessories - 1 Operating Instructions B 95.1530 - 1 set of mounting brackets - 1 seal 09.01/00383037 Data Sheet 95.1530 Page 7/7
95/00387989 价格&库存
很抱歉,暂时无法提供与“95/00387989”相匹配的价格&库存,您可以联系我们找货
