9009059
9009059
    LEDXON
    LEDXON MODULAR - 9009059 - LED Strip, 1 m, 240 LEDs, Warm White, 24 VDC, 19.2 W, IP20
9009059 数据手册
PRODUCT OVERVIEW LINEAR FLEX BASIC HL LFBHL-SW800-24V-6S42-20 PRODUCT DESCRIPTION —— Voltage-based, flexible LED module —— Closely fitted LEDs ensure extremely homogeneous light —— Suitable for use where high lighting levels are required —— Very high light quality and colour consistency (MacAdam 3) —— Available in 2700, 3000, 4000, and 6000 K —— Service life of >36.000 hours / L70B10 —— Double layer circuit board with optimised thermal management —— Fixed using self-adhesive 3M adhesive tape TECHNICAL DATA /OVERVIEW Operating voltage 24 VDC Nominal capacity / m 19,2 W Nominal capacity / segment 0,48 W LED type SMD 3528 LED spacing 4,2 mm LED quantity / m 240 Cut size 25 mm / 6 LED Dimensions (l x w x h) 5000 x 10 x 1,65 mm Service life >36.000 h / L70 Tc point temperature Tc max. +70 °C Ambient temperature -25 … +50 °C ESD classification Testing severity level 1 CONNECTION-RELATED INFORMATION Pad dimensions ( l x w ) 1,6 x 1,6 mm Quantity of pads 2 Max. wire cross section 0,75 mm² Max. assembly length [m] 5 FULFILLMENT OF STANDARDS EN 62031:2015 2011/65/EU referring to EN 62471:2009 2009/125/EU IEC 62717 The values and images presented are subject to change due to technical innovations, and © ledxon modular GmbH are provided without separate notification. April 2017 1 S P E C I F I C T E C H N I C A L D ATA LINEAR FLEX BASIC HL LFBHL-SW800-24V-6S42-20 SPECIFIC DATA OVERVIEW Item no. Light colour Nominal colour temp. Typ. lumen / m Tolerance Operating voltage 9009059 warm white 2700 K 1249 lm 3 SDCM 24 VDC 9009143 warm white 3000 K 1249 lm 3 SDCM 24 VDC 9009102 neutral white 4000 K 1311 lm 3 SDCM 24 VDC 9009058 cool white 6000 K 1311 lm 3 SDCM 24 VDC PHOTOMETRIC DATA Item no. Nominal Colour Colour location Typ.luminous Luminous flux CRI Beam colour temperature temperature coordinates (x,y) flux / m tolerance (Ra) angle 9009059 2700 K 2710 K 0,4590 / 0,4107 1249 lm ± 29 % ≥ 80 120° 9009143 3000 K 2995 K 0,4377 / 0,4045 1249 lm ± 29 % ≥ 80 120° 9009102 4000 K 3901 K 0,3841 / 0,3753 1311 lm ± 29 % ≥ 80 120° 9009058 6000 K 5852 K 0,3251 / 0,3314 1311 lm ± 29 % ≥ 80 120° 2700 K 3000 K 4000 K 0,430 0,425 0,400 0,420 0,415 0,390 0,410 0,405 0,380 0,400 0,395 0,370 0,390 0,442 0,452 0,462 0,315 0,325 0,472 0,482 0,385 0,418 0,428 0,438 0,448 0,458 0,360 0,365 0,375 0,385 0,395 0,405 6000 K 0,350 0,340 0,330 0,320 0,310 0,305 0,335 0,345 The values and images presented are subject to change due to technical innovations, and © ledxon modular GmbH are provided without separate notification. April 2017 2 S P E C I F I C T E C H N I C A L D ATA LINEAR FLEX BASIC HL LFBHL-SW800-24V-6S42-20 ELECTRICAL DATA Item no. Nominal voltage Typ. capacity / m Typ. current / m Current tolerance Energy classification 9009059 24 VDC 18,2 W 0,76 A ± 19 % A 9009143 24 VDC 18,2 W 0,76 A ± 19 % A 9009102 24 VDC 18,2 W 0,76 A ± 19 % A 9009058 24 VDC 18,2 W 0,76 A ± 19 % A THERMAL DATA Item no. Service life Rated service life tc rated tp rated Ambient temperature Storage temperature 9009059 >36.000 h L70 B10 70 °C 65° C -25 … +50 °C -20 … +65 °C 9009143 >36.000 h L70 B10 70 °C 65° C -25 … +50 °C -20 … +65 °C 9009102 >36.000 h L70 B10 70 °C 65° C -25 … +50 °C -20 … +65 °C 9009058 >36.000 h L70 B10 70 °C 65° C -25 … +50 °C -20 … +65 °C FURTHER INFORMATION Item no. Max. feed-in length Max. bending radius IP rating Water protection Fixture 9009059 5000 mm 30 mm IP 00 — self-adhesive 9009143 5000 mm 30 mm IP 00 — self-adhesive 9009102 5000 mm 30 mm IP 00 — self-adhesive 9009058 5000 mm 30 mm IP 00 — self-adhesive PRODUCT KEY DESCRIPTION LFBML SW800 24V 5S100 20 category photometrical voltage- / current- layout code protection Code based class The values and images presented are subject to change due to technical innovations, and © ledxon modular GmbH are provided without separate notification. April 2017 3 S P E C I F I C T E C H N I C A L D ATA LINEAR FLEX BASIC HL LFBHL-SW800-24V-6S42-20 DIMENSIONS Item no. Length Width Height Cut size LED / cut size LED / m LED spacing 9009059 5000 mm 10 mm 2 mm 25 mm 6 pcs. 240 pcs. 4,2 mm 9009143 5000 mm 10 mm 2 mm 25 mm 6 pcs. 240 pcs. 4,2 mm 9009102 5000 mm 10 mm 2 mm 25 mm 6 pcs. 240 pcs. 4,2 mm 9009058 5000 mm 10 mm 2 mm 25 mm 6 pcs. 240 pcs. 4,2 mm 25.0 4.2 10.0 Tc 2.1 LFBHL 24V-6S42 RoHS ORDER INFORMATION Packaging Ordering Weight Dimensions / PU unit (PU) unit (OU) gross / PU length x width x height LFBHL-SW827-24V-6S42-20 1 roll = 5 m 1 metre 158 g 240 mm x 220 mm x 15,5 mm LFBHL-SW830-24V-6S42-20 1 roll = 5 m 1 metre 158 g 240 mm x 220 mm x 15,5 mm 9009102 LFBHL-SW840-24V-6S42-20 1 roll = 5 m 1 metre 158 g 240 mm x 220 mm x 15,5 mm 9009058 LFBHL-SW860-24V-6S42-20 1 roll = 5 m 1 metre 158 g 240 mm x 220 mm x 15,5 mm Item no. Item description 9009059 9009143 220 12 26 MODUL PERFORMANCE www.ledxon.com 176 240 MODUL PERFORMANCE The values and images presented are subject to change due to technical innovations, and © ledxon modular GmbH are provided without separate notification. April 2017 4 T E C H N I C A L I N F O R M AT I O N LINEAR FLEX BASIC HL LFBHL-SW800-24V-6S42-20 INFORMATION ON SERVICE LIFE The maximum Tc/Tp temperature is a crucial factor for the service life information relating to ledxon LED modules. If the permitted limits are exceeded, this shall significantly reduce the service life and may even result in the destruction of the modules. The expected service life of >36,000 hours represents a purely statistical parameter. (L70/B10 at Tp = 65°C) For optimum operation of ledxon LED modules, we recommend installation only on rigid and stationary surfaces. The heatsink must provide for sufficient heat dissipation such that the maximum permitted temperature is not exceeded at the Tc point. The temperatures at the Tc point must be measured in accordance with the specifications stated in EN 60598-1. INFORMATION ON PHOTOMETRIC AND ELECTRICAL DATA Capacity coordinates and tolerances in accordance with CIE 1931 Measurement environment temperature: ta = 25° Measurement tolerance for colour coordinates (x / y) +/- 0.005 The maximum permitted operating voltage must not be exceeded. Otherwise a reduction in service life or a failure may occur. All ledxon LED modules can be dimmed using PWM (pulse width modulation). SAFETY AND INSTALLATION INFORMATION When installing flexible LED modules, the maximum permitted bend radius must be not be fallen short of. Bending these modules laterally results in damage to the printed circuit board. In order to ensure optimum adherence for the double-sided 3M adhesive tape, ledxon recommends installing the modules only on dry, clean surfaces that are free of grease, oil and silicone. ledxon does not accept any liability for the correct adhesion of the LED modules. When installing ledxon LED modules, standard ESD safety precautions must be complied with. ledxon flexible LED modules are delivered without cabling. These modules are electrified by soldiering leads onto the soldering pads provided. The maximum permitted cable cross-section must be observed in this process. Here, the soldering temperature of 270°C for a maximum of 10 seconds must not be exceeded. ledxon modules that are equipped with LED types SMD 5050 and 5630 are subject to photobiological risk group 1. The values and images presented are subject to change due to technical innovations, and © ledxon modular GmbH are provided without separate notification. April 2017 5
9009059 价格&库存
很抱歉,暂时无法提供与“9009059”相匹配的价格&库存,您可以联系我们找货
