9010481050P
9010481050P
    LIGHTECH
9010481050P 数据手册
TM LED CC DC 48W 1050mA LED LED DRIVER DC CC, POTTED LED 48 DC 1050mA P Features          Dimmable with Trailing Edge dimmers Designed for IP67 Reinforced insulation from input to output High efficiency PFC: > 0.95 Fully protected: Short circuit, Input voltage surge, Thermal, Secondary switch Overload regulation, Over voltage protection. Self-resettable AC/DC Soft start Applications       Led in- and outdoor lighting Street lighting Architectural lighting Signage Indication and orientation lighting Ambience lighting SELV Specifications VERSION 48 WATT 1050mA SKU no. 9010481050P VOLTAGE RANGE (V) INPUT 220-240 FREQUENCY RANGE (Hz) 50/60 POWER FACTOR 0,98 EFFICIENCY (Typ.)% 89 AC CURRENT (A) 0.25 INRUSH CURRENT (A) OUTPUT - VOLTAGE (V) Note 3 4-46 CURRENT (A) Note 3 1,05 RATED POWER (W) DIMMABLE PROTECTION 48 REVERSE PHASE CONTROL (TRAILING EDGE) YES INPUT VOLTAGE SURGE YES OVER TEMPERATURE YES SHORT CIRCUIT PROTECTION YES REINFORCED INSULATION YES Ta (°C) ENVIRONMENT STANDARDS -25…+70 Tc (°C) 85 WORKING HUMIDITY IP67 STORAGE TEMP. (°C)  -10…+70 VDE SAFETY PENDING VDE EMC PENDING UL MECHANICAL N/A PLASTIC/ METAL CASE METAL INPUT WIRES COLOR BRW/BLU INPUT WIRES SIZE 0.75mm² OUTPUT WIRE COLOR BLK/RED OUTPUT WIRE SIZE 18AWG WEIGHT 1. All parameters are measured at rated input, rated load and 25°C of ambient temperature. NOTE 2. Specifications may vary from time to time without notice. 3. Tolerance: includes set up tolerance, line regulation and load regulation. 4. Subject to standard warranty, terms and conditions as published from time to time. Page 1/2 www.lightechinc.com TM LED CC DC 48W 1050mA LED 48 DC 1050mA P Mechanical Drawing Mounting Instructions max.3m (118") max.3m (118") LED 48 DC 1050mA From 4 to 10 leds in series. Safety Instructions 1. Always disconnect power before installation and/or removal of the unit. 2. Install in accordance with national and local electrical codes. LE18 DmA P/PU LED 18 DC 700mA P/PU LED 36 DC 700mA P/PU 90 Page 2/2 www.lightechinc.com
9010481050P 价格&库存
很抱歉,暂时无法提供与“9010481050P”相匹配的价格&库存,您可以联系我们找货
