901150024EMS
901150024EMS
    LIGHTECH
901150024EMS 数据手册
TM LED CV DC 150W 12V, 24V LED LED DRIVER DC CV, POTTED LED 150 DC 12V EMS (EU) LED 150 DC 24V EMS (EU) LED 150 DC 12V UM (USA) LED 150 DC 24V UM (USA) Features 0.99 Power Factor 90-93% efficiency 120-277V input voltage Tiny inrush current (1A-2A) Surge, Over-temperature, Short-circuit protections Applications Under-cabinet LED lighting, Cove LED lighting Ideal for daisy-chained LED installations Hi-power LED lighting LED Signage PENDING SELV PENDING LED CV DC 150W 12V, 24V Specifications VERSION 150 DC 12V 150 DC 24V 150 DC 12V 150 DC 24V 150 DC 12V 150 DC 24V ENGINEERING SAMPLE ONLY SKU No. INPUT OUTPUT DIMMABLE PROTECTION 901150012EMS 901150024EMS 901150012120-UM STANDARDS MECHANICAL 901150012 UM 901150024 UM VOLTAGE RANGE (V) 220-240 120 120-277 FREQUENCY RANGE (Hz) 0/50/60 0/50/60 0/50/60 POWER FACTOR 0,99 0,99 0,99 EFFICIENCY (Typ.)% 90 90 90 AC CURRENT (A) 0,7 1,4 1.4-06 INRUSH CURRENT (A) 2 1 2 VOLTAGE (V) Note 3 12 ±10% 24±10% 12 ±10% 24±10% 12 ±10% 24±10% 150 RATED POWER (W) YES/NO NO INPUT VOLTAGE SURGE YES OVER TEMPERATURE YES SHORT CIRCUIT PROTECTION YES YES REINFORCED INSULATION ENVIRONMENT 901150024120-UM Ta (°C) -25…+50 -25…+50 -25…+50 -25…+50 -25…+50 -25…+50 Tc (°C) 70 70 75 75 80 80 WORKING HUMIDITY IP67 IP67 STORAGE TEMP. (°C)  -10…+70  -10…+70  -10…+70  -10…+70 OUTDOOR  -10…+70  -10…+70 VDE SAFETY PENDING N/A VDE EMC PENDING N/A UL N/A PENDING PLASTIC/ METAL CASE METAL METAL CASE COLOR WHITE WHITE INPUT WIRES COLOR BRW/BLU BLK/WHT INPUT WIRES SIZE 0.75mm² 18AWG OUTPUT WIRE COLOR BLK/RED BLK/RED OUTPUT WIRE SIZE 2mm² 14AWG WEIGHT 0.650 Kg 1. All parameters are measured at rated input, rated load and 25°C of ambient temperature. NOTE 2. Specifications may vary from time to time without notice. 3. Tolerance: includes set up tolerance, line regulation and load regulation. 4. Subject to standard warranty, terms and conditions as published from time to time. Page 1/2 www.lightechinc.com TM LED 150 DC 12V EMS (EU) LED 150 DC 24V EMS (EU) LED CV DC 150W 12V, 24V LED 150 DC 12V UM (USA) LED 150 DC 24V UM (USA) Mechanical Drawing max.3m (118") max.3m (118") Mounting Instructions LED STRING Safety Instructions 1. Always disconnect power before installation and/or removal of the unit. 2. Install in accordance with national and local electrical codes. LE18 DmA P/PU LED 18 DC 700mA P/PU LED 36 DC 700mA P/PU 90 Page 2/2 Version __ file 082010 www.lightechinc.com
901150024EMS 价格&库存
很抱歉,暂时无法提供与“901150024EMS”相匹配的价格&库存,您可以联系我们找货
