A10192-L
A10192-L
    ANTENOVA(安诺亚)
    ANTENOVA - A10192-L - ANTENNA, FUSCA, SMD, 2.4GHZ
A10192-L 数据手册
Fusca 2.4GHz SMD Antenna Part No. A10192-L Product Specification 1 Features • Designed for 2.4GHz applications [Bluetooth®, WiFi® (802.11b/g), ZigBee®, etc.] • Intended for SMD mounting • Supplied in tape on reel 2 Description The Fusca antenna is intended for use with all 2.4GHz applications. The antenna requires a groundplane, i.e. your device acts as an active part of the antenna and thus demands careful consideration concerning its placement. 3 Applications • Mobile phones • PDAs • Headsets • PC-Cards • CF-Cards Integrated Antenna Solutions  Product Specification 06MD-0002-1-PS Fusca 2.4GHz SMD Antenna Part No. A10192-L Contents 1 Features 1 2 Description 1 3 Applications 1 4 Model Name 3 5 General Data 3 6 Electrical Characteristics 3 7 Electrical Performance 4 8 Antenna Dimensions 5 9 Antenna Footprint 5 10 Electrical Interface 6 10-1 Transmission Line and Matching 6 11 Test Board Dimensions 6 12 Soldering 7 13 Reliability 7 13-1 Temperature and Humidity 7 13-2 Mechanical 7 14 Hazardous Material Regulation Conformance 8 15 Packaging 9 15-1 Shelf Storage Recommendations 9 15-2 Tape Characteristics 9 15-3 Reel Dimensions 9 Integrated Antenna Solutions  Product Specification 06MD-0002-1-PS Fusca 2.4GHz SMD Antenna Part No. A10192-L 4 Model Name A10192 5 General Data Product Name Fusca 2.4GHz Part No. A10192-L Frequency 2.4 – 2.5GHz Polarization Linear Operating Temperature -40 to +85 °C 6 Electrical Characteristics Characteristics Min Typ Max Peak Gain TBD 0.4dBi TBD Efficiency TBD 50% TBD VSWR TBD 2:1 TBD *Conditions Frequency 2.4-2.5GHz, Measured in 3D chamber (near field) Frequency 2.4-2.5GHz, Measured with Network Analyser * Note all data provided in this table are based on the Antenova reference board. Integrated Antenna Solutions  Product Specification 06MD-0002-1-PS Fusca 2.4GHz SMD Antenna Part No. A10192-L 7 Electrical Performance Integrated Antenna Solutions  Product Specification 06MD-0002-1-PS Fusca 2.4GHz SMD Antenna Part No. A10192-L 8 Antenna Dimensions L W H Length Width Height 4.0 ±0.2 3.0 ±0.2 1.1 ±0.2 F S K J I O 1.0 ±0.15 0.8 ±0.15 0.2 ±0.15 0.2 ±0.15 0.6 ±0.15 0.2 ±0.15 All dimensions in mm 9 Antenna Footprint S I K T M 1 ±0.1 2 ±0.1 0.6 ±0.1 0.4 ±0.2 Pad 0.8 ±0.1 N O 50Ω transmission line. Dependent on substrate All dimensions in mm Integrated Antenna Solutions  Product Specification 06MD-0002-1-PS Fusca 2.4GHz SMD Antenna Part No. A10192-L 10 Electrical Interface 10-1 Transmission Line and Matching Component types Inductor Strip Line Component Module Capacitor Component Typical config. 2 Component Typical config.  DC Block The matching network has to be individually designed using one, two or three components. t, W Unique dimensioning according to your PCB* C Inductor and capacitor values according to your device* *Antenova provides a design service to determine these parameters on request. 11 Test Board Dimensions The test board is designed for evaluation purposes for Fusca 2.4GHz SMD antenna. The card is a similar size to a typical Bluetooth headset. Integrated Antenna Solutions  Product Specification 06MD-0002-1-PS Fusca 2.4GHz SMD Antenna Part No. A10192-L 12 Soldering The antenna has been designed for lead free soldering. A recommended solder paste and reflow profile will be provided. 13 Reliability 13-1 Temperature and Humidity The antenna will be tested for conformance to the following standards: Item Standard Low High Duration Operating Temperature EN/IEC 60068-2-2, Test Bd: Dry heat -30 °C +90 °C - Temperature Cycling EN/IEC 60068-2-14, Test Na: Change of temperature -40 °C +90 °C 500 cycles / 10 min Storage Life Humidity EN/IEC 60068-2-1, Test Ca: Damp heat +60 °C / 90% RH - Storage Life Low Temperature EN/IEC 60068-2-1, Test Ad: Cold -55 °C - - Storage Life High Temperature EN/IEC 60068-2-2, Test Bb: Dry heat - +125 °C - 13-2 Mechanical The antenna will be tested for conformance to the following standards: Item Standard Low High Bending IEC 60068-2-21, Test Ue1: Bending Bending 1mm at a rate of 1mm/s with support at end of PCB Duration 1mm depth on reference board Shear IEC 60068-2-21, Test Ue3: Shear Drop Test Force of 5N applied to the side of the antenna Dummy weight: 150g Height: 170cm Vibration EN/IEC 60068-2-6, Test Fc (sinusoidal) Acceleration spectral density: 10-1000Hz Acceleration:20m/s One drop at each side, total drops: 6 5 cycles per axis 2 Number of axes: 3 mutually perpendicular Integrated Antenna Solutions  Product Specification 06MD-0002-1-PS Fusca 2.4GHz SMD Antenna Part No. A10192-L 14 Hazardous Material Regulation Conformance Restriction of Hazardous Substances (RoHS) The Fusca SMD Antenna A10192-L will be certified to be in full compliance with the relevant EU directives with respect to the content of: Cadmium and cadmium compounds Chlorinated paraffin (CP) Lead and lead compounds Organic tin compounds Organic brominated compound (PBB, PBDE) Mirex Mercury and mercury compounds Asbestos Polychlorinated biphenyl (PCB) Formaldehyde Hexavalent chromium compounds Azo compounds Polychlorinated naphthalene (PCN) Tetra-bromo-bisphenol-A-bis (TBBP-A-bis) Antenova’s Declaration of Compliance for the Fusca SMD Antenna A10192-L will be available upon request from Antenova Technical Support. Integrated Antenna Solutions  Product Specification 06MD-0002-1-PS Fusca 2.4GHz SMD Antenna Part No. A10192-L 15 Packaging 15-1 Shelf Storage Recommendations Temperature -10 to +40 °C Humidity Less than 75% RH Shelf Life 18 Months Storage Place Away from corrosive gas and direct sunlight 15-2 Tape Characteristics W F E1 P0 P1 P2 A0 B0 K0 T D0 D1 12.00 ±0.2 5.50 ±0.1 1.75 ±0.1 4.00 ±0.1 8.00 ±0.1 2.00 ±0.1 3.20 ±0.1 4.20 ±0.1 1.30 ±0.1 0.30 ±0.1 1.50 ±0.1 1.50 ±0.1 Quantity Leading Space Trailing Space TBC 60 blank antenna holders 37 blank antenna holders 15-3 Reel Dimensions Material Conductive Polystyrene Width (W) 14mm Reel Dia (D) 178mm ±2.0mm Hub Dia (H) 60mm Shaft Dia (C) 13.2mm ±0.5mm Integrated Antenna Solutions  Product Specification 06MD-0002-1-PS www.antenova.com Corporate Headquarters USA Headquarters Asia Headquarters Antenova Ltd. Far Field House Albert Road Stow-cum-Quy Cambridge, CB25 9AR UK Antenova USA Rogers Business Park 2541 Technology Drive, Suite 403 Elgin, IL 60124 USA Antenova Asia Ltd. 4F, No. 324, Sec. 1, Nei-Hu Road Nei-Hu District Taipei 11493 Taiwan, ROC Tel: +44 (0) 1223 810600 Fax: +44 (0) 1223 810650 Email: sales@antenova.com Tel: +1 (847) 551-9710 Fax: +1 (847) 551-9719 Email: sales@antenova.com Tel: +886 (0) 2 8797 8630 Fax: +886 (0) 2 8797 6890 Email: sales@antenova.com Copyright® 2007 Antenova Ltd. All Rights Reserved. Antenova® and RADIONOVA® are trademarks of Antenova Ltd. Any other names and/or trademarks belong to their respective companies. The materials provided herein are believed to be reliable and correct at the time of print. Antenova does not warrant the accuracy or completeness of the information, text, graphics or other items contained within these information. Antenova further assumes no responsibility for the use of this information, and all such information shall be entirely at the user’s risk. Integrated Antenna Solutions 10 Product Specification 06MD-0002-1-PS
A10192-L 价格&库存
很抱歉,暂时无法提供与“A10192-L”相匹配的价格&库存,您可以联系我们找货
