CLAMP0551P1
CLAMP0551P1
    WPMTEK(维攀微)
    DFN1006
    双向ESD 5V截止 峰值浪涌电流:8A@8/20US
CLAMP0551P1 数据手册
CLAMP0551P1 Low-capacitance bidirectional micro-packaged TVS Diodes for ESD Protection Low-Capacitance Bidirectional Micro Packaged TVS Diodes for ESD Protection The CLAMP0551P1 is designed with Weipan Punch-Through process TVS technology to protect voltage sensitive components from ESD. Excellent clamping capability, low leakage, and fast response time provide best in class protection on designs that are exposed to ESD. Because of its small size, it is suited for use in cellular phones, MP3 players, digital cameras and many other portable applications where board space comes at a premium. This series has been specifically designed to protect sensitive components which are connected to data and transmission lines from overvoltage caused by ESD (electrostatic discharge), and EFT (electrical fast transients). Features  Peak Power Dissipation − 60 W (8 x 20 us Waveform)  Stand-off Voltage: 5.0 V  Low capacitance for high-speed interfaces  Replacement for MLV (0402)  Protects I/O、VCC Port  Low Clamping Voltage  Low Leakage Current:5nA  Low Capacitance  Response Time is < 1 ns  Meets MSL 1 Requirements  ROHS compliant  WeiPan technology DFN1006 Main applications  Serial and Parallel Ports  Notebooks, Desktops, Servers  Projection TV  Cellular handsets and accessories  Portable instrumentation  Peripherals Protection solution to meet  IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact)  IEC61000-4-4 (EFT) 40A (5/50ns)  IEC61000-4-5 (Lightning) 8A (8/20µs) Ordering Information Device CLAMP0551P1 Rev.B-Aug,2018 Marking F1 Qty per Reel 10000pcs Reel Size 7inch !1! www.wpmtek.com CLAMP0551P1 Low-capacitance bidirectional micro-packaged TVS Diodes for ESD Protection Maximum ratings (Tamb=25℃ Unless Otherwise Specified) Parameter Symbol Value Unit Peak Pulse Power (tp=8/20μs waveform) PPPP 90 Watts Peak pulse current (tp=8/20μs waveform) I PP 8 A ESD Rating per IEC61000-4-2: Contact 30 Air 30 KV Lead Soldering Temperature TL 260 (10 sec.) ℃ Operating Temperature Range TJ -55 ~ 150 ℃ TSTG -55 ~ 150 ℃ Storage Temperature Range Maximum ratings are those values beyond which device damage can occur. Maximum ratings applied to the device are individual stress limit values (not normal operating conditions) and are not valid simultaneously. If these limits are exceeded, device functional operation is not implied, damage may occur and reliability may be affected. *Other voltages may be available upon request. 1. Non-repetitive current pulse, per Figure 1. Electrical characteristics ( Tamb=25℃ Unless Otherwise Specified) Symbol Parameter Conditions Min. Typ. VRWM Reverse Working Voltage VBR Reverse Breakdown Voltage IT = 1mA, IR Reverse Leakage Current V RWM = 5V, 0.005 0.1 μA VC Clamping Voltage I PP = 1A, tp =8/20μs, 7 10 V I PP = 8A, tp =8/20μs, 8.5 12 V I PP Peak Pulse Current tp =8/20μs 8 A CJ Junction Capacitance V R = 1.5V, f = 1MHz, 5.5 Max. Units 5 V 6.4 V 13 pF Junction capacitance is measured in VR=0V,F=1MHz Symbol VRWM IPP Working Peak Reverse Voltage VBR Breakdown Voltage @ IT VC Clamping Voltage @ IPP IT Test Current IRM Leakage current at VRWM IPP Peak pulse current CO Off-state Capacitance CJ Junction Capacitance Rev.B-Aug,2018 I Parameter VC VBR VRWM IT IR IR IT VRWM VBR VC V IPP !2! www.wpmtek.com CLAMP0551P1 Low-capacitance bidirectional micro-packaged TVS Diodes for ESD Protection 10 110 100 90 80 70 60 50 40 30 20 10 0 Waveform Parameters: tr=8us td=20us Peak Pulse Power-PPK(KW) PP Typical electrical characterist applications td=IPP/2 0 5 10 15 20 25 0.1 0.01 0.1 30 Time (us) 1 10 100 1000 Pulse Duration-tp(us) Non-Repetitive Peak Pulse Power vs. Pulse Time Pulse Waveform % of Rated Power or Ipp 1 110 100 90 80 70 60 50 40 30 20 10 0 0 25 50 75 100 125 150 Ambient Temperature-TA Power Derating Curve Rev.B-Aug,2018 !3! www.wpmtek.com CLAMP0551P1 Low-capacitance bidirectional micro-packaged TVS Diodes for ESD Protection Package Information DFN1006 Mechanical Data Case:DFN1006 Case Material: Molded Plastic. UL Flammability D b DIM Min Max A 0.37 0.55 A1 0.00 0.05 D 0.55 0.65 E 0.95 1.05 b 0.45 0.55 L L1 b ID PIN 1 L1 L e E Millimeters 1 脚标识 A1 A e L Recommended Pad outline 0.60mm L1 0.65TYP 0.2 0.32 0.05REF 0.85mm 0.55mm Contact Information WPMTEK Incorporated Limited Floor 1 Building 4#, Binxianghua Industry Park, No.7, Huada Road, Hualian Community, Longhua New District, Shenzhen TEL:86755-29308003 Rev.B-Aug,2018 FAX:86755-23739900 !4! www.wpmtek.com
CLAMP0551P1 价格&库存
很抱歉,暂时无法提供与“CLAMP0551P1”相匹配的价格&库存,您可以联系我们找货
