A1604 BK210J
A1604 BK210J
    RAYOVAC
    Alkaline 9 V AAA Size 46.5 to 48.5 mm Battery
A1604 BK210J 数据手册
Marketing Specification, Batteries Rayovac Stock Number: S6600184, Issue Q Memo No: 11854 World Headquarters 601 Rayovac Drive Madison, WI 53711 Telephone 608-275-3340 Fax 608-275-3340 Internet www.rayovac.com A1604 9 VOLT ALKALINE Name: ENGINEERING DATA: Cell Chemistry: Alkaline Designation: ANSI/NEDA – 1604A , IEC – 6LR61 or 6LF22 Nominal Voltage: 9 volts .610"-.689" (15.5-17.5MM) .490"-.510" (12.45-12.95MM) .070" (1.78MM) MIN Approximate Weight: 1.6 Oz (45.4 grams) Approximate Volume: 1.2 CU IN (19.7 CU CM) Operating Temp. Range: -30 C to 55 C (-20 F to 130 F) Terminals: Snap 1.831"-1.909" (46.5-48.5MM) 1.827" MAX (46.4MM) .965"-1.043" (24.5-26.5MM) Dimensions shown are ANSI/IEC standards Jacket: Steel Environmental: Meets Environmental Protection Agency (EPA) Requirements For Landfill Disposal. No Mercury Added Formulation Expected service life and representative discharge curves are shown on the following page. Page 1 of 2 ESTIMATED INITIAL SERVICE AT 70F (HOURS) CUTOFF VOLTAGE APPLICATION DUTY CYLE LOAD (OHMS) CURRENT (mA at 7.2V) 7.8V 7.2V 6.6V 6.0V 5.4V 4.8V mAh CAPACITY To 4.8V RADIO (2 HR/DAY) 620 11.6 13 32 39 45 49 52 614 TOY/GAME (1 HR/DAY) 270 26.7 4 11 17 19 21 23 600 SMOKE DETECTOR (ACCELERATED) 10K-Ohm BACKGROUND WITH 620 OHM PULSE 1 SEC/HR 500 HOURS TO 7.5V 424 TO 7.5V Rayovac 9V Discharge Curves 620 Ohm 2h/d 270 Ohms 1h/d 10K-Ohm w/ 620 Ohm 1 s/h 10.0 Voltage 9.0 8.0 7.0 6.0 5.0 0.0 0.1 1.0 10.0 100.0 1000.0 Log Load Time (hours) This data sheet contains information specific to batteries manufactured at the time of its publication. Contents herein do not constitute a warranty and are subject to change without notice. Page 2 of 2
A1604 BK210J 价格&库存
很抱歉,暂时无法提供与“A1604 BK210J”相匹配的价格&库存,您可以联系我们找货
