EDM6070AR-01
EDM6070AR-01
    ELEMENT14
    Module
EDM6070AR-01 数据手册
Embedded Display Module EDM6070 Atmel AT91SAM9X35 Based Single Board Computer BY Product Overview Version 1.0 Dated: 3rd Dec 2013 Table of Contents Product Overview .......................................................................... 2 Introduction .................................................................................. 2 Kit Contents .................................................................................. 3 Board Interface.............................................................................. 4 System Block Diagram.................................................................... 5 Physical Dimensions ....................................................................... 6 Hardware Features ........................................................................ 7 CPU .............................................................................................. 7 On-Board Memory .......................................................................... 7 On-Board Interfaces ....................................................................... 7 Others .......................................................................................... 7 Operational Parameters .................................................................. 8 Software Features ......................................................................... 9 BSP Packages ................................................................................ 9 Example Applications .................................................................... 10 1|Pa g e Product Overview Introduction The EDM6070AR-01 is an ARM based Single Board Computer (SBC), designed & developed by element14. It comprises of a 7” LCD display and touch screen assembly, integrated with multi-functional embedded hardware based on Atmel’s ARM9 AT91SAM9X35 industrial processor. The EDM6070AR-01 is a fully integrated Embedded Display Module solution for variety of embedded control HMI applications, ready to drop into your product with negligible integration effort, OR to just wrap an enclosure around, add a software application and become your finished product. EDM6070 is designed to fulfil the different requirements of various HMI applications including industrial control terminals, intelligent instruments, data acquisition and analysis, medical products, and network terminals. EDM6070AR-01 consists of three parts: a MINI6935 CPU core module, an expansion board, and a 7-inch TFT LCD (800×480) with resistive touch screen.  MINI6935 CPU module is an ARM embedded board, integrated with the ATMEL ARM926EJ-S-based processor AT91SAM9X35, operating at 400MHz frequency. The board has 128MB DDR2 SDRAM, 256MB NAND Flash, 4MB DataFlash, 4KB two-wire EEPROM.  The Base Board expands the rich set of connectivity and user interface peripherals of Atmel AT91SAM9X35 including Ethernet and CAN interface. The board also has TFT touch screen LCD interface, USB hosts/device, Buzzer, RS232, RS485, Audio, GPIOs and SD card interface to allow large storage capabilities. 2|Pa g e  LCD Touchscreen Display is a 4-wire resistive touchscreen TFT LCD display with a display resolution of up to 800x480 with 24-bit colour depth. The EDM6070AR-01 includes Linux BSP and supports the Linux QT GUI (Graphical User Interface) and multiple file systems like, FAT, NTFS etc. It is also supplied with a Smart Home demo application (include smart-led controller, weather controller, video) and a number of example applications to give you a quick and easy start. Kit Contents The EDM6070AR-01 SBC is packed with the items listed below:  MINI6935 CPU Process Board based on AT91SAM9X35 MCU  Expansion Base Board  7” Touchscreen LCD Display  Product DVD/CD includes BSP, demo application & technical documentation. Optional Accessories (need to purchase separately):  Serial Cable (Cross Over Female-to-Female)  Ethernet Cable  MicroUSB Cable  Serial Interface Adapter  Power Adapter (12V@1.25A) 3|Pa g e Board Interface Figure 1: MIN6935 CPU Module Figure 2: Base Board Interface with Mounted CPU Module 4|Pa g e System Block Diagram AT91SAM9X35 GPIO ISO Data RS485 ISO K9F2G08U0 NAND CAN 2.0 ISO AT24C04BN TWI MAC DM916 800x480 RGB 7 LCD MT47H64M16HR AT25DF321 32MB DDR2 RTC Watchdog Key SD CARD Reset USB Host USB Device Audio RS232 Debug Port Figure 3: System Block Diagram 5|Pa g e Physical Dimensions Figure 4: MINI6935 Dimensions Figure 5: Expansion Board Dimensions 6|Pa g e Hardware Features CPU  Atmel AT91SAM9X35 ARM9 32-bit processor, 400MHz  16KB Data cache, 16KB Instruction cache, Memory Management unit  64KB internal ROM and 32KB internal SRAM On-Board Memory  128MB DDR2 SDRAM  256MB NAND Flash  4MB DataFlash On-Board Interfaces  7” TFT LCD display, resolution of 800x480 with 24-bit color depth  10/100Mbps Ethernet interface, using DM9161CIEP chip, extendable via expansion board  RS232 interface, 1 RS485 interface, 1 CAN interface  USB Host high-speed interface  USB Device interface  Ethernet interface  Three GPIOs as Input interfaces  Four GPIOs as Output interfaces  Audio output interface, supporting MP3 playback  Debugging Interface, extendable via expansion board  TF card slot Others  I/O interface LED indicator, 2 LED power indicators 7|Pa g e  Buzzer  I/O button  Reset button  RTC (no battery by default)  Watchdog Operational Parameters  Operating Temperature: -10 °C ~ 70 °C  Operating Humidity: 0% ~ 90% (Non-condensing)  Power Supply: 12V@1.25A  Electrical Standards: CE, FCC and CCC  Product Dimensions: 181mm x 120mm 8|Pa g e Software Features BSP Packages Types Names Bootstrap Descriptions Serial Flash Serial Flash BIOS U-Boot Supports kernel and file system programming through SAM-BA or USB flash drive (USB flash drive is recommended) Kernel Linux- ROM/CRAM/EXT2/EXT3/FAT/NFS/JFFS2/YAFFS2/UBIFS 2.6.39 file systems Serial Debugging and COM2 serial interface on CPU RTC Ethernet Internal RTC of AT91SAM9X35 10/100M Ethernet driver Flash NAND Flash and DataFlash driver LCD LCD driver, 800x480 resolution Touch Touchscreen controller on CPU Screen Device Drivers USB Host USB Host driver Watchdog Built-in watchdog driver SD Card SD card driver CAN Bus 1 CAN bus RS-485 1 RS-485 bus LED 1 system status LED BEEP 1 buzzer driver Audio WM8731EDS audio output driver Button 1 custom user button driver GPIO Root File System UBIFS GPIO driver, 3 input channels, 4 output channels Readable and writeable file system, supporting compression storage 9|Pa g e Example Applications The EDM6070AR-01 includes Linux BSP and supports the Linux QT GUI (Graphical User Interface) and multiple file systems like, FAT, NTFS etc. It is also supplied with a Smart Home demo application (include smart-led controller, weather controller, video) and a number of example applications to give you a quick and easy start. Given below is a example applications directory structure of the provided CR-ROM for easy navigation: /home/app COM UART Test EVTEST Event Devices Test GPIO GPIO Test LED LED Test BEEP Buzzer Test CAN Test CAN CAN Receiver Test CAN Transmitter Test Figure 6: Example Applications (Directory Structure) 10 | P a g e
EDM6070AR-01 价格&库存
很抱歉,暂时无法提供与“EDM6070AR-01”相匹配的价格&库存,您可以联系我们找货
