FLOW METER KIT SLF3S-1300F
    SENSIRION(盛思锐)
    SENSIRION - EVALUATION KIT SLF3S-1300F - EVALUATION KIT SLF3S 03AH4501
FLOW METER KIT SLF3S-1300F 数据手册
SLF3S-1300F Liquid Flow Sensor Made to Measure – The Next Level in Liquid Flow Sensing ▪ ▪ ▪ ▪ ▪ ▪ Low flow sensing up to ±40 ml/min Calibrated for H2O and IPA Temperature compensated Turn down ratio 200:1 or better Very compact and light-weight form factor Response time below 20 ms Product Summary The SLF3S-1300F is Sensirion’s compact liquid flow sensor designed for high-volume applications. It enables precise and reliable measurements of dynamic liquid flow rates up to 40 ml/min bi-directionally. The SLF3S-1300F sensor features a digital interface (I2C) via a 6-pin standard electrical connector. The SLF3S-1300F builds on the latest generation CMOSens® sensor chip that is at the heart of Sensirion’s flow sensing platform and allows achieving an outstanding performance. The patented CMOSens® technology combines the sensor element, signal processing and digital calibration on a small CMOS chip. The well-proven CMOS technology is perfectly suited for high-quality mass production and is the ideal choice for demanding and cost-sensitive OEM applications. Benefits of Sensirion’s CMOSens® Technology ▪ High reliability and long-term stability ▪ Best signal–to-noise ratio ▪ Industry-proven technology with a track record of more than 20 years ▪ Designed for mass production and high process capability www.sensirion.com Version 1.0 – D1 – June 2019 1/20 Contents 1 Sensor Performance 3 2 Specifications 5 3 Sensor Output Signal Description 6 4 Digital Interface Description 10 5 Fluidic Specifications and Connections 15 6 Mechanical Specifications 15 7 Mechanical Mounting of the SLF3S-1300F Sensor 16 8 Ordering Information 18 9 Packaging Information 18 10 Important Notices 19 11 Headquarters and Subsidiaries 20 www.sensirion.com Version 1.0 – D1 – June 2019 2/20 1 Sensor Performance The following Table 1 and Table 2 list the specifications of the SLF3S-1300F liquid flow sensor for. The product comes fully calibrated for water (H2O) and Isopropyl alcohol (IPA). Parameter H2O Full scale flow rate H2O Sensor output limit1 Accuracy2 (whichever error is larger) Repeatability2 (whichever error is larger) Temperature coefficient3 (additional error / °C; whichever is larger) Mounting orientation sensitivity4 SLF3S-1300F ±40 ±65 ±5 0.05 ±0.5 0.01 0.2 0.002
物料型号:SLF3S-1300F
器件简介: SENSIRION SLF3S-1300F是一款紧凑型液体流量传感器,专为大批量应用设计,能够双向测量动态液体流量,最高可达40 ml/min。该传感器采用数字接口(I2C),通过6针标准电连接器进行通信。
引脚分配: - 1:非功能性,可接地或悬浮 - 2:SDA(数据),双向串行数据 - 3:VDD,供电电压 - 4:GND,地 - 5:SCL(时钟),双向串行时钟 - 6:非功能性,可接地或悬浮
参数特性: - H2O全量程流量:±40 ml/min - H2O传感器输出限制:+65 ml/min - 精度:±5%(测量值的百分比,以较大者为准)或0.05 ml/min - 重复性:±0.5%(测量值的百分比,以较大者为准)或0.01 ml/min - 温度系数:0.2%测量值/°C(每°C额外误差,以较大者为准)或0.002 ml/min/°C
功能详解: SLF3S-1300F基于CMOSens®传感器芯片,具有高可靠性和长期稳定性,最佳信噪比,并且适用于大规模生产。传感器还具备故障模式检测功能,如空气在线检测和超出传感器输出限制的高流量检测。
应用信息: 适用于需要精确测量液体流量的应用,如工业过程控制、医疗设备等。
封装信息: - 最大尺寸:48x15.5x8.9 mm³ - 重量:3.0 g - 内径:1.4 mm - 内部体积:58 µl - 最大推荐工作压力:12 bar - 额定爆破压力:25 bar
FLOW METER KIT SLF3S-1300F 价格&库存
很抱歉,暂时无法提供与“FLOW METER KIT SLF3S-1300F”相匹配的价格&库存,您可以联系我们找货
