B1D10120F
B1D10120F
    BASIC(基本半导体)
    TO-263
    B1D10120F
B1D10120F 数据手册
B1D10120F SiC Schottky Diode VRRM = 1200 V IF(Tc=155°C) = 10 A QC = 63 nC Features: ⚫ Extremely low reverse current ⚫ No reverse recovery current ⚫ Temperature independent switching ⚫ Positive temperature coefficient on VF ⚫ Excellent surge current capability ⚫ Low Capacitive charge Benefits ⚫ Essentially No switching losses ⚫ System efficiency improvement over Si Diodes ⚫ Increased power density ⚫ Enabling higher switching frequency ⚫ Reduction of Heat Sink Requirements ⚫ System Cost savings due to smaller magnetics ⚫ Reduced EMI Applications ⚫ Switch Mode Power Supplies (SMPS) ⚫ Uninterruptable power supplies ⚫ Motor Drivers ⚫ Power Factor Correction Pacakge Pin definitions ⚫ Pin1- Cathode ⚫ Pin2- Anode Package Parameters Part Number Marking Package B1D10120F B1D10120F TO-263-2 1 / 7 B1D10120F SiC Schottky Diode Maximum ratings Symbol Parameter Test conditions Value Unit VRRM Repetitive Peak Reverse Voltage 1200 V VRSM Surge Peak Reverse Voltage 1200 V IF Continuous Forward Current Tc=25°C Tc=135°C Tc=155°C 30 14.5 10 A IFSM Non-Repetitive Forward Surge Current Tc=25°C , tp=10ms, sine halfwave 77 A ∫i2dt i2t Value Tc=25°C ,tp=10ms 29.6 A2S Power Dissipation Tc=25°C Tc=110°C 134 43 W Operating junction temperature -55~175 °C Storage temperature -55~135 °C Ptot Tj Tstg Thermal Characteristics Symbol Parameter Min. Value Typ. Max. Unit Rth(jc) Thermal resistance from junction to case 0.931 K/W Rth(ja) Thermal resistance from junction to ambient 66.76 K/W 2 / 7 B1D10120F SiC Schottky Diode Electrical Characteristics Static Characteristics(Tj=25°C unless otherwise specified) Symbol Parameter Test conditions Min. Value Typ. Max. 1200 Unit VDC DC blocking voltage Tj=25°C V VF Diode forward voltage IF=10A Tj=25°C IF=10A Tj=175°C 1.46 2.17 V IR Reverse current VR=1200V Tj=25°C VR=1200V Tj=175°C 4.5 45 μA Dynamic Characteristics(Tj=25°C unless otherwise specified) Symbol QC Parameter Total capactive charge Test conditions VR=800V Tj=25°C VR Min. Value Typ. Max. Unit 63 nC 614 62 51 pF 𝑄𝐶 = ∫0 C(V)dV C Total Capacitance VR=1V f=1MHz VR=400V f=1MHz VR=800V f=1MHz 3 / 7 B1D10120F SiC Schottky Diode Typical Performance Figure 2. Typical reverse current as function of reverse voltage Figure 1. Typical forward characteristics Figure 3. Diode forward current as function of temperature, D=duty cycle Figure 4. Typical capacitance as function of reverse voltage, C=f(VR); T j =25°C; f=1 MHz 4 / 7 B1D10120F SiC Schottky Diode Figure 5. Typical reverse charge as function of reverse voltage Figure 6. Power dissipation as function of case temperature Zthjc (K/W) 1 D=0.5 D=0.3 D=0.1 D=0.05 D=0.02 D=0.01 Single pulse 0.1 0.01 0.001 1E-6 1E-5 1E-4 0.001 0.01 0.1 1 tp (s) Figure 7. Max. transient thermal impedance, Zth,jc=f(t ), parameter: D=t /T 5 / 7 B1D10120F SiC Schottky Diode Package Dimensions 6 / 7 B1D10120F SiC Schottky Diode Revision History Revision: Preliminary Version Previous Revision BASiC Semiconductor Ltd. Shenzhen, China © 2018 BASiC Semiconductor Ltd. All Rights Reserved. Information For further information on technology, delivery terms and conditions and prices, please contact the nearest BASiC Semiconductor Office Disclaimer The information given in this document shall in no event be regarded as a guarantee of conditions or characteristics. With respect to any examples or hints given herein, any typical values stated herein and/or any information regarding the application of the device, BASiC semiconductor Ltd. hereby disclaims any and all warranties and liabilities of any kind, including without limitation, warranties of non-infringement of intellectual property rights of any third party. 7 / 7
B1D10120F
- 物料型号: B1D10120F - 器件简介: 该二极管具有极低的反向电流、无反向恢复电流、温度无关的开关特性、正温度系数的正向电压、出色的浪涌电流承受能力、低电容电荷和减少电磁干扰的特点。 - 引脚分配: Pin1为阴极,Pin2为阳极。 - 参数特性: 包括重复峰值反向电压(VRRM)为1200V,连续正向电流(IF)在不同温度下有不同的值,如在155°C时为10A,以及热阻和功率耗散等。 - 功能详解: 包括静态特性和动态特性,例如正向电压(VF)、反向电流(IR)、总电容电荷(Qc)和总电容(C)。 - 应用信息: 适用于开关电源模式供应(SMPS)、不间断电源供应、电机驱动器、功率因数校正等。 - 封装信息: 封装类型为TO-263-2,提供了详细的封装尺寸。
B1D10120F 价格&库存
很抱歉,暂时无法提供与“B1D10120F”相匹配的价格&库存,您可以联系我们找货
