D882-1.1
D882-1.1
    IDCHIP(英锐芯)
    SOT89-3
    D882-1.1
D882-1.1 数据手册
深圳市英锐芯电子科技有限公司 P沟道功率晶体管   D882 NPN Silicon Power Transistor The transistor is subdivided into four groups, R, Q, P and E, according to its DC current gain. Absolute Maximum Ratings (Ta = 25 OC) Symbol Value Unit Collector to Base Voltage VCBO 40 V Collector to Emitter Voltage VCEO 30 V Emitter to Base Voltage VEBO 5 V IC 3 A Peak Collector Current (t = 10 ms) ICP 7 A Total power dissipation (Ta = 25 C) Ptot 1 W Total power dissipation (Tc = 25 OC) Ptot 10 W Tj 150 O C Tstg - 55 to + 150 O C Symbol Min. Typ. Max. Unit hFE hFE hFE hFE hFE 30 60 100 160 200 - 120 200 320 400 - ICBO - - 1 µA IEBO - - 1 µA VCE(sat) - - 0.5 V VBE(sat) - - 2 V Gain Bandwidth Product at VCE = 5 V, IC = 0.1 A fT - 90 - MHz Output Capacitance at VCB = 10 V, f = 1 MHz Cob - 45 - pF Parameter Collector Current O Junction Temperature Storage Temperature Range Characteristics at Ta = 25 OC Parameter DC Current Gain at VCE = 2 V, IC = 20 mA at VCE = 2 V, IC = 1 A Current Gain Group R Q P E Collector Base Cutoff Current at VCB = 30 V Emitter Base Cutoff Current at VEB = 3 V Collector Emitter Saturation Voltage at IC = 2 A, IB = 0.2 A Base Emitter Saturation Voltage at IC = 2 A, IB = 0.2 A 电话:0755-82568882 邮箱:idchip@indreamchip.com 82568883 传真:0755-82568886 网址:www.idchip.cn        A 1308 公司地址:深圳市福田区滨河大道联合广场 座   深圳市英锐芯电子科技有限公司 P沟道功率晶体管   D882 o TYPICAL CHARACTERISTICS (Ta=25 C) TOTAL POWER DISSIPATION vs. AMBIENT TEMPERATURE NOTE 1.Aluminum heat sink of 1.0 mm thickness. 2.With no insulator film. 3.With silicon compound. he at 4 25c m 2 9cm 2 2 Without heat sin k 0 0 50 100 ite d 60 d ite m Li nk si 100 cm 2 Lim n io at ip ss Di ite fin 6 S/b 80 Rth-Thermal Resistance- oC/W dT-Percentage of Rated Current-% 8 VCE=10V I C=1.0A 30 Duty=0.001 100 In P T-Total Power Dissipation-W 10 THERMAL RESISTANCE vs. PULSE WIDTH DERATING CURVES FOR ALL TYPES 40 20 10 3 1 0.3 0.1 0 150 50 100 0.3 150 1 10 3 30 100 300 1000 PW-Pulse Width-mS o Ta-Ambient Temperature - C Tc-Case Temperature -o C 0.3 I C-Collector Current-A 1 0.1 0.03 NOTE 1.T C=25o C 2.Curves must be derated Iinearly with increase of temperature and Duty Cycle. 3 6 10 7 1.2 6 5 0.8 4 3 30 60 1 0.6 VBE 0.3 3 4 12 8 10 3 0.1 3 10 100 30 10 3 Cib 100 60 30 Cob 10 6 3 1 0.01 I C-Collector Current-A f=1.0MHz I E=0(C ob) I C=0(C ib) 300 Cib -Input Capacitance-pF Cob-Output Capacitance-pF VCE(sat) 0.01 0.006 0.003 INPUT AND OUTPUT CAPACITANCE vs. REVERSE VOLTAGE VCE=5.0V Forced air cooling (with heat sink) 300 电话:0755-82568882 1 20 GAIN BANDWIDTH PRODUCT vs. COLLCETOR CURRENT 1000 VBE(sat) 1 16 I C-Collector Current-A I C=10.I B Pulse Test 0.001 0.003 0.01 0.03 0.1 0.3 10 6 3 o Voltage-V VCE-Collector to Emitter 0.1 0.06 0.03 30 100 f T-Gain Bandwidth Product-MHz VBE(sat) -Base Saturation Voltage-v VCE(sat)-Collector Saturation Voltage-V 1 0.6 0.3 60 1 0.001 0.003 0.01 0.03 0.1 0.3 0 BASE AND COLLECTOR SATURATION VOLTAGE vs. COLLECTOR CURRENT 3 h FE 100 I B =1mA VCE-Collector to Emitter Voltage-V 10 2 0.4 0.01 1 300 10 9 8 1.6 VCEO MAX. IC-Collector Current-A 3 VCE=2.0V Pulse Test Pulse Test h FE -DC Current Gain I C(pulse) MAX.(PW 10ms,Duty Cycle 50%) PW 1m 10 s =1 I C(DC) MAX. ms 00 DC s Di s (S sip ing at Li i le o S/ m n no b ite nr Li d ep m et i te iti d ve pu lse ) 0.03 0.1 I C-Collcetor Current-A 0.3 1 1 3 6 10 60 邮箱:idchip@indreamchip.com 82568883 传真:0755-82568886 网址:www.idchip.cn        A 1308 公司地址:深圳市福田区滨河大道联合广场 30 VCB-Collector to Base Voltage-V VEB -Emitter to Base Voltage-V 座   VBE -Base Emitter Voltage-V 1000 2.0 10 DC CURRENT GAIN, BASE TO EMITTER VOLTAGE vs. COLLECTOR CURRENT COLLECTOR CURRENT vs. COLLECTOR TO EMITTER VOLTAGE SAFE OPERATING AREAS 深圳市英锐芯电子科技有限公司 P沟道功率晶体管   D882 SOT-89 PACKAGE OUTLINE 电话:0755-82568882 邮箱:idchip@indreamchip.com 82568883 传真:0755-82568886 网址:www.idchip.cn        A 1308 公司地址:深圳市福田区滨河大道联合广场 座
D882-1.1 价格&库存
很抱歉,暂时无法提供与“D882-1.1”相匹配的价格&库存,您可以联系我们找货
D882-1.1
    • 1+0.93960
    • 200+0.36364
    • 500+0.35090
    • 1000+0.34452
