BGS2T RS232
BGS2T RS232
    THALES(泰雷兹)
    BGS2T RS232
BGS2T RS232 数据手册
TERMINALS Cinterion® BGS2 Terminal Plug-and-Play with Most Flexible Mounting Cinterion® BGS2 Terminal Plug-and-Play with Most Flexible Mounting BGS2 Terminal Quad-Band 2G Compact Size GPRS Class 10 Flexible Mounting Large Input Voltage Range Industrial Interfaces TCP / IP Low Power Consumption The ultra-compact BGS2 Terminal incorporates the latest generation of powerful 2G wireless modules featuring a QuadBand GSM/GPRS baseband, TCP/IP connectivity based on GPRS class 10 data transmission and outstanding low power consumption. Ideal for first time M2M implementers and small scale deployments, the BGS2 Terminal offers reliable, cost-effective, out-of-the-box M2M communications for a variety of industrial applications such as metering, security, transportation, remote monitoring and control and many more. The plug-and-play design includes a robust plastic housing with unparalleled mounting options, a range of common industrial interfaces such as RS-232 and RS-485 as well as an integrated SIM cardholder to enable easy deployment. Quad-Band support ensures global coverage for an all-in-one solution with data communications plus SMS and fax capabilities. Like all Cinterion products, the BGS2 Terminal comes with full type approval (FTA) and is certified by the largest carriers worldwide. Plug-and-Play with Most Flexible Mounting Most Flexible Mounting Sharing the footprint of a credit card, the slim terminal fits in almost every M2M application. To ensure a simple, reliable and efficient integration the ultra-compact design incorporates a highly flexible mounting concept:  DIN rail mounting  C-rail mounting  Screw fixing  The use of cable ties Low Power Consumption Plug & Play BGS2 Terminal is a simple and reliable plug-and-play communication device that allows M2M entrants to quickly connect their industrial applications using wireless technology with low integration and approval efforts, saving significant time to market. The new M2M Terminal equipped with Cinterion’s BGS2 module is based on the latest chipset generation, offering bestin-class power efficiency to extend operating time while saving battery power. Industrial Interfaces The robust BGS2 Terminal comes in two versions offering verticalspecific industrial interfaces, such as RS-485 used in automatic meter reading or RS-232 for general purpose applications. Thales M2M Support includes:  Personal design-in consulting for hardware and software Local engineers, a competent helpdesk, a dedicated team of R&D specialists and an advanced development center are the hallmarks of our leading support offer.  Extensive RF test capabilities  GCF/PTCRB conform pretests to validate approval readiness  Regular training workshops Cinterion® BGS2 Terminal Features General Features   GSM Quad-Band:850/900/1800/1900 MHz   GPRS multi-slot class 10   Compliant to GSM phase 2/2+3GPP Release 99   Output power:   Class 4 (2W) for GSM850   Class 4 (2W) for GSM900   Class 1 (1W) for GSM1800   Class 1 (1W) for GSM1900   SIM Application Toolkit Rel.99   Dimension: 80 × 55 × 23 mm (excluding connectors)   Operation Temperature Ranges:   Normal operation: -30 °C to +85 °C   Restricted operation: -40 °C to +90 °C   Weight 65 g  WEEE   RoHS and EuP compliant Specifications  GPRS class 10: DL: max. 85.6 kbps, UL: max. 42.8 kbps  Control via AT commands (Hayes, 3GPP TS 27.007 and 27.005)   Mobile Station class B   TCP/IP stack access via AT commands   USSD support  Internet Services: FTP, ICMP, DNS, TCP server & client, UDP client, HTTP, SMTP, POP3, Transparent Mode   SMS text and PDU mode, cell broadcast   Supply voltage range: 8 - 30 V   CSD data transmission   Fax Group 3, class 1&2 Special Features Drivers   Hardware watchdog  Driver for Microsoft® Windows 7™, Windows XP™ and Windows Vista™   Firmware update via serial interface   Real time clock with alarm functionality   Flexible mounting concept   Cable fixations Interfaces Approvals   CE, R&TTE, GCF, FCC, PTCRB, IC   Local approvals and network operator certifications   Antenna Connector SMA (female)   Mini-SIM card reader, 1.8 V and 3.0 V  Plug-in power supply connector (6-pole Western jack @BGS2T RS232  V.24 / V.28 RS-232 Interface (D-sub 9-pole female socket @BGS2T RS232)  6 pin header with RS-485 interface, power and ignition/reset (@BGS2T RS485)   Operating status LED’s Thales delivers innovative IoT technology that simplifies and speeds enterprise digital transformation. For more than 20 years, our customers – in a wide range of industries - trust our IoT solutions to seamlessly connect and secure their IoT devices, maximise field insights, and accelerate their global business success. Thales solutions:  Connect assets to wireless networks and cloud platforms  Manage the long lifecycle of IoT solutions  Secure devices and their data  Analyse real-time data transforming it into business intelligence that improves decision making Our 360° approach provides the essential building blocks needed to simplify design, streamline development and accelerate timeto-market. For more information, please visit www.thalesgroup.com/IoT or follow @ThalesIoT on Twitter thalesgroup.com/iot  Thales has a policy of continuous development and improvement and consequently the equipment may vary from the description and specification in this document. This document may not be considered as a contract specification. Graphics do not indicate use or endorsement of the featured equipment or services. © Thales 2020. All rights reserved. Thales, the Thales logo, are trademarks and service marks of Thales and are registered in certain countries. 3 Jun 2020 Thales in IoT: Driving digital transformation with the power of the IoT
BGS2T RS232 价格&库存
很抱歉,暂时无法提供与“BGS2T RS232”相匹配的价格&库存,您可以联系我们找货
